Tire & Wheel Forum sponsored by The Tire Rack |
11-06-2014, 08:54 PM | #1251 |
Member#: 301428
SCIC
Vehicle:2015 WRX CWP |
Yup, +38 to +40 will be much better for stock body.
11-06-2014, 09:38 PM | #1252 |
Member#: 381623
NWIC
Vehicle:2015 Subaru WRX WRB |
11-06-2014, 11:26 PM | #1253 |
Member#: 397303
Anyone got any info or pics about going smaller?
i.e. 16's or even 15's? Brake clearance etc. Perhaps suggestions? I'm finding it tough to find 5 x 114.3 for anything less than 17's. EDIT: After doing more research it seems as though 17's are the smallest that can fit due to the brakes. Last edited by Brahlicious; 11-07-2014 at 12:46 AM. |
11-07-2014, 01:08 AM | #1254 |
Member#: 296571
Vehicle:2011 Subaru WRX Black |
Question for anyone who cares to chime in- I just picked up a set of winters at discount tires for my 2015 WRX. They sold me 235/45R17 blizzaks on a 17x7" rims. I didn't think much about it at the sales counter, but now that I have the car back, I think it looks a little "bulgey", and I'm not entirely sure about running 235s on 7" rims. Any advice?
11-07-2014, 01:20 AM | #1255 |
Member#: 388585
Vehicle:2015 wrx base ISM |
I believe those are stock spec though. So it should be fine. No idea how winters differ from summer tires though. From the little I've read, seems like many go a size smaller in width with winter tires. I'm not completely sure if it due to traction or fitment though.
11-07-2014, 06:41 AM | #1256 | |
Member#: 391748
NESIC
Vehicle:2015 WRX CWP (sold) 2019 STi CWP |
Those are literally the worst wheels I have ever seen.... |
11-07-2014, 10:18 AM | #1257 | |
Member#: 296571
11-07-2014, 01:09 PM | #1258 |
Member#: 392588
South East
Vehicle:1205 '12 WRX&'05 STI DGM & SWP |
Would have liked to have gone with 265's but chose not to because I do not want to have to do any fender modifications. At stock ride height I may have gotten away with 265's...not at stock ride height though.
11-08-2014, 10:05 AM | #1259 |
Member#: 250511
whats a good 18x8 rim for autocross with an offset close to 55?
11-08-2014, 11:45 AM | #1260 |
Member#: 393716
Vehicle:2015 Wrx STI WRB |
Can somebody confirm the fitment of 18x9.75 +20mm offset of XXR's and what tires would be recommended ?
Thank You |
11-08-2014, 11:51 AM | #1261 |
Member#: 352140
MWSOC
Vehicle:2015 WRX |
11-08-2014, 12:26 PM | #1262 |
Member#: 48025
NESIC
Vehicle:24 FL5 CTR Champ White |
People are running 18x10's with 265's on the WRX/STI but it all comes down to what you're using for suspension and camber also.
11-08-2014, 12:37 PM | #1263 |
Member#: 210315
NWIC
Vehicle:'15 Audi S3 Black |
11-08-2014, 01:13 PM | #1264 | |
Member#: 393716
I really like the concave look of these wheels hence my reason to get +20 offset. Can you please elaborate on "wrong size and offset" ? |
11-08-2014, 02:49 PM | #1265 |
Member#: 381623
NWIC
Et20 is too low. You need a lot of modification to get +20 to fit properly. Even if you get it to fit, the steering may feel a little off.
11-08-2014, 02:58 PM | #1266 | |
Member#: 330690
W. Canada
Vehicle:2011 2.5 HB Blue |
So, it might look good to you... but its a WIDE wheel with a low offset... meaning the wheel is pushed to the outside of the car... and it won't fit unless you really mess with your car... ! |
11-08-2014, 03:18 PM | #1267 |
Member#: 356927
NESIC
Vehicle:'21 WRX STI Crystal White Pearl |
2015 WRX/STi Aftermarket wheel and tire fitment
The lowest you should go with these cars imo is a 35 offset. 38-42 seems to be ideal for 15's with aftermarket wheels. Especially if you plan to lower it at all.
11-08-2014, 03:25 PM | #1268 |
Member#: 268491
Vehicle:2009 Legacy 2.5i Black |
The ride performance issue seems unanswered to me. As I understand it a lower offset changes the suspension geometry and alters the handling. What changes, both physically and performance wise?
Also, if you want to alter from the stock tire position, what's the best way to do that without changing the handling? If you're going with a wider tire, do you want the new tire to be "centered" on the position of the stock tire, the outside in the same location, or the inside in the same location? |
11-08-2014, 06:48 PM | #1269 | |
Member#: 393716
11-09-2014, 12:28 AM | #1270 |
Member#: 389236
Thinking of running 17x8 +35 for now using the stock tires. Going with RCE lowering springs, anyone think rubbing would be a problem with that set up? Have yet to see that on a 2015
11-09-2014, 03:48 PM | #1271 |
Member#: 389236
Okay I can't decide....my car is CWP... It's between these 3 colors
11-09-2014, 08:50 PM | #1272 |
Member#: 392588
South East
11-10-2014, 02:19 AM | #1273 |
Member#: 405297
fitment question
For 2015 STI
Looking at XXR 521 18x8.5 35mm offset w/ 245/40/18 or 235/45/18? Do I need longer wheel stud? Thanks Last edited by sian0120; 11-10-2014 at 02:40 AM. |
11-10-2014, 08:41 AM | #1274 |
Member#: 352140
MWSOC
Vehicle:2015 WRX |
11-10-2014, 08:53 AM | #1275 |
Member#: 395904
TXIC
IMHO you should put in the few hundred more dollars into wheels. For the cost of 6 months car insurance u decrease the risk that ur wheels fail and possibly destroy your car. Unlikely, but getting in a major accident is unlikely too,but you still get insurance.
