Welcome to the North American Subaru Impreza Owners Club Monday February 24, 2020
Old 03-13-2015, 12:24 PM   #1176
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
What's going on with your hp and torque? I expected to see a much different shape with this new setup. There's almost a 80 ft/lbs spike between 4600 and 5800 and it keeps dropping down fast to 7000. HP peaks but then falls as well. I thought it would have a long flat torque curve with power rising to at least 7000. Even with your S1 cams I thought it would look different on this setup. Is something holding it back? Boost is hold very flat so its not that. I can't see anything with your build that would seem to hold you back up top on this setup.
WRXt4cy is offline   Reply With Quote
Old 03-13-2015, 01:29 PM   #1177
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I'm not sure. I was a little surprised it drops so much too. I thought the big torque hump may be wheelspin but I've had a similar curve on half a dozen pulls throughout the week. Other thought is that it could be my way to small filter killing the top end. It is only 2" long.
Old 03-13-2015, 01:32 PM   #1178
Shortpersonbk
Member#: 319017
15 Prius
2JZ miata Death Trap
I can almost guarantee its the intake, i already went through the same thing once this week.
Shortpersonbk is offline   Reply With Quote
Old 03-13-2015, 01:33 PM   #1179
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I saw you pit a 4" intake pipe on yours now. How big is the filter? What did you have in before this?
Old 03-13-2015, 01:34 PM   #1180
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Have done any logs with the filter off to see how they compare?
Old 03-13-2015, 01:34 PM   #1181
Shortpersonbk
Member#: 319017
15 Prius
Well i think my issue with the big filter is that i have the pipe jammed in there really far so its only using a small part of it, the filter its self is like 6.5 inches long or something maybe even 8. I need to cut back the pipe to make it all fit well as i just jammed it in for a test fit and drive.
I normally just run no filter
Old 03-13-2015, 01:44 PM   #1182
besthaticouldo
Member#: 279660
This thing looks like a turd.
All these pics are photoshopped. I can tell by the pixels. Come on people.
besthaticouldo is offline   Reply With Quote
Old 03-13-2015, 01:47 PM   #1183
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
No. I will eventjally but roads are too dirty.
Pipe way into filter is no good. I need to try my velocity stack once the roads are cleaner.
Old 03-13-2015, 01:48 PM   #1184
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
This is the worst part.
Old 03-13-2015, 01:53 PM   #1185
besthaticouldo
Member#: 279660
total photoshop
Old 03-13-2015, 01:54 PM   #1186
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
No, believe it or not it really does look that crappy in real life.
Old 03-13-2015, 03:03 PM   #1187
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
I run this filter directly clamped onto my turbo due to space constraints of my own:
http://www.knfilters.com/search/prod...x?prod=RU-2510
Could something like that, a little taller perhaps work for you or are you trying to avoid having the filter stick out any farther than it is?
Old 03-13-2015, 03:53 PM   #1188
gotsugg
Member#: 204014
02 02 WRB Bugeye
GTX3582 front mount turbo
What is the CFM rating of that filter?
Have you tried any 4th gear data logs?
gotsugg is offline   Reply With Quote
Old 03-13-2015, 04:30 PM   #1189
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
The original hope was to have the filter site behind the foglight cover. But this one doesn't fit anyways, so I should have just gotten something longer. I have looked into Treadstone, Vibrant, and AEM as well as larger offerings from K&N. I just looked at the filter area to try and decide if any will flow enough to be worth it.
I added yours to the list below. It only has a small amount more filter area than my stubby one. Mine is very short, but the diamter is large so that somewhat makes up for it.
I may also try this foam filter. I'm not sure how well it will flow though. It may end up being much worse than an actual filter. I'd prefer not to have something sticking way out of my bumper, but that may be the best option.
http://turbo-guard.com/turbo-guard-sv/
Code:
Brand		Model	 Price 		Height	Bottom 	Top	Filter Area
Treadstone	10045	 $29.40 	6.02	5.90	5.50	216.08
Treadstone	10015	 $26.25 	4.50	5.90	5.50	161.80
Vibrant		10931	 $61.95 	3.63	5.00	5.00	113.88
AEM		21-205	 $48.99 	5.25	6.00	5.13	186.02
K&N		RC-4480	 $62.99 	2.19	6.88	5.88	96.36
K&N		RU-2510	 $37.99 	3.50	5.38	4.38	111.50
K&N		RU-2520	 $41.99 	5.00	5.38	4.38	156.19
I have no idea the flow ratings. That info is very hard to come by.
I haven't done any 4th gear logs. I'm still on snow tires and they don't really like high speed.
Old 03-13-2015, 05:35 PM   #1190
gotsugg
Member#: 204014
02 02 WRB Bugeye
If you call K&N they can give you the CFM rating of that filter. When I designed my set-up I called them prior to buying a filter. The one I have flows about 950 CFM.
http://www.knfilters.com/search/prod...x?prod=RE-0920
Old 03-13-2015, 06:05 PM   #1191
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
That's a hair over 300 in^2. Over 3x the filter area that mine has.
Maybe I should just get an eBay filter. It should have more filter area than mine...
http://www.ebay.com/itm/4-6-W-COLD-S...-/191287565901
http://www.ebay.com/itm/4-6-75-H-COL...-/400792420440
http://www.ebay.com/itm/4-YELLOW-COL...-/191383087330
http://www.ebay.com/itm/4-100mm-Mush...-/261448567930
Old 03-13-2015, 06:11 PM   #1192
gotsugg
Member#: 204014
02 02 WRB Bugeye
How often will you really be running a filter?
Old 03-13-2015, 06:12 PM   #1193
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Probably most of the time on the street? I drove it to work every day this week. I've had a filter on the whole time.
Old 03-14-2015, 12:09 AM   #1194
redprzdent311
Member#: 201377
2010 Forester
Chamilia Red Pearl
Love your progress and the way everything is so well done. I cant wait to see some trap times. Have you thought about running the fog covers (just the turbo side) that are mesh with some sort of 'fabbed' drop in style filter behind it for street use and removable filter for the strip or just a stealth look?
redprzdent311 is offline   Reply With Quote
Old 03-14-2015, 12:13 AM   #1195
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I've considered many different options. I really haven't decided anything yet. I'd really love to just run a velocity stack and no filter but I don't think that would end well on the street.
Old 03-23-2015, 12:25 AM   #1196
brett192
Member#: 274252
2002 WRX Sedan PSM
EJ207 & 6 speed
Hey Ben I seem to remember you posting side-by-side shots of the Tial vs Turbosmart EWGs but can't find them for the life of me.. can you repost them if it's convenient?
I see you're running Turbosmart now, would you say they are superior to Tial?
brett192 is offline   Reply With Quote
Old 03-23-2015, 01:02 AM   #1197
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I think this is the best comparison I've posted:
I ran both the Tial and the TurboSmart EWG's on my 2011. I greatly preferred the TurboSmart. It is a waaaay smaller physical package, has a better build, and the locking collar is much more convenient than the bolt on cap. On my rotated setup I could actually swap springs without even taking the gate off the car!
http://forums.nasioc.com/forums/show...postcount=5418
Obviously this won't be possible with a stock location setup but I still find the TurboSmart design to be far superior and well worth the money. Once installed and setup correctly I didn't have any issues with either of them. They're both solid options and work very well.
http://forums.nasioc.com/forums/show...&postcount=825
http://forums.nasioc.com/forums/show...&postcount=833
Originally Posted by rocklizzard91 View Post
Good info!
The tial gates have vband clamps now and have the option of water cooling.
I'm going ewg soon and I've been torn between the two. The new model tials look much more like the turbosmart's do.
Edit: Nvm looks like you did use the newer tial, is it really that much bigger?
Ifek and xluben do you have the grimmspeed uppipe? Or a modified aftermarket uppipe?
I'm looking to have a fabricator friend just weld me vbands on my Invidia uppipe
The Tial does have water cooling and that is the only real difference. This is the cause of the larger size. If you plan on using the water cooling, then it's a no brainer. Tial is the way to go. But most people don't use it (and have no issues), and then the TurboSmart is a lot smaller package.
Here are some pictures to compare. They are scaled in a way that is a bit misleading. Just keep in mind that the bottom portion of these images is really the same size between the Tial and TurboSmart. If you keep that in mind, you should be able to tell that the upper half of the Tial is much, much larger.
Tial 38mm vs TurboSmart 40mm
Tial 44mm vs TurboSmart 45mm
Old 03-23-2015, 02:56 AM   #1198
brett192
Member#: 274252
2002 WRX Sedan PSM
EJ207 & 6 speed
Thanks for the great response! I thought the Tial was smaller for some reason.. Good thing I just installed a Comp-Gate40
Keep up the good work
Old 03-24-2015, 01:32 PM   #1199
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Thanks! Hopefully I'll have a bunch of different intake options to compare soon. Once the weather improves...
Old 03-24-2015, 11:40 PM   #1200
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Any guesses on how all of these will compare?
