Welcome to the North American Subaru Impreza Owners Club Wednesday July 8, 2020
Old 04-25-2015, 10:08 PM   #1276
projectQWKSLVR
Member#: 285270
03 WRX
You should look into the "H6 upgrade" for the rear.
-Same caliper and pad
-1.1" taller rotor and taller caliper hanger to match
Best part... It can be done very very cheap
projectQWKSLVR is offline   Reply With Quote
Old 04-25-2015, 10:16 PM   #1277
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
That does look easy and cheap. I'd be worried about them fitting under my 15" wheels (slick setup).
Old 04-25-2015, 10:19 PM   #1278
projectQWKSLVR
Member#: 285270
03 WRX
That does look easy and cheap. I'd be worried abojtvthem fitting under my 15" wheels (slick setup).
Still smaller than the front tho...
Old 04-25-2015, 10:50 PM   #1279
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Good point. I might have to look into that when I get around to doing the rear brakes.
Old 04-25-2015, 10:58 PM   #1280
projectQWKSLVR
Member#: 285270
03 WRX
With the speeds you're hauling down from... It's a no brainer! lol If the pads are still good, I bet you could do it for under $100
Old 04-25-2015, 11:42 PM   #1281
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I've had various people comming on the stopping power from stock brakes (not just you), so I made a video. I will considering the larger rears once it's time to replace them, though.
Here's an extended cut of my 10.3 @ 139mph pass from Rock Falls last weekend. For anyone concerned that stock brakes aren't enough stopping power check out the video.
It is ~10 seconds from 140-40mph and another ~10 seconds cruising at 40mph before turning to head back. Probably no more than 1/3 to 1/2 braking at any point.
Old 04-25-2015, 11:50 PM   #1282
projectQWKSLVR
Member#: 285270
03 WRX
No doubt the stock brakes will stop it. With the larger rear, the bias swings toward the rear some. Which is good since ours are so far forward biased. The idea of a more stable car, again at those speeds, is only added insurance in my eyes. You've made it clear you're all about straight line performance, and part of that is stopping, in a straight line.
I too play some in straight lines, all be it in an 81' Camaro that'll pull the front tires off the ground for 15-20'. ;-) I just prefer my subie on the auto-x as it turns, and the Camaro just doesn't, EVER! lol
Old 04-30-2015, 12:40 PM   #1283
enjoilife1991
Member#: 322400
03 WRX 360whp
I'm an engineer and my wife and I do photography on the side. BUT little to none of the money for the car comes from those sources of income. It's mostly funded just by selling things. Haha.
Also, keep in mind that the total cost of the project (including the car itself as well as all the mods) is still less than what you'd pay for a new WRX on the dealer lot (let alone a new STI).
not to bring this up agian but... just what kind of "things" are you selling?
enjoilife1991 is offline   Reply With Quote
Old 04-30-2015, 12:49 PM   #1284
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Mainly flip keys but I'm not supposed to say that on NASIOC. I also do a pretty good job of selling my old parts whenever I upgrade.
Old 04-30-2015, 12:52 PM   #1285
besthaticouldo
Member#: 279660
Drugs, it's drugs.
besthaticouldo is offline   Reply With Quote
Old 05-01-2015, 12:16 AM   #1286
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Spent some time on the dyno today. Made 666WHP.
Old 05-01-2015, 08:24 AM   #1287
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Seems about right for the boost level you are running. What's holding you back from turning up the boost?
Are you going to post the full plot? Can't really see much from the little snippet.
Old 05-01-2015, 08:36 AM   #1288
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Spark was blowing out above 34psi. I'll get some new plugs in tonight. I'll post a plot later. It breaks up at the top end due to the blow out.
Originally Posted by bnifnd View Post
Thanks everyone. No plans set in stone yet. Eventually it will start getting power mods though.
How do these spam accounts always find my thread...
Old 05-01-2015, 08:37 AM   #1289
besthaticouldo
Member#: 279660
Nice numbers dude.
Old 05-01-2015, 12:42 PM   #1290
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Event: Dyno Tuning
Ambient Temp: 78F (in dyno room)
Elevation: ~1,000ft
Weather: Sunny and Clear Outside
Tires: 255/40R17 Federal 595 RS-R Tires on 17x9" +45 Enkei RPF1 Wheels
Car: 2002 WRX Sedan
Tuner: Nuke @ NF Performance
Dyno Info: Dynojet at MAPerformance
Transmission: 2012 STI 6 Speed
Gear: 4th
Peak HP at RPM: 666 WHP @ 7,300 RPM
Peak Torque at RPM: 523 WTQ @ 6,300 RPM
Baseline hp/tq for a stock on same dyno: ~240WHP Stock STI
Target Boost: 35psi
Target AFR: 11's
Fuel: E85
Yesterday Nuke and I took my car to do some dyno tuning at MAP. Since the last time at the track we switched it to an EBCS to be able to ramp up boost at the top end, and also put in a Boost-A-Pump because it was leaning out with the higher boost levels.
The car ended up making 666 WHP at 35psi, but we were seeing spark plug blow out on anything over 33 or 34psi so the plot breaks up at the higher boost levels. You can see the car spitting flames when it misses in the video. New plugs should be going in tonight.
666 WHP / 523 WTQ
Here is a video of the pull.
Old 05-01-2015, 12:50 PM   #1291
imxblue
Member#: 147284
2015 STi
W O W ! ! ! !
imxblue is offline   Reply With Quote
Old 05-01-2015, 01:08 PM   #1292
96accord
Member#: 145105
2007 Impreza WRX STi
'15 Accord (Daily)
I'm not sure but I've noticed that.
I reported it as "spam" before you posted that message this morning lol
Old 05-01-2015, 01:37 PM   #1293
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
What are you running for plug gap? We always have to gap down to around .024 to get over 33-34 psi. That's always about when we see blow out start and a quick gap down on the dyno always clears it right up. .024 on stock iridiums let me go to 42 psi on that 6466 car recently. With .028 it started blowing out at 34.
Old 05-01-2015, 01:44 PM   #1294
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
They're stock heat range Iridium's that I gapped to 0.025". I think we're going to try some fresh Copper's that have been gapped down a little further.
Old 05-04-2015, 08:59 AM   #1295
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Here are a couple rig shots from over the weekend.
Old 05-04-2015, 04:02 PM   #1296
Jive Turkey
Member#: 219492
17' 5mt XV & 02 WRX
@comrad
damn, the want for a rig is strong now lucifer.
Jive Turkey is offline   Reply With Quote
Old 05-04-2015, 07:01 PM   #1297
redprzdent311
Member#: 201377
2010 Forester
Chamilia Red Pearl
Such numbers..so better. Cant wait to see what it does with the plugs situation sorted. Great job Ben and NF! Im still rocking my NF tune, not much has changed I just dont wana lose what he's done for me...until I can bring it back home or if you guys ever come out to the WA/OR area.. ��
redprzdent311 is offline   Reply With Quote
Old 05-09-2015, 11:49 PM   #1298
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Got a Seibon RS-style (scoopless) CF hood. Threw it on for a few pics before I get it painted.
Old 05-10-2015, 08:34 PM   #1299
thatsilverwrx
Member#: 307725
Now 2015 WRX
Looks pretty sweet unpainted
thatsilverwrx is online now   Reply With Quote
Old 05-10-2015, 08:39 PM   #1300
TheAnser
Member#: 84045
2017 Leggy 3.6R
ISM
666 hp....el Diablo!
TheAnser is offline   Reply With Quote
