Welcome to the North American Subaru Impreza Owners Club Tuesday June 2, 2020
Old 05-11-2015, 01:39 AM   #1301
Jive Turkey
Member#: 219492
17' 5mt XV & 02 WRX
@comrad
ricer.
Jive Turkey is offline   Reply With Quote
Old 05-11-2015, 10:42 AM   #1302
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Originally Posted by WRXt4cy View Post
What are you running for plug gap? We always have to gap down to around .024 to get over 33-34 psi. That's always about when we see blow out start and a quick gap down on the dyno always clears it right up. .024 on stock iridiums let me go to 42 psi on that 6466 car recently. With .028 it started blowing out at 34.
Update:
  • Stock heat range Iridium's came out and were gapped around 0.027"
  • One step colder Copper's went in and were gapped around 0.021"
  • Upgraded from stock 70A alternator to OEM 110A alternator
  • Upgraded battery negative to chassis ground with 2AWG welding wire
  • Upgraded TGV to chassis ground with 2AWG welding wire
  • Upgraded battery positive to alternator with 2AWG welding wire
Not seeing any blow out, but I haven't done a lot of driving recently due to rain.
Just for fun I plotted my data on top of the RSTI data that jnorth posted. Very similar powerband.
I believe the turbo's have similar sized compressors (his may actually be larger), but the exhaust housing is different as well as many other parts of the builds.
Looks like his AVCS is helping a bit in the midrange, but mine is carrying the top end a bit stronger. I think that stock location housing is just choking it out, but my setup still drops off up high as well.
Old 05-11-2015, 10:49 AM   #1303
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Good deal on the blow out issue. I think a lot of it was gap. We ran Doogies LGT up to 39 psi peak on stock iridiums gapped to .024 and had no issues at all.
Yeah, I wanted to see more top end out of this custom turbo but it just didn't have it. Big improvement in the mid range and good power for a stock location turbo but you are right, its just choked up. We will see how it can scoot down the track now. 6800 rpm shift points should work. I'd love to see a better fmic core on this car too. It heat soaks a decent amount on the dyno pulls. The ETS core we run in other cars such as the LGT does so much better.
WRXt4cy is offline   Reply With Quote
Old 05-11-2015, 10:55 AM   #1304
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I had tried to gap them down to 0.025 I believe but my tool only goes from 0.023 to 0.028 or something like that and I think I was a lot wider than I thought I was. They're gapped way down now, so it should avoid any future issues. Going to coppers should give me a nice strong spark and since I only drive the car a few thousand miles a year it shouldn't be a big deal to change them out.
My TurboXS style core that I used last year was also kinda small, so I'm glad I got the big Treadstone core for this setup. I think it's one of the biggest ones on the market for these cars. The ETS ones also look really nice. I really need to get an IAT sensor in my post-intercooler FMIC piping one of these days. Right now I really don't know what it's getting up to. Feels ice cold to the touch though. Even on the dyno.
Old 05-11-2015, 01:27 PM   #1305
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Yeah, that's the issue with coppers, they don't last long but with not driving it often, its not a big deal.
I figured you'd already have your IAT being used for charge temp with running speed density. I know guys do without but you should have it that way since charge temp is used in the calculation of airflow. I would have thought Nuke would have insisted on this.
Old 05-14-2015, 08:32 AM   #1306
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Installed some Hella horns on my car. They're on the upcoming GrimmSpeed bracket.
Old 05-14-2015, 08:45 AM   #1307
S2 13BT
Member#: 366651
2006 Forester XT
Obsidian Black Pearl
Neat install!
S2 13BT is offline   Reply With Quote
Old 05-15-2015, 10:19 AM   #1308
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Outfront Motorsports alternator relocation bracket.
Install:
The bracket came with a 28" belt, but it wouldn't fit on my car. The 110A alternator hits the block and stops it from swinging all the way down in the Outfront bracket. I went to the store and got the next size up, which happened to be 39.25". This fits fine, but the alternator is at the very top of the adjustment range. I will be trying to find a 28.5" belt at some point. I think that would be perfect.
Old 05-15-2015, 10:43 AM   #1309
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I've never been a fan of black wheels, but I ended up with black RPF1's because it was too good of a deal to pass up, but I've always been considering a change.
I decided I'd try Plasti Dipping them and see how it would look. I like an OEM-ish silver/gunmetal look but I cheaped out and got the matte gray Plasti Dip.
I painted them with tires on just by sticking index cards in the bead to block overspray. I used 3 full cans for the faces (and overspray onto the barrels) of the 4 wheels.
Honestly, I don't like it at all. I'm not sure what I'll do. It will probably stay for a little while, but it will probably be changed or removed eventually.
Old 05-15-2015, 04:55 PM   #1310
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Some shots of the painted CF hood and the wingless trunk. Also seen are the awful Plasti Dip gray wheels.
Old 05-15-2015, 06:28 PM   #1311
thatsilverwrx
Member#: 307725
2012 WRX
Now 2015 WRX
I don't think the wheels are that bad. kinda like them more than black
thatsilverwrx is offline   Reply With Quote
Old 05-15-2015, 09:09 PM   #1312
S2 13BT
Member#: 366651
2006 Forester XT
The car in garage shot makes the wheels look terrible... Out in the light though it's really not as bad.
Old 05-15-2015, 09:32 PM   #1313
Ultimateone
Member#: 48025
2020 Supra
AZW
No the wheels look god awful, peel that off haha
Everything else is awesome, love this thread
Ultimateone is offline   Reply With Quote
Old 05-15-2015, 09:43 PM   #1314
thatsilverwrx
Member#: 307725
2012 WRX
Now 2015 WRX
dip them white!! they also have a OEM silver style plastidip
Old 05-16-2015, 01:11 AM   #1315
John_Clark42
Member#: 376119
White would look worse!
John_Clark42 is offline   Reply With Quote
Old 05-16-2015, 10:04 AM   #1316
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Now that I see the gray I think white would actually be better. I just hate how dirty the white Plasti Dip gets. I think the silver looks good but I went cheap and got the gray. At this point I might just leave them black until I swap tires and then get them powder coated. Or maybe try and find someone to trade with.
Old 05-18-2015, 09:00 AM   #1317
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Over the weekend I swapped in an 04 WRX cluster. Direct plug and play. I wanted it for the center tach.
I ended up swapping back because center tach doesn't work with my steering column mounted GoPro.
Old 05-18-2015, 12:10 PM   #1318
Flat Face
Member#: 275220
2000 Bugeye
Blue Ridge Pearl
You should pop them open and swap the STI silver surrounds over into your cluster and depending on how adventurous you feel you could also swap over the needles.
Combine those things with the LED mod and you've got a full STI cluster
Flat Face is offline   Reply With Quote
Old 05-18-2015, 01:30 PM   #1319
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Oh, I wish I would have thought of doing the surrounds. That does look a lot nicer. The cluster is already gone though. Went to a local friend with another 600WHP Bugeye.
Old 05-18-2015, 03:28 PM   #1320
Jive Turkey
Member#: 219492
17' 5mt XV & 02 WRX
@comrad
honestly, you should just rattle can the wheels a nice deep gunmetal finish or do some kind of crazy color.
silver wouldn't look bad either...but now you know that DIP is not the way to go
Old 05-18-2015, 03:51 PM   #1321
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I might try the "aluminum" Plasti Dip next. Not sure yet. I just think the flat finish on these looks terrible.
Old 05-18-2015, 05:02 PM   #1322
bicycle_wreck
Member#: 226331
2012 WRX Hatch
Poor Man's Panamera
I like the color a lot. I could take or leave the flat finish, but I don't hate it.
bicycle_wreck is offline   Reply With Quote
Old 05-18-2015, 05:32 PM   #1323
Jive Turkey
Member#: 219492
17' 5mt XV & 02 WRX
@comrad
honestly, just get 17 mac v awesome in gold. will look excellent.
Old 05-18-2015, 06:08 PM   #1324
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I had the Mach V on my 2011, remember? I got them right when they came out.
Also, I will not do gold wheels. I am trying to stand out less, not more.
Old 05-20-2015, 12:03 AM   #1325
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Updated video on the 35psi tune that made 666WHP. 50-100mph came in at 3.36 sec.
