Welcome to the North American Subaru Impreza Owners Club Wednesday May 14, 2025
Old 11-18-2014, 12:01 AM   #1
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Default DIY exhaust AVCS controller?
It's time for me to do a motor build. My car currently has a single-AVCS motor, (like every 05 Legacy GT) and I'm thinking about getting a dual-AVCS motor put in.
Of course that would require something to control the exhaust cam timing, so I'm wondering if it would be practical to build an exhaust-AVCS controller around an Arduino or Atmel AVR or similar small microcontroller.
I write software for a living and I have some embedded exerience, so I'm not worried about that part. If there's a roadblock here it would be in the hardware to interface the AVCS sensors and actuators with the microcontroller. For that, I could use some help.
Does anyone know where I can find some info about the signals from the exhaust cam angle sensors, and the signals to the oil control valves?
Edited to add: If I end up trying this, whatever I come up with will be totally open-source, GPL v2.
Old 07-07-2015, 10:09 AM   #2
NITROS
Member#: 41561
04 GT3076 2.1
Stroker = Broken 3rd
I'm willing to help you out with this. i was thinking about doing this with a netduino instead of arduino but ultimately it doesn't matter.
NITROS is offline   Reply With Quote
Old 07-08-2015, 12:40 AM   #3
NSFW
Member#: 140444
05 Stage Free LGT
I replied to your PM before I even saw this thread... I'd rather do netduino too actually. I spend all day in Visual Studio already.
Old 07-08-2015, 12:33 PM   #4
NITROS
Member#: 41561
04 GT3076 2.1
I looked into netduino, but it is too expensive and the amount of community support is much smaller than arduino. The netduino is significantly more powerful but for this project the arduino gives us enough power.
I just ordered my ardunio leonardo and a starter kit.
Old 07-13-2015, 01:41 PM   #5
86Dreams
Member#: 385256
'18 Giulia QV
'21 Giulia Q4
REALLY interested in this project please post updates. Interested in helping but not sure what I could actually contribute. ~3 years ago when I graduated college I used 4 arduinos to create a 3-phase Inverter, havent touched them since tho.
86Dreams is offline   Reply With Quote
Old 07-13-2015, 09:58 PM   #6
sabreofsd
Member#: 48943
2004 95%*STi Blu/Gld
www.dcawd.com
You're going to need A/D and D/A converters... which probably means voltage dividers on the input side at least. The two big hurtles you're going to encounter:
To mimic the stock ECU's controlling, you'll need to create a table that is looked up for a value based on intake pressure (boost) and RPM. Getting the RPM is easy, the boost might be a little more tricky.
Now for the hard part: Making sure that the Arduino has enough power to maintain nyquist theorem's input/output PWM signals.
So....
A->D conversion
Table look up
D->A conversion of PWM signal to AVCS actuator
Making sure that you do this fast enough to keep up with the engine... otherwise you have the possibility (unlikely) of valve contact.
Check out this link (just googled) for some high speed ADC stuff: http://www.microsmart.co.za/technica...d-arduino-adc/
sabreofsd is offline   Reply With Quote
Old 07-13-2015, 11:33 PM   #7
NSFW
Member#: 140444
05 Stage Free LGT
It's my understanding (possibly wrong) that the cam position sensors are send pulses, not analog signals. And the AVCS control valves just need 12v PWM at relatively low power, so I don't think D/A or A/D will be needed.
Manifold pressure can be had from the existing manifold pressure sensor, or a separate sensor T'd off of an existing line. They're cheap and well understood, I've got an AEM sensor wired in place of the factory sensor on my car.
One of the biggest unknowns IMO is exactly how the AVCS signal pulses work. I'd kinda like to get a source for the sensor plugs so I could make something that would easily wire into a dual-AVCS motor with no cutting or splicing, just to analyze those signals. I don't have a dual-AVCS motor so I'd have to use someone else's for most of the testing.
Old 07-14-2015, 11:56 AM   #8
86Dreams
Member#: 385256
'18 Giulia QV
'21 Giulia Q4
Does the cam position sensor work the same way that a crank position sensor does? Crank position sensors work with a toothed wheel and magnet sensor (Hall-effect?) I believe. When the tooth passes by the sensor it produces an analog pulse, you know the number of teeth on the wheel so you know how fast the wheel (and therefore cam) is moving by counting the teeth. The 'beginning' of a new revolution is marked with either an extra tooth or a missing tooth.
Do the AVCs have drivers that accept a low power signal?
can you get an oscilloscope on an existing AVCs?
Old 07-14-2015, 04:54 PM   #9
sabreofsd
Member#: 48943
www.dcawd.com
Old 07-15-2015, 12:08 PM   #10
NITROS
Member#: 41561
04 GT3076 2.1
I would love any help you can offer. I'm really just learning circuit design for this project, so it will be a while before I have anything tangible.
Answering this as I read the posts, expect edits. I also have a thread going on chippernut http://www.chippernut.com/forums.htm...-im-l-4864009/
1) Does the arduino have enough power to run avcs. I would say so? The is a guy that created a piggyback ecu for a boosted IS300. The concept is very similar. Also there is another arduino project that is being developed as a standalone ecu for mazda engines. It's based off of the Megasquirt v1. Chippernut created a shiftlight using a arduino, with RPM readout, this is relevant as I plan to use the same mechanism to pickup RPM for a ref. He also utilizes the 2JZduino for his own IS300.
IS300: https://thedeltaecho.wordpress.com/2jzduino/
Speeduino: https://www.youtube.com/watch?v=Q475JN-t63E
Chippernut: http://www.chippernut.com/
Old 07-15-2015, 03:44 PM   #11
86Dreams
Member#: 385256
'18 Giulia QV
'21 Giulia Q4
Im subscribed, good luck.
Old 07-16-2015, 02:55 PM   #12
NITROS
Member#: 41561
04 GT3076 2.1
My arduino finally came in. I'm going to try to build some simple circuits to basically just read the RPM and cam position.
Does anyone know how to verify whether the cam position sensor is a hall effect or VR? I know I can use a scope but I don't have one. (First project build a arduino scope?)
Old 07-16-2015, 03:48 PM   #13
sabreofsd
Member#: 48943
www.dcawd.com
Old 07-17-2015, 11:11 AM   #14
86Dreams
Member#: 385256
'18 Giulia QV
'21 Giulia Q4
Originally Posted by sabreofsd View Post
honestly for that price
http://www.amazon.com/Siglent-SDS1052DL-Digital-Oscilloscope-Frequency/dp/B00GQNN70A/ref=sr_1_1?ie=UTF8&qid=1437145821&sr=8-1&keywords=oscilloscope
might as well just get a regular o-scope...assuming youre not working in a parking lot that is.
Old 07-17-2015, 05:33 PM   #15
sabreofsd
Member#: 48943
www.dcawd.com
That's a very decent scope for the price! Better resolution, but no outputs. Different tools for different applications
Old 07-20-2015, 09:18 PM   #16
NITROS
Member#: 41561
04 GT3076 2.1
Looks like I found a solution for the vr signal. www.jbperf.com/dual_VR/v2_1.html
Old 07-21-2015, 12:04 AM   #17
NSFW
Member#: 140444
05 Stage Free LGT
Which sensor uses VR? Is that for the intake AVCS angles?
Old 07-21-2015, 08:56 AM   #18
NITROS
Member#: 41561
04 GT3076 2.1
Its my assumption at the moment that the Exhaust AVCS cam position sensor is VR. The intake cam position is hall effect. This is based on my research. I found that VR sensors are 2 pins and hall effect snesors are 3 pin. On the ej20x the exhaust cam position sensors are 2 pins. the intake cam position sensors are 3 pin.
I still need to verify by hooking it up to an actual scope.
Old 07-25-2015, 11:43 AM   #19
fragment
Member#: 8050
2004 FXTi - Stage 2
Goooooooolld
Subscribed.
My 04 FXti is equipped with DAVCS heads, but no exhaust control. I'm making about 40 hp less than I should given my mods. My tuner suspects the lack of advance is the major issue.
fragment is offline   Reply With Quote
Old 07-25-2015, 01:25 PM   #20
NITROS
Member#: 41561
04 GT3076 2.1
You can mechanically advance the cams a bit by adjusting the cams by two teeth ccw, I think. There is a thread here on nasioc. This would put the exhaust cam in roughly the position of a single access head. Do a search.
Old 07-25-2015, 02:57 PM   #21
fragment
Member#: 8050
2004 FXTi - Stage 2
Goooooooolld
This is my current thinking. Pity I didn't find that thread before I drove 6 hours one way for a tune.
My searching failed me.
Old 07-28-2015, 12:14 AM   #22
NITROS
Member#: 41561
04 GT3076 2.1
This is the thread I referred to.
Http://forums.nasioc.com/forums/showthread.php?t=2582784&page=3
Old 07-31-2015, 02:53 PM   #23
NITROS
Member#: 41561
04 GT3076 2.1
I received my VR conditioner circuit. I will start experimenting building the circuit this weekend.
Old 08-02-2015, 12:36 AM   #24
NSFW
Member#: 140444
05 Stage Free LGT
Subscribed.
Were there any other drawbacks to running no exhaust cam advance? How's startup & general driveability? Did the break-in go OK?
I was thinking about getting a dual-AVCS motor put in now and figuring out the cam control later, but I wasn't sure the motor would even start... Sounds like that fear was a little overblown though.
Old 08-03-2015, 12:39 AM   #25
NITROS
Member#: 41561
04 GT3076 2.1
I am running a JDM ej20x davcs engine on a 05 sti ecu and wiring harness. The car drives fine but it does definitely seem low on power.
Here are some items i found interesting in the 05 and 13 sti manuals. I compared those results with the legacy ej20x/y manuals. I found some differences and also some very helpful diagrams.
One difference I noticed between a EJ20x and DAVCS sti heads is that subaru has changed the cam position sensor from VR on the EJ20x to HallEffect on the DAVCS STI. This is good news for those with STI DAVCS heads as the purchase of a VR conditioner circuit is not required.
Looking at the image below both the 05 sti and 13 cam position in relation to crank position are identical.
2005 STI
2013 STI
If the above is true then I can use this data + some maths, I can calculate crank angle and the positions of the cams. After some more maths I should be able to figure out the needed PWM signal to the AVCS solenoids. I wonder if oil pressure will result in a necessary modification in the PWM signal sent to the AVCS solenoid.
I wonder of the LH intake position signal is a misprint as it shows rise in voltage instead of a drop?
