Welcome to the North American Subaru Impreza Owners Club Thursday February 20, 2020
Old 08-08-2015, 10:49 AM   #1426
Celery GT-5
Member#: 98210
2016 Forester XT CWP
2002 WRX SRP 2016 Sienna
The average engine is pretty easy to pull. Being longitudinally mounted makes subarus a bit easily I'd imagine but pulling out your average fwd i4 isn't all that tough.
Cool video btw.
Old 08-11-2015, 08:52 PM   #1427
ebo03
Member#: 111008
2011 LGT SSM, 2006
Baja Turbo ABP
Subscribed.
ebo03 is offline   Reply With Quote
Old 08-11-2015, 09:56 PM   #1428
561wrx
Member#: 166427
03 wrx
lover your car.
561wrx is offline   Reply With Quote
Old 08-12-2015, 12:23 AM   #1429
panteras
Member#: 32271
2005 STI
White/Silver wheels
It's really not a good daily driver at all. It has no AC, no radio, an exhaust dump, solid billet motor/trans mounts, no sway bars, super squishy tires, and no powerband under 4k. Mostly I just drive it quite slowly to daycare and to work and back, but I like having the ability to rip on it whenever I want. There are always minor tweaks and fixes being made, but I haven't had too many major problems. Plus I have my 2012 Forester so any time there's an issue or an upgrade that I didn't finish installing, or even if it rains then I just drive my Forester.
Do you get stopped by the police when you drive it on the street? Since it doesn't have any muffler at all how loud it is when you drive it? I can only imagine it probably is more than 100db
panteras is offline   Reply With Quote
Old 08-12-2015, 09:34 AM   #1430
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I believe you also commented on my Facebook page, and I responded there, but in case you didn't see it: I have driven a couple thousand street miles since switching to the exhaust dump. No issues so far. It's not really much louder than a fart can exhaust when I'm cruising around.
Old 08-12-2015, 09:35 AM   #1431
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Took my brother's motor out. My old shortblock will be going into his car.
Old 08-12-2015, 01:14 PM   #1432
Marcus Amelious
Member#: 426662
2006 STI
Any reason why you went for the non avcs version of the kelford 280's? I have the avcs version but yet to dyno.
Marcus Amelious is offline   Reply With Quote
Old 08-12-2015, 01:24 PM   #1433
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Because I have a 2002 WRX that does not support AVCS. Also, keeping things as simple as possible for a straight line focused car.
Old 08-12-2015, 01:31 PM   #1434
Marcus Amelious
Member#: 426662
2006 STI
Ah that would make sense, to be honest I doubt I will be able to run much advance on the avcs due to piston/valve contact anyway. Looking forward to the results with your new build, are you still using the 6266?
Old 08-12-2015, 01:37 PM   #1435
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
No, I have a 6766 now.
Old 08-14-2015, 11:53 AM   #1436
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
IAG just posted an update on my motor!
Originally Posted by IAG Performance View Post
Well, until we ship his block tomorrow, you are gonna have to settle for my crappy cell phone shots during the machining process. lol
Old 08-14-2015, 12:52 PM   #1437
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
Finally, some closure!
JourdanWithaU is offline   Reply With Quote
Old 08-16-2015, 12:33 AM   #1438
TS7XREX
Member#: 287450
2011 Impreza WRX
Damn.
TS7XREX is offline   Reply With Quote
Old 08-19-2015, 10:04 AM   #1439
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Upgraded my newer "CARB" compliant gas cans to the higher flowing "old" style.
Advantages:
  • No longer need to use a funnel to fill up my car
  • No longer have to hold down button the entire time it's filling
  • Empties in ~1/2 the time
Old 08-19-2015, 12:17 PM   #1440
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
Interesting accordion hose... Sounds like still a pain. I got a VP style can with a rather long and sturdy hose. I can flip the can vertical and rest the weight of the can on the hose.
Old 08-19-2015, 12:44 PM   #1441
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
NF brings the VP cans to the track. They work very well. I don't like where the vent is though. You can't really turn it completely upside down and have the vent open or else it just leaks out all over.
Only other issue with the VP ones is that they're too tall to fit easily in my trunk without laying them over. These fit perfectly side by side in the spare tire well.
The accordion hose on this one is much stiffer than it looks in pictures. It can bend a little, but it's very solid. Probably more stiff than the VP ones (although I bet it could be crushed more easily).
If I didn't already have these cans I would have just bought the VP ones. They're not cheap, but they're sturdy and work well. Since I already had these cans it was a cheap and easy upgrade.
Old 08-19-2015, 01:24 PM   #1442
bicycle_wreck
Member#: 226331
2012 WRX Hatch
Dirty Smurf
Probably going to pick up one of those filler necks. Saw one at O'Autovance or wherever and almost did the impulse buy thing.
The cans I have are both this twist and push locking thing that just blows off the end on a hot day and I spend half an hour putting it all back together.
bicycle_wreck is offline   Reply With Quote
Old 08-19-2015, 01:36 PM   #1443
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Yeah, all the spring loaded ones tend to break at one point or another. I had one that was completely broken and one that I had put back together a couple times.
This kit works great. Just make sure the inside is clean and dry before drilling the vent hole so that you can make sure to get all of the shavings out of the gas can before using it.
Old 08-20-2015, 09:46 AM   #1444
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
My block arrived! Here are some photos of it. IAG closed deck and 1/2" headstuds.
*Studs and plugs are loosely installed by hand for photos.
Old 08-20-2015, 09:50 AM   #1445
besthaticouldo
Member#: 279660
sweet baby jesus that's nice.
besthaticouldo is offline   Reply With Quote
Old 08-20-2015, 10:31 AM   #1446
TS7XREX
Member#: 287450
2011 Impreza WRX
Is there a streen driven record for et or mph? If so is that what you're going for?
Old 08-20-2015, 10:57 AM   #1447
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I think there have been "street legal" Subaru's in the 8's. I'm not really chasing any kind of records in particular.
Old 08-20-2015, 05:19 PM   #1448
bicycle_wreck
Member#: 226331
2012 WRX Hatch
Dirty Smurf
Great photos of the closed deck. Hope you have it all back together and purring soon. Thanks for sharing.
Old 08-21-2015, 09:38 AM   #1449
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Selling my old cams if anyone is interested:
http://forums.nasioc.com/forums/show....php?t=2743286
Old 08-21-2015, 09:38 AM   #1450
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Double Post.
