Welcome to the North American Subaru Impreza Owners Club Monday February 24, 2020
Old 09-03-2015, 10:56 PM   #1451
subbi7
Member#: 241967
02 wrx
Any update ?
subbi7 is offline   Reply With Quote
Old 09-04-2015, 09:38 AM   #1452
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Originally Posted by subbi7 View Post
Any update ?
Nope. Motor is still at the shop.
Old 09-10-2015, 11:50 PM   #1453
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
After sitting in my garage like this for a few weeks things have started to progress...
Motor assembly was completed by NF yesterday. I spent the day/night installing it and then spent this morning troubleshooting some issues (boost leaks at BOV, FMIC piping, TGV, and injector, and a leaking fuel line inside the tank) and then got it onto the dyno at MAP this afternoon (tuned by Nuke).
I also picked up a DSS CF driveshaft and installed that after the tuning.
Old 09-10-2015, 11:54 PM   #1454
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Here are some photos from the dyno tuning today. I will have the dyno plots and videos later.
Old 09-11-2015, 09:19 AM   #1455
GJL44
Member#: 248748
2011 STi SWP
04 WRB WRX wagon (RIP)
Sorry if this seems noobish of me, but any thoughts of doing a reverse manifold?
GJL44 is offline   Reply With Quote
Old 09-11-2015, 05:11 PM   #1456
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Made a peak of 834WHP / 677WTQ at the dyno yesterday. NF built and tuned. IAG closed deck block. PTE 6766 turbo. Ended up turning it down to around 750WHP due to fuel limitations.
Packed up for Proving Grounds.
9.5 @ 150mph
First pass. Street tires. Driven 2hrs to the track with a passenger, full set of slicks in the backseat, and a trunk full of tools and gas cans.
Big thanks to everyone at NF Performance for all the help, motor build, tuning, and everything else along the way.
Thanks to IAG Performance for building a closed deck block with 1/2" headstuds that can handle some abuse.
Old 09-11-2015, 06:35 PM   #1457
Ultimateone
Member#: 48025
17 BMW M2
AW
Wow, that is moving dude! Congrats
Ultimateone is offline   Reply With Quote
Old 09-11-2015, 10:58 PM   #1458
djuss21
Member#: 214715
2010 Gt500
2012 Swp Wrx e85 (Sold)
Damn!
djuss21 is offline   Reply With Quote
Old 09-11-2015, 11:49 PM   #1459
thrasher
Member#: 40579
2002 WRX Stage 2+
Tuned by IA Performance
Now that's an update. Mother of god!!!
thrasher is offline   Reply With Quote
Old 09-12-2015, 01:35 AM   #1460
redprzdent311
Member#: 201377
2010 Forester
Chamilia Red Pearl
Dear lawd.
redprzdent311 is offline   Reply With Quote
Old 09-12-2015, 10:14 AM   #1461
thrasher
Member#: 40579
2002 WRX Stage 2+
Next up...sequential gearbox. Doo eeet!! Haha
Old 09-14-2015, 12:26 PM   #1462
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Here's the full update (with videos) from last week:
There aren't a lot of threads in this section, so I figured that creating a new one for my new setup wouldn't hurt. Since the last time at the dyno/track (666WHP and 9.9-10.1 @ 139-140mph) I have switched to an IAG closed deck 2.5L motor with IAG 1/2" headstuds. Rotating assembly is similar spec to the last motor. Cams upgraded from GSC S1 (268) to Kelford 282's. The turbo went from a PTE 6266 to a PTE 6766.
Wednesday:
As of Wednesday of last week the motor was still being assembled. NF Performance did the assembly and got it done and back to me Wednesday afternoon. I spent the evening/night installing it into my car and trying to troubleshoot any major issues. Then I did cam break in and changed the oil.
Thursday:
Thursday I drove it about 10 miles to the shop and we continued to troubleshoot. We fixed various boost leaks and then found that fuel pressure wouldn't go above 20psi. We did a lot of troubleshooting before determining it was a torn hose in the fuel tank. That was replaced and fuel pressure was back to normal.
Just to be safe, the car was trailered to the dyno that afternoon. It was strapped down and on the first pull (wastegate pressure of 35psi) it made just shy of 700WHP. A few more 35psi pulls were all 700WHP +/- 10WHP or so. Then we cranked the boost up and made over 800WHP at 50psi+. Fuel couldn't keep up so the final tune was back down around 40psi and made about 750WHP. I threw on the DSS CF driveshaft that night.
Friday:
Friday morning I loaded the car up with tools, clothes, 10 gallons of E85 and my set of Hoosier slicks in the backseat. My brother and I drove 2 hours up to BIR for the Proving Grounds event. First pass was on the street tires (Mickey Thompson ET Street Radials that I drove up on) and no boost off the line, and I did a 9.5 @ 150mph!
Saturday:
Saturday morning we put the slicks on and then loaded a drag map that would make 18psi on the 2 step. Then I watched one of NF's other cars break the output shaft on the first launch (on slicks and boost on the line). I ended up taking my slicks back off and reloading the no boost launch map.
I did 2 more passes. The first one bogged the launch and then hit the rev limiter before the finish line (trying to hold out 4th gear). The second pass caused my velocity stack to fall off on the 1-2 shift and then the coupler got sucked into the turbo (and destroyed it) in the middle of 4th gear.
Event: MAPerformance Proving Grounds
Ambient Temp: ~60F
Elevation: ~1,200ft (DA: 1,335ft)
Weather: Sunny and Clear
Tires: 26" Mickey Thompson ET Street Radials on 15x7" +35 Rota Slipstream Wheels
Car: 2002 WRX Sedan
Tuner: Nuke @ NF Performance
Transmission: 2012 STI 6 Speed
1/4 Mile ET: 9.51s
1/4 Mile Trap: 150.5mph
60': 1.56s
Target Boost: 43psi
Target AFR: 11's
Fuel: E85
9.5s @ 150mph @ 43psi on E85
Full Build Thread:
http://forums.nasioc.com/forums/show....php?t=2528768
Engine:
  • OEM 2.5L Case with IAG Closed Deck Conversion
  • IAG 1/2" Headstuds
  • OEM 2012 STI Heads (running Non-AVCS)
  • OEM Subaru Crank
  • JE Pro Seal Head Gaskets
  • JE 99.75mm Pistons
  • Manley Turbo Tuff I Beam Rods
  • King Rod and Main Bearings
  • Kelford 199-L (282) Camshafts
  • GSC Beehive Springs w/Retainers
  • GSC Valve Seals
  • Aluminati Solid Billet Motor Mounts
Intake/Exhaust/Fuel:
  • Precision 6766 Turbo
  • KillerB EL Header
  • Fobia Fab Modified for FogLight Mount
  • Fobia Fab Fender Exhaust Dump
  • Fobia Fab Oil Sump
  • TurboWerx Exa Pump Mini Oil Scavenge Pump
  • Custom AN Oil Return Lines/Fittings
  • Treadstone FMIC
  • TurboSmart 40mm HP (35psi) EWG
  • TurboSmart Race Port BOV
  • TurboSmart FPR 1200
  • Walbro 465 Fuel Pump
  • DW 300 Fuel Pump
  • Boost A Pump
  • ID2000cc Injectors
  • IAG Fuel Rails and Lines
  • Treadstone 4" Velocity Stack
Drivetrain/Transmission
  • OEM 2012 STI 6MT
  • DSS CF Driveshaft
  • DSS 800HP Rear Axles
  • OEM STI R180 Rear Diff
  • OEM 2004 STI Front Axles
  • Anarchy Motive Shift Knob
  • Kartboy Short Shifter
  • Kartboy Front Shifter Bushings
  • Karboy Rear Shifter Bushings
  • Aluminati Solid Billet Tranny Mount
  • Aluminati Solid Billet Pitch Stop Mount
  • ACT HD Pressure Plate
  • ACT 4 Puck Unsprung Disk
Suspension/Wheels:
  • 15x7" +35 Rota Slipstream Wheels
  • 26" Mickey Thompson ET Street Radial Tires
  • 02 WRX Struts
  • Eibach Pro Kit Springs
Interior/Electronics:
  • MapDCCD Differential Controller
  • MapDCCD Wheel Speed Signal Processor
  • ProSport EVO Boost Gauge
  • ProSport EVO Oil Pressure Gauge
  • AEM Wideband O2 Gauge
  • Odyssey Slim Battery
Exterior:
  • Seibon CF RS-Style Flat Hood
  • OEM Fog Light Covers
  • Impreza Wingless Trunk
Old 09-14-2015, 12:35 PM   #1463
ocdpvw
Member#: 282232
2012 TP Stage 3
Bagged SWP & Bagged DGM
Your cars are always insane! I love it.
ocdpvw is offline   Reply With Quote
Old 09-14-2015, 12:36 PM   #1464
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Thanks! Your new exhaust looks great!
Old 09-14-2015, 12:41 PM   #1465
ocdpvw
Member#: 282232
2012 TP Stage 3
Thanks! I would love to hear it on something making the power of your car. My little 300whp doesn't even compare to what you going on
Old 09-15-2015, 01:22 PM   #1466
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Here's the video of the motor install:
Old 09-16-2015, 12:47 PM   #1467
1VIPWRX
Member#: 107554
yellow
keep it up man..you definitely have a fan
1VIPWRX is offline   Reply With Quote
Old 09-16-2015, 03:48 PM   #1468
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Thanks!
Old 09-17-2015, 03:29 AM   #1469
Josh LaCroix
Member#: 329353
Grabber Blue
Sorry your turbo ate it right after getting up and running. Was it something preventable? Or no more velocity stack?
Josh LaCroix is offline   Reply With Quote
Old 09-17-2015, 12:02 PM   #1470
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
The velocity stack fell off and then the turbo sucked in the silicone coupler. Completely preventable by using clamps on the coupler and velocity stack. I just had it slipped on because I had been switching it back and forth to go to lunch, etc.
Old 09-17-2015, 03:54 PM   #1471
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Old Build List:
Engine:
  • OEM 2012 STI 2.5L Case
  • OEM STI Nitrided Crank
  • OEM STI 11mm Oil Pump
  • OEM STI Gasket Set
  • CP 99.75mm 8.2:1 Pistons
  • ACL Rod and Main Bearings
  • ARP Head Studs
  • GSC S1 Camshafts
  • GSC Valve Seals
  • Torque Solution Motor Mounts
  • Precision 6266 Turbo
  • KillerB EL Header
  • Treadstone FMIC
  • TurboSmart 40mm EWG
  • GrimmSpeed MBC
  • 04 STI Fuel Pump Hanger
  • Walbro 465 Fuel Pump (Hardwired)
  • OEM 2012 STI 6MT
  • OEM 2004 STI Driveshaft
  • Torque Solution Tranny Mount
  • Torque Solution Pitch Stop Mount
Suspension/Wheels:
  • OEM 2002 WRX Wheels (Winter)
  • 205/60R16 Blizzak WS70 Tires (Winter)
  • 17x9" +45 Enkei RPF1 Wheels (Summer)
  • 255/40R17 Federal 595 RS-R Tires (Summer)
  • 15x7" +35 Rota Slipstream Wheels (Track)
  • 26x8.5" Hoosier Slicks (Track)
  • 02 WRX Struts
Exterior:
  • RS Flat Hood
  • Removed Rear Wing
New Build List:
Engine:
  • IAG Closed Deck 2.5L Case
  • IAG 1/2" Head Studs
  • OEM Subaru Crank
  • OEM 2012 STI Heads (Running Non-AVCS)
  • GSC Valve Seals
  • KillerB EL Header
  • Treadstone FMIC
  • TurboSmart 40mm HP EWG
  • GrimmSpeed MBC
  • DW300 Fuel Pump
  • OEM 2012 STI 6MT
  • DSS CF Driveshaft
Suspension/Wheels:
  • 15x7" +35 Rota Slipstream Wheels (Summer)
  • 235/60R15 Mickey Thompson ET Street Radial Tires (Summer)
  • 02 WRX Struts
Exterior:
  • RS Flat Hood
  • Removed Rear Wing
Old 09-18-2015, 04:19 AM   #1472
Riz98
Member#: 329344
2006 Sti
What are your plans for the turbo?
Riz98 is offline   Reply With Quote
Old 09-18-2015, 09:43 AM   #1473
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Precision just happened to have a refurbished 6766 (journal bearing / v-band) for sale on their site for well below retail so I picked that up. It arrived yesterday and I put it on the car for a couple quick test runs. Still seems to be making good power so I am optimistic that the motor is healthy.
The refurb from PTE looks great. Everything looks to have been media blasted and looks nearly like new. A couple cosmetic marks in the compressor cover, but that's it. The damaged turbo will be sent back to PTE for rebuild sometime in the near future and then sold. Let me know if you're interested!
Old 09-18-2015, 01:27 PM   #1474
snkp360
Member#: 276780
2016 STi Limited
Dark Grey Metallic
All I wonder is where the hell can you find strait roads to hit 120+ on a consistent basis and have you ever been pulled over filing one of your videos....
Hell of a car Ben and its been awesome to see how its progressed
snkp360 is offline   Reply With Quote
Old 09-18-2015, 01:30 PM   #1475
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
Considering he's pulling 150 at the track. The road doesn't have to be very long.
There's plenty of places in the bay.
JourdanWithaU is offline   Reply With Quote
