10-28-2015, 05:36 PM | #251 |
Member#: 428085
Vehicle:2016 WRX Black |
^^^ Looks pretty complete. I will mention that instead of buying/assembling your own voltage regulator for the backup camera, several of us have used THIS with excellent results.
The 28-pin harness I used is HERE.
10-31-2015, 07:24 PM | #252 |
Member#: 428085
Anyone have the wiring schematic for connecting a Maestro SW module to a 2016 WRX (28-pin connector)?
10-31-2015, 08:27 PM | #253 |
Member#: 14900
Vehicle:2016 WRX Limited LBP |
Has anyone found a replacement bezel to fit that isn't the faux carbon fiber? I swapped out the trim pieces for the brushed silver crosstrek pieces immediately and don't want to add any back. I know I could wrap or paint it, but if there's an oem solution that'd be awesome.
11-01-2015, 08:07 AM | #254 | ||
Member#: 431964
I do know they use the middle 3 wires on the connector. Pins 21, 22, 23. SW's black/white goes to yellow. SW's Purple/red goes to brown/black SW's pink/red goes to blue/yellow. you'll need to contact pdh12v for any software downloads. Quote:
11-02-2015, 01:52 PM | #255 | |
Member#: 432497
Vehicle:18 Sti ISM |
Red - Accessory (same as new radio) Black- Ground (same as new radio) SW COLOR - VEHICLE COLOR Black/White - yellow/white Pink/Red - Blue/Yellow Purple/Red - Brown/Black IF YOU WANT ACCESS TO THE FLASH, you need to PM me your username on the website, and I can grant you access to the download, it is done however we are waiting on an official release, which will need to have an install manual drawn up and it takes some time. All of the info is here on this thread for the install, and it has been working 100% for me. |
11-02-2015, 07:12 PM | #256 |
Member#: 14900
@phd12v is there an updated firmware for the rr as well as the sw? I'm debating which to get. If there is, what functions beyond the sw does it support (OBDII, I assume, but any other integration?
11-02-2015, 11:06 PM | #257 |
Member#: 432497
it is live on the site, albeit a better photo could have been used without my keys in the background, lol
RR gives you more choices for the 22 functions you CAN program.... wiring is the same as the SW except the RR has a Gray/red for ACC and yellow for constant and black for ground. Also I still need to approve the flash on the RR. Kenwood and Alpine will give you gauges with an RR and a compatible radio. Other than that that is it. |
11-03-2015, 11:56 AM | #258 | |
Member#: 14900
m not shocked that it doesn't. |
11-03-2015, 01:45 PM | #259 |
Member#: 432497
it doesn't at this time, we might be able to do something at some point, but it is low on the totem pole at the moment, maybe next year when I have my vehicle at the mothership....but until then it will be gauges and steering wheel controls for now.
I did look at the wiring and take some measurements on the mic stuff and I did some background info on the reverse camera input... the RR can output a 6 volt signal....so there are a few things we could do extra with it, but right now it is not that high in the grand scheme of things... ill work on them though. |
11-07-2015, 01:55 PM | #260 |
Member#: 433786
pictures
Hey guys, just picked up a 16 wrx and as you all have pointed out the stock 6.2" Starlink system is an absolute joke. I traded in a 2012 Sonata with just a basic non-screen dash that was light years ahead of this thing it terms of sound quality and usability.... its kind of a joke they can expect us to pay close to $30k for these cars with this audio system, but I am just beating a dead horse at this point.
two things, first does anyone have any pictures of their aftermarket HU installed? I want to see what that looks like, and second does anyone have a total price payed to install a new system? after putting a lot of money down on the car I dont feel like spending more, but I am so disappointed in this stock system I might have to. |
11-09-2015, 04:04 PM | #261 | |
Member#: 432497
I found the original radio IDEA was good, but poorly implemented and has a severe lack of POWER. I also have a audiocontrol LC6i here just in case I do go back to using it, so I can go all outboard amplification...cause that's the only way it will sound decent..... but you will need a processor of some sort also, as the factory radio has a lot of nasty built in eq curves..... all in all I did the math, and going the aftermarket radio route ended up being the better value. Just putting one in you will increase the volume two fold, and the speakers don't sound that terrible either. |
11-09-2015, 04:28 PM | #262 | |
Member#: 429584
Vehicle:2016 WRX (base) WR Blue |
11-09-2015, 11:19 PM | #263 |
Member#: 432497
tuning the sound properly may ne different for you versus me,for a normal person that wants to increase the volume and add an amp and use the built in eq it can be fine.... if you want to do it the best way you will need an outboard processor to clean up the factory headunit signal....there are a few different ways to do it. paying 600 dollars for a processor to keep the factory radio?? not really interested in that (IMO) I would rather use that money towards having an in dash that works to my specs since it is the "heart" of the system.
11-10-2015, 10:18 AM | #264 |
Member#: 332561
Vehicle:2015 GTI Autobahn White |
it depends on how much you care about audio. Just changing all the speakers and amping them on the stock radio makes a huge difference to me. I'm not an audio guru anymore. Just wanted to be able to listen to it at level 15 and hear it. Mine sounds good and i spent less than $500 and also soundproofed all 4 doors. I may add a small sub, but still I am way less than what it would have cost me to do the headunit and everything else.
11-11-2015, 10:40 AM | #265 | |
Member#: 431964
I think I have $300 in just accessories to get the HU to fit and work with OEM integration. It's absurd. |
11-11-2015, 01:38 PM | #266 | |
Member#: 433786
What did you use for sound proofing the doors? |
11-11-2015, 01:55 PM | #267 |
Member#: 332561
box of stinger roadmat on amazon for $99 did all four doors. I had some foam tiles in my garage and placed those where it made sense too.
I think a LC6i would work well, i used cheap $10 Locs, but the LC6i is on my list if I get a sub. |
11-12-2015, 08:26 PM | #268 |
Member#: 431395
Vehicle:2016 WRX Metallic Gray |
Does anyone know if the CV641UL deck on the 2016 WRX has a remote wire?
11-13-2015, 08:57 AM | #269 |
Member#: 332561
11-13-2015, 03:33 PM | #270 |
Member#: 425400
I think this was asked before, but is anyone planning on doing a parts list and a step by step for the HU swap? I'm dying to get at it, but am way too novice to do so without learning aides!
11-13-2015, 06:20 PM | #271 | |
Member#: 431964
I already did a parts list post #250, so did others(although there was wrong info in beginning on their part with USB adapters). Please go through the thread where you'll also find other valuable install info! and FWIW, i've been through every post in this thread...a few times, so please take the time you expect others to write you a personal install post and read through this thread a bit more. add: If you are a novice, you may want to just bring your car to a shop. This car ranks up there with most difficult radio install I have ever done! I've done hundreds btw and am very savvy electrically(Electronics degree..haha) Last edited by Subisnob; 11-13-2015 at 06:26 PM. |
11-13-2015, 07:03 PM | #272 |
Member#: 429584
Wow that carbon fiber bezel looks so... aftermarket! Especially with the black adapter bezel between the head unit and the actual carbon fiber bezel. Ugh... Makes my eyes bleed
I would love an aftermarket HU but it needs to look stock. It is incredible why there are no aftermarket products that actually look stock. </rant> |
11-13-2015, 07:49 PM | #273 | |
Member#: 431964
I agreeabout the mounting kit looking cheap. I have already planned on molding/sanding and spraying mine to match my radio...gloss black unfortunately.lol |
11-13-2015, 07:58 PM | #274 |
Member#: 429584
Yeah, now that I think of it, that's probably that mounting kit's fault not the carbon fiber bezel. It would be cool though if it was all one piece without adapter.
11-13-2015, 10:35 PM | #275 |
Member#: 432497
the gloss black starlink setup looked way out of place to me... actually my 15 piece looks more uniform due to the carbon fiber inserts on dash, my opinion though
