Welcome to the North American Subaru Impreza Owners Club Monday December 16, 2019
Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.0L Turbo Powertrain
View Poll Results: Which do you prefer....?
Artistic Weld Bead 21 60.00%
Plain 14 40.00%
Voters: 35. You may not vote on this poll
Old 03-18-2016, 05:12 PM   #1
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Default FA20 Pulley Cover Poll
OK fellow NASIOCers we're looking for feedback on what you'd like on a product of ours... for you.
The product is a stainless steel Pulley Cover for the Turbo FA engine in the 2015+ WRX.
Designed, Manufactured and Craftsmanship added right here in the USA!
Let us know your preference and we'll make it!!
Old 03-18-2016, 05:19 PM   #2
Wireeater
Member#: 76503
2016 Mustang GT
I like the plain as much as I enjoy nice weld work. But do you know... I've broken 2 of these that was from PW... I have no idea why. They sent a replacement after the first broke. I didn't bother letting them know after the second one broke as I feel it must be something up with my mounts. It keeps breaking where you bolt it to the altenator. Any idea what would cause this? Before I buy anything else I need to figure it out!
Wireeater is offline   Reply With Quote
Old 03-18-2016, 05:34 PM   #3
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Originally Posted by Wireeater View Post
I like the plane as much as I enjoy nice weld work. But do you know... I've broken 2 of these that was from PW... I have no idea why. They sent a replacement after the first broke. I didn't bother letting them know after the second one broke as I feel it must be something up with my mounts. It keeps breaking where you bolt it to the starter. Any idea what would cause this? Before I buy anything else I need to figure it out!
Could be any number of reasons; materials, design, bad batch how it's manufactured, etc...?
This part is pretty robust and no issues so far
Old 03-18-2016, 07:45 PM   #4
scotte30m3
Member#: 409636
2015 WRX
Is there a reason you didn't cover the whole top part of the intake manifold back to the intercooler?
scotte30m3 is offline   Reply With Quote
Old 03-18-2016, 08:05 PM   #5
dfoy01
Member#: 315002
16 WRX
CPW
let it be offered in black and I'll order one
dfoy01 is offline   Reply With Quote
Old 03-18-2016, 08:11 PM   #6
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
I like both.
Bishop is offline   Reply With Quote
Old 03-18-2016, 10:12 PM   #7
JeffWRX16
Member#: 429261
2016 WRX
Metallic SIlver
Not crazy about it being so small. I wish it would cover the ugly plastic intake manifold to be honest. Torque solution has one that covers quite a bit, but not the manifold. But everyone's opinion will be different.
JeffWRX16 is offline   Reply With Quote
Old 03-18-2016, 10:42 PM   #8
SeeeeeYa
Member#: 129681
'19 Imp Ltd Wagon
CWP
First, stock is perfect. Perfectly engineered, that is.
Second, anyone who removes their engine cover, unless they've gone FMIC, is ill-informed and stupid. Even the STi and WRX that had no engine cover had ductwork engineered correctly for the TMIC. But to just ditch the '15+ engine cover, and not make similar ducting solutions? Stupid.
So, while I have always held KillerB engineering in the highest regard?... to cater to this level of "mod" is out of context with that image.
That said, were I somehow to want such a "protective" cover for the belts... and had made such TMIC ducting provisions, it would be different from the ones shown. There is no red like the STi, only black plastic in the WRX. Maybe if the owner has other KillerB products and wants to advertise that... a cover with that name cut out and offered in anodized black or SS.
SeeeeeYa is offline   Reply With Quote
Old 03-18-2016, 11:19 PM   #9
mishapopa
Member#: 393629
I removed mine, I honestly don't think it serves a purpose what-so-ever.
mishapopa is offline   Reply With Quote
Old 03-18-2016, 11:44 PM   #10
Ericthered545
Member#: 411430
2015 WRX
The engine cover definitely serves a purpose. It directs air into the TMIC. Without it air can and will go around the intercooler, which will reduce its cooling effectiveness.
We need new ductwork.
Ericthered545 is offline   Reply With Quote
Old 03-19-2016, 12:05 AM   #11
Wireeater
Member#: 76503
2016 Mustang GT
Unless you're running PW Verticooler (which requires removing the engine cover) ... As it replaces all the ducting and funnels directly into the core. I'm also sure on paper removing the engine cover will show changes but in actual real world observations.... You'd probably barely, if it all notice a difference....
Old 03-19-2016, 12:28 AM   #12
mishapopa
Member#: 393629
I could see it doing that if you drive with the hood open otherwise the hood scoop is what directs the air to the intercooler. The air will regardless go through the intercooler as below it is the lowest pressure drop.
Having the engine cover on probably increases performance as much as the weight of the cover itself decreases it. Also it's cold where I live.
It's just engine dress up.
Old 03-19-2016, 10:10 AM   #13
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Except they break after removing them X amount of times, lol. I've got through 2 so far. This is with be VERY careful during removal and even applying some light grease on the rubber grommets.
It definitely does. I would never remove it without providing another solution for air ducting.
^ This. Air follows the path of least resistance. So if you've removed your ducting, air will mostly go around the restriction (TMIC).
I really didn't want to leak this as it has too many other things in the image, but you can see there are lots of easy free options with the factory piece...
Old 03-19-2016, 10:12 AM   #14
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Everyone sees things differently. You see ugly plastic manifold. I see advanced engineering design and manufacturing being utilized.
Old 03-19-2016, 10:37 AM   #15
SeeeeeYa
Member#: 129681
'19 Imp Ltd Wagon
CWP
Thank you for that "leakage." Now you're talking.
And, it refines my opinion... make the new cover black, thus contextual, and it all makes sense.
Any question I may have momentarily had about KillerB... is no more. Just don't do that again withholding that is.
Old 03-19-2016, 11:22 AM   #16
Ericthered545
Member#: 411430
2015 WRX
Good idea. I might do something similar when my other tab breaks. Then I will need a pulley cover. I like the design with the welds but my only concern is that over time those weld spots will oxidize and look rusty?
Where'd you get that AOS? That looks different.
Old 03-19-2016, 03:14 PM   #17
joncole227
Member#: 420578
2015 WRX
dgm
The pw piece broke on me as well, the metal they choose is just too thin.
I like the general design of the piece but wish it covered things more
joncole227 is offline   Reply With Quote
Old 03-19-2016, 08:48 PM   #18
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
This thing? Yeah, don't tell anyone about this. Top Secret!!
Old 03-20-2016, 01:12 PM   #19
dr_wookiee
Member#: 144106
2015 WRX
Lightning Red
Any idea on when you'll be offering that aftercooler duct? I bought your charge pipe/aftercooler during your original group buy and don't care for using the factory engine cover with it.
I also think a black pulley cover to match a black aftercooler duct would look great!
dr_wookiee is offline   Reply With Quote
Old 03-20-2016, 01:21 PM   #20
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
^ The duct in that picture? That is a modified OEM engine cover
Old 03-20-2016, 01:31 PM   #21
dr_wookiee
Member#: 144106
2015 WRX
Lightning Red
Ha! I at first was thinking it might be, but it looks like metal in the pic. Is it fastened anywhere in front of the aftercooler? Any plans to make and sell one so we don't have to cut up our stock cover?
Old 03-20-2016, 08:09 PM   #22
ahughes
Member#: 396349
2015 wrx
Ice silver metallic
I personally liked the old design of the ones you made for the ej motor. I would like to see something like that. I have the Mishimoto tmic and had to remove my engine cover and would like to put something in that spot.
ahughes is offline   Reply With Quote
Old 03-20-2016, 08:48 PM   #23
rufus819
Member#: 202947
2015 WRX Limited ISM
275/310 PhatBotti tuned
I'd buy it, looks good to me! Of course i would wait to buy this until I get my Verticooler, which of course PW and grimmspeed make their own ducting to go with an aftermarket TMIC.
rufus819 is offline   Reply With Quote
Old 03-21-2016, 12:18 AM   #24
15WRXNoob
Member#: 394141
2015 WRX
Galaxy blue pearl
I like the small simple design. I have a front mount and have wanted something to cover just the pulleys. The torqued solutions pulley cover is to big for my taste.
15WRXNoob is offline   Reply With Quote
Old 03-21-2016, 08:36 AM   #25
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Nothing on the front. At first I thought about designing a clip or something, but with it trimmed down the two rear clips hold it in place just fine. Vertically it sits right on the front face of the core as it normally would. My point here is I don't know what adding any fastening would add to it? once the hood is closed it's squeezed between the engine and rubber seal anyway.
My guess is, with more aftermarket products coming on the market you will see used engine covers cheap... Very cheap... Especially ones with the front tabs busted that can be used to trim or modify.
I looked into a TMIC shroud/duct. To make a nice CF piece is really expensive. With metal/plastic it's still pricey for what it is. Retaining the stock engine cover reduced the cost of admission for our Aftercooler, which as many of you know, is already a very expensive piece. The other great thing about the factory shroud/duct, is that it works really well, plus free
