05-28-2016, 08:09 PM | #1 |
Member#: 254851
BAIC
Vehicle:2002 WRX wagon 5mt PSM |
How to fix a window switch
Edit: the photos work on the phone app but not on a PC. sorry I don’t know why. See post #23 for a way to view them on a computer.
How to fix a broken window switch. This is on my 02 WRX. The window would go down, but not up. Remove switch from door card. Use a flat hard tool to pry up the back of the switch plate Lift it up to expose the wire connection Press this button while pulling to disconnect Carefully pry apart the black tabs to remove the cover (this step is not necessary but it does give you more room). Then pry apart the white tabs. CAREFUL, THERE ARE SMALL PARTS THAT MAY GO FLYING!!!! Do this on a work table so you don't loose anything. Yes the switches are made by Nissan. Edit: Cougar4's good bag tip is in post 3. These are all the parts. Here is the most likely reason for the failure. Those little "smudges" on the plates and fulcrum. Clean them up. Like this (the fulcrums were not done yet).
05-28-2016, 08:09 PM | #2 |
Member#: 254851
BAIC
Part 2.
These are the rockers. Clean them up too. I also bent them ever so slightly, so they make better contact. DON'T BEND TOO MUCH!!! Just a hair. You do NOT want them to always be in contact. Like this. Install the rockers. They should rock like a seesaw. Install the springs into the switch cap. Tip, put a dab of grease on the end of the spring that goes into the cap. It helps during reassembly. I also stretched them just a hair, to increase pressure. Ball bearings go here. Here's the tricky part. Put the switch cap on top of the switch. Carefully put the toggle plate on top and click it all together. This might take several tries as they don't always want to line up. Do this in the upright position. I put the white switch part on the table and then put the black part on top, then pushed down. Like this. Install switch onto the door card in the reverse order you removed it. I hope this helps. Last edited by Bikelok; 03-29-2017 at 12:05 AM. |
05-28-2016, 09:15 PM | #3 |
Member#: 53443
Vehicle:2001 LL Bean Outback Winestone |
I'll add one more suggestion to this nice post. If you take the switch apart, do it while you have it inside a clear plastic bag. If parts do go flying at least you should be able to keep them in the bag and not have to hunt them down.
05-28-2016, 11:28 PM | #4 | |
Member#: 254851
BAIC
Thank you and that's a great tip! |
09-28-2016, 01:51 PM | #5 |
Member#: 85435
Vehicle:02 Impreza RS 2.5L Silver |
This was very helpful, and fixed my passenger side window switch from randomly working on my 02 Impreza. Thanks!
10-07-2016, 12:52 PM | #6 |
Member#: 456023
Vehicle:2003 STi Blue |
These things are great to know, I've had problems like this with my other car; will try this out!
10-08-2016, 09:22 AM | #7 |
Member#: 198067
Tri-State
Vehicle:2009 IMPREZA 2.5i 4d WHITE Premium |
Very nice post.
In the past I would spray RadioShack Contact Cleaner into the switch. I now use CRC QD Electronic Cleaner to clean electronic contacts. |
11-01-2016, 08:40 PM | #8 | |
Member#: 254851
BAIC
Thank you. I've used cleaners before and they do work, but sometimes they just don't reach all the right places. |
11-14-2016, 07:46 PM | #9 |
Member#: 458020
Vehicle:2002 wrx wagon white |
I'll be trying this tomorrow
Passenger window only rolls up or down from the driver's side. I'll let you guys know how it goes. Thanks for the step by step instructions.
09-21-2017, 01:34 PM | #10 |
Member#: 30669
Tri-State
Vehicle:1998 Legacy 2.5GT Silver Sleeper BK, 5MT |
Nice write up and good info.
Additional thoughts. An ink eraser can be used for the contact cleaning, small enough to get places and not too abrasive. White lithium lube or Vaseline can be used for the "grease" along with other substitutes. Good comment by Cougar4 on the bag idea. |
03-14-2018, 10:33 PM | #11 |
Member#: 479479
NWIC
Vehicle:2003 WRX Platinum Silver |
thank you
This just worked on my passenger side window on a 2003 WRX Wagon, fixed it! now to do the drivers side master switch for the rear passenger window. Thank you!!
04-02-2018, 09:21 AM | #12 |
Member#: 483496
thanks!
04-02-2018, 09:52 AM | #13 |
Member#: 30669
Tri-State
I highly doubt this is your issue...... https://forums.nasioc.com/forums/sho....php?t=2871295, you lost everything likely at once.
I think you have a fuse issue. |
04-11-2018, 10:47 PM | #14 |
Member#: 484480
NWIC
Vehicle:2002 Impreza WRX Sadona Red |
Hi new here, I just got a 2002 WRX and the driver side door window isn't moving at all, I believe the switch is busted but not the motor. The previous owner told me that he replaced the motor not too long ago and it stopped working again recently. I attempted to follow your guide but got stuck at the beginning! I attempted to remove the switch panel like you did in the picture but the sucker wouldn't budge! Any tips?
04-12-2018, 09:26 AM | #15 | |
Member#: 30669
Tri-State
02-24-2019, 04:04 PM | #16 |
Member#: 83417
NWIC
Vehicle:2003 WRX Black Swirlomatic |
Thank you Bikelok!!!
THANK YOU! You're a lifesaver! $120+ for drivers side switch panel and 3x $40+ for the door switches SAVED. |
03-10-2019, 10:25 PM | #17 |
Member#: 385360
Vehicle:2014 Impreza WRX Plasma Blue |
Very good write up had to do this to my wife’s 2000 outback.
04-29-2019, 12:51 PM | #18 |
Member#: 450507
NWIC
Vehicle:02 Subaru Wrx Platinum Silver Metallic. |
02 wrx
Just fixed my passenger rear switch with this method, write up was very good thank you Bikelok
05-03-2019, 08:38 PM | #19 |
Member#: 254851
BAIC
I’m glad this post has helped.
08-23-2021, 05:23 PM | #20 |
Member#: 526220
Hi I cant seem to get hold of any of these pictures, this is exactly the walkthrough i was needing and after trawling the rest if the net to find another "how to" nothing even comes close to this!!!! Please help me I will be eternally greatful, karma works wonders in life dont forget. THANK YOU.
08-23-2021, 06:29 PM | #21 |
Member#: 526220
sorry seem to have doubled up on this message.. nooob alert
09-08-2021, 11:43 PM | #22 | |
Member#: 254851
BAIC
The photos are working on my mobile app, sorry I don’t know why you’re having problems. |
09-12-2021, 01:52 AM | #23 |
Member#: 254851
BAIC
You can try this for the pictures “If you click the pic links to imgur, all you have to do is remove the "http://dereferer.org/?" from in front of the "https://imgur.com" part and you can view the pics.” |
