Welcome to the North American Subaru Impreza Owners Club Thursday September 24, 2020
Old 06-29-2016, 05:11 PM   #1
nate_fisher
Member#: 270482
2011 turbotek fxt
[email protected] 4eat xt record?
Default Show me your Fp green htz thoughts!
Thinking about upgrading from my td06sl2 20g to a Fp green htz and just wanted to see who was running one and what you think. I will also have to upgrade my id1000 as I will be running e85 and they already maxed. But want to see if it's worth it or if I shouldn't bother.
nate_fisher is offline   Reply With Quote
Old 06-30-2016, 01:35 PM   #2
nysti06
Member#: 261347
2006 STI
supporting mods? motor, intercooler, fuel pump?
nysti06 is offline   Reply With Quote
Old 06-30-2016, 02:55 PM   #3
nate_fisher
Member#: 270482
2011 turbotek fxt
Built motor, fmic, aem 320 e85 and tomei fpr yada yada.
Old 07-02-2016, 03:46 AM   #4
subaru_gc8
Member#: 29292
2004 WRX wagon
I think youre going to have to get bigger than 1000 for that size turbo
Old 07-02-2016, 07:42 AM   #5
nate_fisher
Member#: 270482
2011 turbotek fxt
I stated that I will be upgrading my id1000 most likely to id1300 or maybe 1700 depending how they idle on pump gas.
Any one have any feedback that actually run this turbo?
Old 07-02-2016, 08:56 AM   #6
everkain
Member#: 84150
2013 WRX Hatchback
I've been looking for some results too. I had the OG green on my 2005 and have been thinking of going this route on my 2013.
everkain is offline   Reply With Quote
Old 07-02-2016, 09:21 AM   #7
alakazoo22
Member#: 230730
05 FXT 18GXTR
black
On pump 93 is a 400whp ?
Build bloc, ets tmic, header, ewg etc etc..
alakazoo22 is offline   Reply With Quote
Old 07-02-2016, 11:38 AM   #8
nate_fisher
Member#: 270482
2011 turbotek fxt
I wont be running pump on a regular basis only in a emergency.
Old 07-02-2016, 12:16 PM   #9
alakazoo22
Member#: 230730
05 FXT 18GXTR
black
Its for me.. maybe replace my 18g xtr. .
Is a 400whp easy on pump or more 350 on a dynapack ?
Old 07-02-2016, 04:31 PM   #10
nate_fisher
Member#: 270482
2011 turbotek fxt
If the htz really flows 61lb/min then I don't see why it couldn't hit 400whp on 93 octaine.
Old 07-02-2016, 11:07 PM   #11
STIJim87
Member#: 363476
2013 STI Wagon
Ice Silver Metallic
My buddy made right under 500whp on DynoJet run E85. Stock motor, killer b header, Spearco TMIC...... And so on
STIJim87 is offline   Reply With Quote
Old 07-02-2016, 11:14 PM   #12
nate_fisher
Member#: 270482
2011 turbotek fxt
I just want to know how it spools compared to my 20g really. I would think with my supporting mods 500whp should be doable around 30 psi and some e85. I have a 4eat in my forester which really hurts spool but I would think this turbo should suite my needs. Now weither I should go iwg or 38mm ewg is the question.
Old 07-02-2016, 11:27 PM   #13
revlimit408
Member#: 407008
02 2.1 stroker
fpgreen htz v9 sti 6speed
I wanna see result too. building a 2.1 stroker with fp green htz on e85 , id1300 and dw300 pump. i found this fp green htz 30 psi on e85 http://forums.nasioc.com/forums/show....php?t=2771312
revlimit408 is offline   Reply With Quote
Old 07-03-2016, 07:53 AM   #14
alakazoo22
Member#: 230730
05 FXT 18GXTR
black
Why we dont have e85 here in Canada... every turbo shine with E
Old 07-03-2016, 04:37 PM   #15
nate_fisher
Member#: 270482
2011 turbotek fxt
That's to bad e85 is like anti knock juice.
Old 07-03-2016, 06:22 PM   #16
everkain
Member#: 84150
2013 WRX Hatchback
I'd like to see some dyno plots on 93. My OG green with the 49lb wheel made 340whp and 330tq with great spool. This new green has a 61lb wheel so I'm curious on the powerband on pump.
Old 07-04-2016, 12:26 PM   #17
MetalRex69
Member#: 367985
13 Wrx
I should have my car back this week stock motor, 84mm inlet, e85, ewg, El headers, etc etc. Not gonna push it hard but will post results
MetalRex69 is offline   Reply With Quote
Old 07-12-2016, 09:21 AM   #18
everkain
Member#: 84150
2013 WRX Hatchback
Any updates?
Old 07-12-2016, 04:25 PM   #19
nysti06
Member#: 261347
2006 STI
i went with ID 1300 on green hta 8cm w/e85
Old 07-12-2016, 04:54 PM   #20
MetalRex69
Member#: 367985
13 Wrx
Originally Posted by everkain View Post
Any updates?
Almost, should be done soon. There was some issues my car had I didn't know about and they had to deal with that but it should be done before the weekend!
Old 07-12-2016, 05:07 PM   #21
everkain
Member#: 84150
2013 WRX Hatchback
awesome. i can't wait to see the finished product. are you gonna be running just e85 or are you gonna have a pump tune as well?
Old 07-12-2016, 05:21 PM   #22
MetalRex69
Member#: 367985
13 Wrx
Just e85! I'm lucky enough to have a good 5 or 6 e85 stations in my area haha
Old 07-12-2016, 05:46 PM   #23
everkain
Member#: 84150
2013 WRX Hatchback
i wish. we have 2 or 3 in the whole state...
Old 07-14-2016, 02:23 PM   #24
bboygreddy
Member#: 107937
2005 WRX 18G OBP
@kamphotography_khoi
17.5 psi (track map) - 407/375
20 psi (everyday map) - 435/397
Could easily swap in bigger injectors as the turbo has plenty more room to breathe. At 20psi the injectors were at 90% IDC so the tuner felt safe there
05 WRX with built ej255 (forged piston and rods, heat treated crank) stock heads (DBC so no avcs, hence the slight lag)
FP Green HTZ with 84mm FAP
Modified stock injectors
Walboro 255 fuel pump
Tomei ELH
Catless turboback
TGV deletes
FMIC
bboygreddy is offline   Reply With Quote
Old 07-14-2016, 06:42 PM   #25
Boxer112
Member#: 78751
2017 Sti
ISM
That's a 450whp turbo easy.
Boxer112 is offline   Reply With Quote
