Welcome to the North American Subaru Impreza Owners Club Thursday December 5, 2019
Old 11-27-2016, 10:48 PM   #676
Harey
Member#: 270569
'15 Foz XT & GT86
Originally Posted by IfIWorePants View Post
Let me say I was hesitant with all the negative stories about the GTX3076R and it's mismatched housings, however the setup really blew past my expectations. I'm almost 100% confident the housing makes all the difference in efficiency.
IAG Stage 2 Tuff short block
Stock rebuilt heads
Spoolinator gtx3076R .82 housing
Perrin 3 inch inlet
IAG Fuel Rails
ID1300 injectors
DW300C fuel pump (hardwired)
IAG TGV deletes
Grimmspeed Top Mount (boost > power)
Speed density sensor mounted into TMIC
IAG AOS
Aeromotive FPR and Fuel lines
Gtspec II UEL headers
IAG uppipe w/ 38mm EWG
Pump Gas 93 saw 450whp / 450Wtq with ~20psi hitting at 3900rpms
E85 saw 550whp / 554wtq making 25psi @4200rpms
Are you referring to the increased efficiency of the 0.82 housing on the GTX3076? I agree, the 0.82 housing is the way to go on the GTX3076 or GTX3576 but the 0.63 on the GTX3067.
Harey is offline   Reply With Quote
Old 12-29-2016, 05:40 PM   #677
TeddyK
Member#: 404608
2010 WRX sedan
Here is the progress of my Spoolinator GTX3076r setup: Sent the turbo off to Turbo Re-source, and guess what it was within spec! OMG!!! Not really a surprise at all, my tuner was skeptical and/or profitable. No harm in my book...(sigh).
Anyways here some brief pics of the progress thus far:
[/url]
This is all being done at InFront Automotive in Auburn, Washington. They have been super short-handed with mechanics; I dropped it off a week before Thanksgiving and they are still not done as of this writing---though John, owner head mechanic/tuner knows this set back well in the terms of his business.
Why I am patient: John is a learned EFI tuner for 12+ years----and then he decided that he didn't know enough and got EFI University accredited.
Spoolinator Kit Install: They stated that they never had to grind so much damn metal off the block and transmission bell housing ever before. Afterwards, I saw the results and agreed that the turbo is super low fitting and in a very compact position. I applaud Killer B for its fitment to appease the TMIC crowd!
Spoolinator Kit Criticisms: Add 2 inches to the vertical aspect to the DP and it would fit my AWIC setup perfect.
I will try to post results of 2nd, 3rd, 4th gear results of boost from a low RPM.
Also, that Killer B DownPipe is sexy as hell! The pictures are not justice--Killer B
TeddyK is offline   Reply With Quote
Old 12-30-2016, 12:47 AM   #678
scottD
Member#: 94748
[/url]
I have really been going back and forth with this kit or just going rotated so I will be interested in your results. Did you buy your turbo from killer b?
I thought their turbo came with some machining done to the compressor cover to make it fit without a bunch of grinding?
Doesn't seem to be a lot of people running this kit. Hard to find any recent results of this setup.
scottD is offline   Reply With Quote
Old 12-30-2016, 09:10 AM   #679
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
hanks for posting the pics and update TeddyK. It's a tight squeeze for sure, but I think you'll be happy with the results
Old 12-30-2016, 10:02 AM   #680
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
It does. We grind the compressor cover, mill the inlet and add a weld bead. The bellhousing still needs some grinding to fit.
Looks like TeddyK is also running the compressor cover pointed up, which might have more interference since the volute is fatter where it's now nearest the block.
There are a handful of street guys running them, but mostly track guys from what I can tell. We don't sell a ton of them, but 4-5 per month means they are going somewhere.
Old 01-04-2017, 08:02 PM   #681
subaru_gc8
Member#: 29292
2004 WRX wagon
i just bought one so I will get you know how it turns out with my build
Old 01-17-2017, 02:24 PM   #682
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
^ Awesome!
Old 01-25-2017, 09:28 AM   #683
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
E-mail I just got this morning...
Hi Chris!
It's been along time coming, and I appreciate your patience. Our 2.1L ej205 with the holy header and spoolinator turbo Kit was finally dynoed today. We are only running 20psi, to give us some cushions for compliance with the rules in our series. As you also recall, the car has a turbo inlet restrictor, per the series rules.
The car made 400+wtq, and 320whp on only 20psi at peak torque, and tapering to less than 1 bar up top due to the turbo inlet restrictor. We're thrilled with the performance, and couldn't be happier with the header/turbo kit, and oiling products. We'll be documenting further online, after our race this weekend.
These are the best numbers I've ever seen on a car in our class.
Cheers,
Reid
Old 01-25-2017, 09:21 PM   #684
subaru_gc8
Member#: 29292
2004 WRX wagon
Wow good numbers, did eh say which turbo he's rnning
Old 01-26-2017, 07:41 AM   #685
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Gtx2860-r
Old 01-26-2017, 01:27 PM   #686
Lance123
Member#: 301663
2004 JDM WRX Wagon
Very nice. That's a lot of tq for a 2.1
What dyno?
Lance123 is offline   Reply With Quote
Old 01-27-2017, 07:41 AM   #687
kevmo11
Member#: 403684
2006 sti
cgm
Originally Posted by kevmo11 View Post
Had the car tuned yesterday Jr at shift fast motorsports!
Build
Iag stage 2 tough short block arp head studs
Stock heads and cams
Gtx 3576 spoolinator kit
Killer b holy header
Iag fuel rails, lines and dampners
Aeromotive fpr and stealth 340 in tank pump
Id 1000s
Ok guys I would really like to make more wheel torque on this build. will id2000s and a flex fuel kit and another jr tune get me over into the mid fours? The car has every bolt on as well.
kevmo11 is offline   Reply With Quote
Old 01-27-2017, 07:43 AM   #688
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Very true, and typical of rally car setups. Here's the plot. Keep in mind this is with running an inlet restrictor per class rules and the torque/hp values are not the same going up the side of the plot (making it look flatter).
Old 01-27-2017, 07:49 AM   #689
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Well I have a couple questions. What A/R turbine housing are you using? What did Jr say were your limiting factors?
It looks like the plot kept climbing to the end of the pull?
Old 01-27-2017, 09:52 AM   #690
kevmo11
Member#: 403684
2006 sti
cgm
.82 a/r, I'm not really sure as Jr's opinion but the shop told me the top mount and injectors were my limiting factors. I'm planning on keeping the process west top mount to keep the car looking stock. Maybe a ets top mount? I have the stock bypass valve as well, I'm not sure if that is limiting? The car has plenty of power up top but looking to get some low end torque!
Old 01-27-2017, 10:09 AM   #691
rexworx
Member#: 103232
GTX 3071R'd 11WRX
PPG,4.44,LSD,E85,6spdx3
Id say the GrimmSpeed tmic would be your best bet. Theres a thread floating around that compares it to the ets with a IAT sensor post core..
Id think a set of ID1300x or ID1700x injectors would be enough and maintain better idle etc then the ID2000cc. Especially with pump gas. Im not saying you cant get to idle well with the 2000's, The other options may do better though.
Man Ive really been waiting for one of these kits with a 3576r to put down the sauce...
rexworx is offline   Reply With Quote
Old 01-27-2017, 10:33 AM   #692
MazNJ
Member#: 388661
2013 WRX STI 5Dr
I think I posted it already?
3576... and 1700s idle terribly.
MazNJ is offline   Reply With Quote
Old 01-27-2017, 10:33 AM   #693
MazNJ
Member#: 388661
2013 WRX STI 5Dr
And Chris put down 50 atop of that I think. I'm sure he can repost his.
Old 01-27-2017, 10:37 AM   #694
kevmo11
Member#: 403684
2006 sti
cgm
That's e85 correct?
Old 01-27-2017, 10:45 AM   #695
MazNJ
Member#: 388661
2013 WRX STI 5Dr
Both are there. 540/511 on e85 and 448/395 on 93.
Old 01-27-2017, 10:51 AM   #696
A-man07
Member#: 271525
7/2 STi/WRX wagon
SWP/AW
Jr made 500 whp on a Spearco TMIC in past years so unless the PW TMIC is not as good as advertised, which is certainly possible, then it's something else limiting power.
Old 01-27-2017, 11:31 AM   #697
MazNJ
Member#: 388661
2013 WRX STI 5Dr
I'm running the Spearco TMIC and Jr thinks it's great.
Old 01-27-2017, 11:53 AM   #698
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
You have any head work on this engine?
TMIC and injectors should have that pronounced of an effect on spool. Depending on what boost level you're running the OEM BPV may be struggling to stay closed? I've never run an OEM one at those power levels. I've never used a PW TMIC. I can say my ETS unit gets really hot. For occasionally street flogging fine, but dyno pulls saw post intercooler temps hit the mid 170s.
Not used this unit but G-S makes good stuff.
We are using ID1300, and I really like them. Idles perfect and no issues. We run ID2000 on our bigger power setup and it idles good, not great, with a higher idle and cams.
Old 01-27-2017, 12:05 PM   #699
rexworx
Member#: 103232
GTX 3071R'd 11WRX
Yes, the BPV. I was going to mention it could be cracking open during boost onset. A nice TurboSmart Kompact BPV should do the trick.
Old 01-27-2017, 12:18 PM   #700
kevmo11
Member#: 403684
2006 sti
cgm
No head work, just refreshed them. Ok I will definitely be getting a different bpv!
