Welcome to the North American Subaru Impreza Owners Club Monday April 23, 2018
Old 02-28-2017, 01:49 PM   #19901
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
I heard that too. But I never got to the point of replacing mine.
Old 02-28-2017, 10:17 PM   #19902
rocsubie77
Member#: 446285
Originally Posted by SCNEot View Post
It is unlikely that the rings would fail, however you can check cylinder compression which would show a ring problem. If oil got into the cylinder it would be burning leaving a tell tale signs on the rings and traces of smoke.
Check your spark plugs. Bet the gaskets are leaking. Take valve covers off to access them!
rocsubie77 is offline   Reply With Quote
Old 03-01-2017, 09:06 AM   #19903
dirkwitty
Member#: 439907
'09 OBS 5MT
I also remember reading that the turbo HGs were less prone to fail than the OEM NA ones.
I got lucky with my '09 as my HGs aren't even seeping a little bit. Everything is dry down there as of 115k. On my '02 OBS I drove it for 30k+ with leaky HGs, just made sure the oil stayed above the L mark on the stick. Between consumption and leaking I lost about 1.5 qts per OCI. As long as the engine is lubricated and cooled, you can run slightly leaky gaskets for a while but should probably do them once you get a good quote, which should be well below 3300!!
dirkwitty is offline   Reply With Quote
Old 03-02-2017, 09:59 PM   #19904
rocsubie77
Member#: 446285
Originally Posted by 08impreza2.5isport View Post
Did someone say UEL?
https://www.youtube.com/watch?v=8y0EZkncpRg
Heres my setup, 06 WRX headers with OBX catback
Did you have room with the header clearing the oil filter?
Old 03-05-2017, 03:39 PM   #19905
DownhillSubie
Member#: 342985
Just installed 1" rear aluminum spacers to get rid of the saggy butt, anyone want photos and install tricks? I can do a mini write-up.
DownhillSubie is offline   Reply With Quote
Old 03-07-2017, 03:58 PM   #19906
chillwill007
Member#: 441189
2010 Impreza obs
2 tone silver
Sure that would be great
chillwill007 is offline   Reply With Quote
Old 03-08-2017, 05:17 PM   #19907
Josh.12
Member#: 464206
Default 08 2.5i
New to the site, 2008 Impreza outback sport
Josh.12 is offline   Reply With Quote
Old 03-11-2017, 09:37 AM   #19908
dirkwitty
Member#: 439907
'09 OBS 5MT
I like what you did with your taillights, somewhat unique doing the insides like that.
I did a little electrical work last weekend...
Makes the stock speakers sound 10x better but the Bluetooth is the real reason I wanted to upgrade. I also got sick of how my OEM one just said "Aux" all the time since I listened to Spotify on my phone.
Old 03-12-2017, 02:44 PM   #19909
jedest
Member#: 410358
2008 Impreza 2.5i
Gold
Nice wheels and perfect job blacking the chrome. What exhaust is that?
jedest is offline   Reply With Quote
Old 03-12-2017, 02:45 PM   #19910
jedest
Member#: 410358
2008 Impreza 2.5i
Gold
You selling your cd collection?
Old 03-12-2017, 03:08 PM   #19911
Josh.12
Member#: 464206
Thanks and it's a tsudo exhaust for a wrx
Old 03-13-2017, 10:51 AM   #19912
dirkwitty
Member#: 439907
'09 OBS 5MT
I'll be honest, I haven't owned a CD in probably close to 10 years.
My laptop doesn't even have a CD drive. Spotify FTW.
Nonetheless, it's a motorized display so the CD insert is behind the screen.
Old 03-13-2017, 10:21 PM   #19913
TheDiamondOreo
Member#: 459903
2007 Impreza 2.5i
Urban Gray Metallic
I've got an '07, not an '08 but still a 2.5i! 5-speed, had it since October. Loving it ever since!
TheDiamondOreo is offline   Reply With Quote
Old 03-14-2017, 07:53 PM   #19914
Josh.12
Member#: 464206
It's definitely gets me where I need and fun to drive with manual
Old 03-15-2017, 08:50 AM   #19915
Daddya2
Member#: 461795
Originally Posted by Bucky92 View Post
The shifter is alittle tight...not bad though...it actually feels just like my XT6 shifter..very tight and alittle "choppy"..now compaired to my 93 Imp LMAO..there were no bushings left so it was sloppy!
I think the more we drive them things will settle into place and smooth out... I just dont like that upper RPM hang that it has...feels like the throttle sticking
To chime into the rpm sticking thing you ever figure out why? Mine does it too it puzzles me
Daddya2 is offline   Reply With Quote
Old 03-17-2017, 12:06 PM   #19916
OpFox
Member#: 447104
2011 Impreza 2.5i
Spark Silver Metallic
Originally Posted by DexteRS View Post
I'm on the green coolant. I thought about flushing and putting in the blue with the conditioner because of this issue. But again, dealership advised against a flush and replacement in case that basically cleaned out anything that was helping block up the leak.
I picked mine up at 48k miles and was glad to find it has the blue coolant. I don't know if this green is the typical coolant or some special Subaru version of the green coolant or what, but from what I hear, the standard green coolant will cause accelerated head gasket wear among other problems.
Reviews on the blue coolant even back up the ability of the blue coolant to block minor leaks and many owners were able to go without a head gasket job or on worse head gaskets, prolong the life until proper work can be done.
Regarding the head gasket failures, from what I know the later models it was fixed. I have a 2011 and supposedly it has better head gaskets.
Newer pics of my car since I added an STi wing.
I was thinking of some Enkei's in 17x8... Sometimes I feel like 18's look a bit big on Narrow bodies especially without the side skits/ premium bumper. Anyone with 8 inch wheels with 40 offset? Would there be any rubbing issues? I just want better fitment. I like my P1s but don't want to use spacers.
OpFox is offline   Reply With Quote
Old 03-17-2017, 01:02 PM   #19917
Fendyman
Member#: 21542
2011 Impreza 2.5i
Dark Gray Metallic
^ Looking good! Add OEM splash guard kit & OEM rear bumper under guard to make the car more aggressive since we don't have sideskirts & premium bumpers.
Which Enkei's? Not sure about +40 offset, but I've seen Rotas 17x9" +42 w/ 245/40 clear just fine.
Fendyman is offline   Reply With Quote
Old 03-17-2017, 01:03 PM   #19918
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
18s can be big sometimes. Really depends on size, offset, and color.
18x8+48
18x9.5+38
Old 03-17-2017, 02:23 PM   #19919
OpFox
Member#: 447104
2011 Impreza 2.5i
Thanks for the feedback!
I was planning on getting the
E551SFG010 painted black (bumper flat black)
as well as maybe the splash guards and the 09-10 WRX grill down the road.
The wheels I was looking into are the TSP-5 and they come in 17 or 18... 18's usually look good on lowered narrow body WRX with kits or wide bodies. Look goofy on bare narrow body.
Goals for the end of the year is wheels to get a nice fitment. Maybe coilovers if the drop is not enough.
18x8+48
18x9.5+38
Wow, thanks. Really gives me a good idea of what it'll look like. I will probably go 17's with the TSP5's.
Old 03-17-2017, 07:11 PM   #19920
fakewrx
Member#: 457502
2010 Impreza
I have a 2010 2.5i and I really like the Tsudo exhaust, but my car's a sedan. Would it work to buy the exhaust, cut off the tip, and weld a few inches of tube in between? I was told everything was the same with the sedan and hatch, just the length is different. If not, is there any other exhausts? I can't seem to find any good sounding ones for a 2.5i hatch. Or maybe i can just save the money so I can sell my car and use that money plus the money I saved to buy a wrx instead.
What do you guys think I should do?
fakewrx is offline   Reply With Quote
Old 03-17-2017, 11:00 PM   #19921
OpFox
Member#: 447104
2011 Impreza 2.5i
There are other of exhausts for sedans, alot more options i think. Nameless makes cheap good exhausts for sedans.
Old 03-18-2017, 01:46 AM   #19922
Fendyman
Member#: 21542
2011 Impreza 2.5i
Dark Gray Metallic
Originally Posted by OpFox View Post
I was planning on getting the rear under guard E551SFG010 painted black (bumper flat black)
Since you're going to paint it, maybe look for a used one on eBay or Craigslist or even junk yard. Got mine for like $60 used & painted flat black.
FYI, even though Enkei is Japanese brand, but I think only the Racing series are made in Japan... the rest are made in Thailand or China. I'd personally rather pay a bit more for PF01 (made in Japan) which similar design as TSP-5 (made in Thailand).
Oh yeah... 17x8 +45 w/ 245/40 is perfect fitment for our car.
Old 03-18-2017, 03:11 PM   #19923
OpFox
Member#: 447104
2011 Impreza 2.5i
Yeah I'm always trying to fish Ebay for it to try to find one for under $150. I got my wing there that came painted from a wrecked STi for about $200 on ebay. Btw judging how good it looks on your car, it would look nice in my SSM as well paint to break up the ass silhouette.
Good info on the Enkei's.. I just noticed that the RPF1's (which i avoid normally since it played out) now comes in Bronze, as well as 17x7 42mm offset and 17x7.5 48 offset so I don't have to immediately change tires.
I'm wondering if those offsets will provide good fitment despite not being 45mm. My Prodrive P1s are currently 17x7 52-53 offset? and They aren't flush at all. I wish i could find 17" P1s with 45 offset
Old 03-20-2017, 12:43 PM   #19924
Fendyman
Member#: 21542
2011 Impreza 2.5i
Dark Gray Metallic
That bronze RPF1s come w/ 17x8 +45 as well... IMO, I wouldn't bother getting anything less than 8" width so you can fit 245/40. What tires & size do you have on the P1s? Are you planning to keep the P1s? If not, get rid of them w/ the tires... easier to sell.
FYI, the silver, & gold RPF1s is $23 cheaper & 0.3 lbs lighter (according to Tire Rack) than the bronze ones.
Old 03-20-2017, 07:11 PM   #19925
OpFox
Member#: 447104
2011 Impreza 2.5i
I have 215's, probably going 225, 235 tops... I'm not sure I want to go any wider.
Maybe the bronze paint is heavier? lol Either way, I like bronze since it doesn't stick out as much as gold. The design is "meh " to me and gold/ silver RPF1s are already everywhere.
would the +42 fit better than +48? the +38's in Jourdan's poke out a bit too much for me.
08 2.5i and 08 Sti Suspension WRXbrother Brakes, Steering & Suspension 10 08-22-2017 12:30 AM
Will an 08 WRX intake fit an 08 2.5i? Racing101 Normally Aspirated Powertrain 26 01-19-2012 11:57 AM
08 STI Wing on 08 2.5i impreza juny102004 Interior & Exterior Modification 13 01-18-2012 09:46 AM
Will 08+ WRX gauges swap into 08+ 2.5i? Simeon Priest Interior & Exterior Modification 10 03-26-2010 02:17 PM
08 2.5i mod question deunique1 Impreza Forum 1 10-03-2007 02:35 PM
