Welcome to the North American Subaru Impreza Owners Club Wednesday February 21, 2018
Old 03-19-2017, 04:40 AM   #1
voidteam
Member#: 436431
2011 WRX Hatch
Default Is this a nitrated crank?
Hi just wondering if anyone can help me work out of this is a normal or nitrated crank?
voidteam is offline   Reply With Quote
Old 03-19-2017, 09:17 AM   #2
motorbykemike
Member#: 273868
yeppers
motorbykemike is offline   Reply With Quote
Old 03-19-2017, 09:30 AM   #3
rexworx
Member#: 103232
GTX 3071R'd 11WRX
PPG,4.44,LSD,E85,6spdx2
Now quick, toss it and get a og forged, or newer forged/heat treated crank...
The nitrated crank is known to be the weakest of all Subaru cranks. A few have documented them breaking in half.
If your building for higher hp/trq. I would source a different crank. If its a basic build that wont be spun high rpm or beat on then run it I guess.
This is just IMO.
Old 03-19-2017, 10:57 PM   #4
Titter
Member#: 416107
2002 WRX Wagon
EJ207 Spec C 4EAT
This is just IMO.
this is completly false.
the 2011+ STI nitride crank is double cross drilled and heat-treated; it is plenty strong. they are used in most of IAG's blocks.
Titter is offline   Reply With Quote
Old 03-20-2017, 05:49 AM   #5
voidteam
Member#: 436431
2011 WRX Hatch
Well im rebuilding for a max of 500hp and was hoping to get my existing crank balanced and reuse it...
Will pros only ever run 400hp as a high boost tune however.
Old 03-20-2017, 11:51 AM   #6
rexworx
Member#: 103232
GTX 3071R'd 11WRX
Well your right about one thing. Yes in 11+ it is different. We aren't talking about a crank from a 11+ though my friend.... The 08-10 crank is what we are talking about. In fact I said the newest cranks are good....
How many cranks are sitting on your work order shelf as you type?
Old 03-20-2017, 05:18 PM   #7
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
^+2
I've heard of people breaking the nitrated crank also and broken cranks is pretty rare otherwise
Old 03-20-2017, 05:27 PM   #8
voidteam
Member#: 436431
2011 WRX Hatch
It came out of MY11 WRX
Old 03-20-2017, 05:43 PM   #9
norcaltuna
Member#: 286686
2003 WRX EJ207 VF36
It's a possibility that SOA only sells one replacement 2.5 crank at this point, but a new 2011 wrx crank is cross listed to the STi. Not to say yours is the same...
norcaltuna is offline   Reply With Quote
Old 03-20-2017, 06:42 PM   #10
rexworx
Member#: 103232
GTX 3071R'd 11WRX
Exactlly... All 79mm stroke cranks have been superseded with the new heat treated crank.
If you search youll find pics of the broken 08-10 cranks. Clint or Tony at TiC deff posted one they have broken. Should be easy to find that thread...
Old 03-20-2017, 07:49 PM   #11
isurfnj1
Member#: 343367
2002 rotated gt3076
What's the general consensus on the limits of the nitrated crank?
isurfnj1 is offline   Reply With Quote
Old 03-20-2017, 08:24 PM   #12
rexworx
Member#: 103232
GTX 3071R'd 11WRX
It really seems to be hit or miss. No clear "keep it under 500whp/8krpm etc. I personally ran one in a built block for a few years starting back in 2009ish. Car made 410whp/480wtrq. I never had a issue. Im not much of a gambling man... IMO the 300ish bucks for another crank is well worth the cost of the carnage a broken crank would cost. So when I decided to do a teardown to inspect the internals I swapped it out. I ended up building a 2.12 stroker with it. I figured the lighter weight of ej205 pistons would be less load on it...
Old 03-20-2017, 08:31 PM   #13
Titter
Member#: 416107
2002 WRX Wagon
EJ207 Spec C 4EAT
my bad i had my cranks mixed up. thought you were talking about the new ones.
Old 03-20-2017, 08:53 PM   #14
isurfnj1
Member#: 343367
2002 rotated gt3076
Maybe Ill try to sell my 09 crank and buy a new one. I'm going to be putting a hybrid together this summer. Looking to push my gt3076 on e85.
Old 03-20-2017, 09:11 PM   #15
tramp
Member#: 459629
2017 WRX base
WR Blue
I cannot help myself.............it's nitrided not nitrated.
tramp is offline   Reply With Quote
Old 03-21-2017, 12:20 PM   #16
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
indeed we have. snapped in half. we've seen it a few other times locally as well, and I know of other cases.
We're only using the newer induction hardened crank because of this.
Old 03-21-2017, 01:11 PM   #17
isurfnj1
Member#: 343367
2002 rotated gt3076
How much power snapped your crank?
Old 03-21-2017, 05:37 PM   #18
Turn in Concepts
Member#: 93646
Many Track Records
Honestly we don't know. We didn't have the dyno set up at the time so we never got a chance to measure it, and given the race schedule we never made it to one to try out.
I can say it was a large amount though given the lap times we were turning with the car at that time.
Old 03-22-2017, 05:29 AM   #19
voidteam
Member#: 436431
2011 WRX Hatch
Thanks.
So should I use my existing crank or buy a new one? They are much more expensive down here (Australia). For a new one it will cost about $800-$900. I wont be going past 400hp.
Ill also be getting the crank crack tested, grind and balance (if needed).
Old 03-22-2017, 06:50 AM   #20
A-man07
Member#: 271525
7/2 STi/WRX wagon
SWP/AW
Yeah that was driving me nuts too. Nitrated is something they do to hot dogs
Old 03-22-2017, 08:35 AM   #21
tramp
Member#: 459629
2017 WRX base
WR Blue
Originally Posted by voidteam View Post
Thanks.
Were it mine I'd have it magnafluxed (crack detection) and inspected by the best crank guy I could find and go on his assessment.
Old 03-22-2017, 08:45 AM   #22
voidteam
Member#: 436431
2011 WRX Hatch
The machine shop I am using are going to crack test it but I don't really know what method they use.
Old 03-22-2017, 10:05 AM   #23
voidteam
Member#: 436431
2011 WRX Hatch
This will be my build thread and has more info on the car.
https://forums.nasioc.com/forums/sho....php?t=2832372
Old 03-22-2017, 11:21 AM   #24
TDagen
Member#: 163648
2002 Resurrected WRX
Thanks.
Wow! Would shipping one in from the states be cost prohibitive? Brand new they go for about $380 around here IIRC.
Old 03-22-2017, 11:23 AM   #25
TDagen
Member#: 163648
Also is this a 2.5l or 2.0l? I know some of the AUS sti's run the 2.0...
