03-28-2017, 08:45 PM | #51 |
Member#: 89967
NESIC
Vehicle:2020 Volvo S60 Gray |
Look in the engine bay - theres a bunch of grommets in the firewall, you should be able to pick one. On our 2012-16 there was one that had 4 points, almost like a trapezoid. I used that to run the power line to my amp under the passenger seat.
04-04-2017, 04:22 PM | #52 |
Member#: 380906
Tri-State
Vehicle:2007 Legacy gt Silver |
Anyone do any exhaust work to the hatch yet?
04-05-2017, 10:22 AM | #53 |
Member#: 158794
MWSOC
Vehicle:xxxx wrx silver |
I did a muffler delete/ turn down pipe for a minute. It was really loud, go figure, sounded decent but it was too much for my daily driver.
04-05-2017, 06:55 PM | #54 |
Member#: 361912
E. Canada
Vehicle:2013 Imp GP Touring Satin White Pearl |
looks like Subispeed will be supporting the 17+ Impreza as they now added its own section: http://www.subispeed.com/more/2017-impreza
Theres nothing much yet, but at least its a start. |
04-15-2017, 06:37 PM | #55 | |
Member#: 380906
Tri-State
I saw that too |
04-15-2017, 10:27 PM | #56 |
Member#: 454351
Looks like the mud flaps are up, wonder how they look on the 5dr.
04-16-2017, 02:56 PM | #57 |
Member#: 463508
04-18-2017, 03:01 PM | #58 |
Member#: 21811
International
Sport Stabilizer Bar Question
I'm thinking about adding the rear swaybar from the Sport to my 2017 5 Door Premium. The Sport comes with front and rear bars while the rest of the models get the front only. Has anyone with the Sport measured the diameter of their bars. If the front on the Sport is the same size as the one on my Premium then I know adding the rear bar won't be too much for it.
The bar itself is only like $80 or so but you have to add the links, bushings and clamps too. I'm also considering going up to the Sport 11.6" front brake rotors. The other cars have 10.9" front rotors. 16" and 17" alloys have enough room to do the swap just by changing to the Sport caliper supports. The knuckles, calipers and brake shields appear to be the same ones used on the Sport. It should be an easy mod like I did to my old Forester going from 10.7"up to 11.4" WRX rotors. |
04-18-2017, 04:02 PM | #59 | |
Member#: 466267
04-19-2017, 03:42 PM | #60 | |
Member#: 466316
05-05-2017, 01:53 PM | #61 |
Member#: 466053
Vehicle:2017 Impreza 2.0i 5D Carbide Metallic Gray |
K&N Air Filter 33-2304 on 2017 Subaru Impreza
I was curious if anyone has tried the K&N Air Filter 33-2304 with their 2017 Subaru Impreza.
I was searching several parts retailers to see if anyone has manufactured a high(er) performance filter specifically for the 2017 yet, but haven't found anything. However, when searching the 2016 model (at AutoZone.com, for example), the results are: - STP Air Filter SA9997 - STP Premium Air Filter PSA9997 - K&N Air Filter 33-2304 When searching for the 2017 model on the same site, the results are: - STP Air Filter SA9997 - STP Premium Air Filter PSA9997 Since the two STP filters with the same part numbers and dimensions work on both years, I'm inclined to think the K&N would work on the 2017 Impreza as well. Any thoughts? |
05-05-2017, 04:13 PM | #62 | |
moon moon
Moderator Member#: 86213
NWIC
05-05-2017, 07:54 PM | #63 |
Member#: 421858
Vehicle:2012 Impreza |
lol trick wants you to destroy your engine with the cheese cloth that is K&N
05-11-2017, 11:14 AM | #64 | |
Member#: 465013
05-11-2017, 06:50 PM | #65 |
Member#: 21811
International
Thanks! You are correct and my reading comprehension on the brochure is not good My Premium does have the rear bar. I thought it cornered too flat not to have one. It is mounted way forward compared to the old Imprezas I'm used to working on. That's great and means I can spend my money on the larger brake rotors.
05-13-2017, 03:56 PM | #66 |
Member#: 459160
SCIC
Vehicle:2017 Impreza Crystal White Pearl |
05-13-2017, 07:57 PM | #67 |
Member#: 459160
SCIC
And better photos:
05-14-2017, 01:17 AM | #68 |
Member#: 299546
NESIC
Vehicle:2006 2.5i Impreza Wg Black |
Any pics at a better angle? Showing the whole car from the rear. Looks good but but can't really tell how they look as a whole from those angles
05-14-2017, 12:46 PM | #69 |
Member#: 459160
SCIC
05-15-2017, 12:44 PM | #70 |
Member#: 461580
Vehicle:2017 Impreza |
05-15-2017, 03:28 PM | #71 |
Member#: 459160
SCIC
05-21-2017, 10:51 PM | #72 |
Member#: 463508
Installing fog light kit
Anytime have any idea how easy or difficult installing a fog light kit like the one linked below would be? The description makes it sound pretty simple.
http://www.subispeed.com/more/2017-impreza/lighting/fog-lights/olm-complete-oem-style-fog-light-kit-2017-impreza |
05-22-2017, 12:49 AM | #73 | |
Member#: 459160
SCIC
The installation is the easy part. It's the electrical that can get tricky. Typically it's taken me about an hour for cars that needed the front bumper removed. The instructions provided look simple enough. Give it a go. |
05-25-2017, 01:08 AM | #74 |
Member#: 459160
SCIC
Anyone know of these are the US Eyesight headlights?
05-25-2017, 01:06 PM | #75 |
Member#: 466053
http://www.subispeed.com/more/2017-impreza/lighting/fog-lights/olm-complete-oem-style-fog-light-kit-2017-impreza<<< I bought these the day before yesterday. They arrive on Tuesday. Hope to install them next week - if/when I do, I'll post back and let you know how it went. |
