#26 |
Member#: 355661
W. Canada
Vehicle:2010 Impreza 2.5i WR Blue |
![]() ![]() 200whp on my 2.5i... yes lots of dollar bills spent
#27 |
Member#: 201277
Vehicle:2008 08 QSM 5MT LGT QSM |
![]() Are you running boost or is that just an extra mapped parameter ?
#28 |
Member#: 355661
W. Canada
![]() no boost no. its manifold relative pressure. vr dyno thinks its boost
#29 |
Member#: 466374
![]() Ours is just a 02 impreza, rs2.5 sedan, manual. I don't expect it to be like my big subie (AWD RT Dodge Magnum) but would like to build it up for my son (his 1st car, 15.5 yrs old) so hopefully he stays subie and will be prepared for a wrx at graduation in 3 yrs.
#30 |
Member#: 467956
Vehicle:2018 ordered WRX STI DGM |
![]() I had a 1998rs2.5 with borla headers, high flow cat, 2.5in cat back, injen intake, CM clutch, lightweight flywheel, strut bars front back, sway bars front back, lowering springs, short shifter. Car ripped with no tune. I never found a chip or tuned this car cus it was years ago but you prb get a chip or tune for an 06 easy now.
#31 |
Member#: 411867
E. Canada
Vehicle:2011 Impreza 2.5i WRB |
#32 |
Member#: 355661
W. Canada
![]() just buy one of everything, and dont stop till your broke! lol
im not really joking... I boxed up the whole engine and shiped it to Tom at tech works. his own 100mm 11.3:1 pistons, sti c rods and hardened crank port and bended the heads to match his pistons, valve job and his stage 2 cams and springs sti oil pump, fuel pump and injectors act wrx clutch and light weight fly wheel, light weight pulleys headers, low flow cat and 3" exhaust all the way stock intake, i can't find one i like. ecu flash for all my tuning |
#33 | |
Member#: 464727
Vehicle:2008 OB(Wan)S OBP/DGM 2-toner |
![]() Quote:
#34 |
Member#: 161832
Vehicle:2000 Outback Limited Black |
![]() i assume this graph is an engine dyno, correct?
#35 |
Member#: 355661
W. Canada
![]() its wheel hp, if that's what you are asking
#36 |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT 1996 Impreza coupe |
#37 | |
Member#: 334356
SWIC
Vehicle:2006 2.5i Wagon SRR |
![]() Quote:
#38 |
Member#: 355661
W. Canada
![]() id like to add a sound clip, but i can seem to
#39 |
Member#: 120
AKIC
![]() Youtube?
#40 |
Member#: 161832
#41 |
Member#: 355661
W. Canada
![]() see if that works, lol |
#42 | |
Member#: 464727
![]() Quote:
Nice looking suba ^.^ |
#43 |
Member#: 355661
W. Canada
![]() no 3" all the way
#44 |
Member#: 161832
#45 |
Member#: 464727
#46 |
Member#: 355661
W. Canada
![]() no wheel spacers, just an offset.
why not 3"? 2 1/2" would be too restrictive on my set up. |
#47 |
Member#: 408701
#48 |
Member#: 457410
International
Vehicle:1991 Legacy RS RA White |
![]() 2 1/2 inch is the biggest you want to go on N/A. This was the case for my EJ25 wagon and my Mondeo 2.5 V6.
With bigger piping you lose the 'Back pressure' in the system. In other words the piping decreases the speed of flow of the exhaust and you end up losing the savaging properties of a well set up system. 3inch is fine for a turbo but not for N/A. Don't know wh you would say 2.5 is too restrictive, I would say 3inch is too unrestricted. But hey its you car and tune, if you like the 3inch then go for it. Would be interesting to see a back to back with a 2.5 and 3inch exhaust on the dyno Does sound good for a N/A sub |
#49 |
Member#: 71092
Vehicle:2005 2.5RS Wagon Regal Blue Pearl |
![]() Unless you're increasing airflow SIGNIFICANTLY (like putting $10k+ into the build in todays money), with the EJ25 non-turbo the biggest you want to go is 2.25". Anything more than that actually drops the exhaust velocity, hurts scavenging, and reduces power.
#50 |
Member#: 161832
![]() 2.5" is max as we all know for N/A. not sure who told you to go that large.
More HP for a 2.5I | Abill10 | Normally Aspirated Powertrain | 49 | 06-08-2010 09:04 PM |
How to gain more power on an Impreza 2.0GT | WGTimpreza | Subaru Conversions | 0 | 12-24-2009 01:53 AM |
Ideas? 10-20 more hp for a 2.5i? | jbd0419 | Built Motor Discussion | 3 | 06-28-2009 04:41 PM |
ways to increase lower end on a 2.5i | new2.5i | Newbies & FAQs | 15 | 04-15-2008 03:37 AM |
How did SOA get 7 more hp On newer 2.5?? | brett-01 | Normally Aspirated Powertrain | 38 | 11-02-2007 01:30 AM |
