Welcome to the North American Subaru Impreza Owners Club Sunday May 27, 2018
Old 04-30-2017, 12:21 PM   #1
Boostwagon256
Member#: 450448
Default Help! Sd Ve Tables!
I have searched to no avail for an example of a SD VE table! Is there anyone here that could do me a huge favor and send me a base table to work from? I don't have the ability to base off of a MAF table. Also I wondered if there is any way to copy and past a MAF table from an OTS map to my SD VE table? The problem I see with doing that, if at all possible would be the adjustments. The SD VE tables are not real time and I see it taking a large amount of reflashing to even come close to the right numbers. Thank you for any and all feedback on this.
Boostwagon256 is offline   Reply With Quote
Old 05-02-2017, 12:04 PM   #2
mr.nicknasty8
Member#: 244192
2006 WRX
ARC FMIC
You can live tune the VE map. It's pretty straight forward even if you don't have a basemap to use
mr.nicknasty8 is offline   Reply With Quote
Old 05-02-2017, 12:36 PM   #3
Boostwagon256
Member#: 450448
According to COBB support and the software it is reflash only.
If I'm missing something please let me know!
Old 05-19-2017, 03:46 PM   #4
wildt267
Member#: 161812
06 Wrx STi
Check out their speed density primer document. It explains there is a monitor you can select to help you build your ve map while running off the map. It will make sense when you see it. Megasquirt also has some documentation on how to develop a ve map from scratch.
wildt267 is offline   Reply With Quote
