Welcome to the North American Subaru Impreza Owners Club Saturday June 23, 2018
Old 06-19-2017, 01:10 PM   #1
BOL3RO
Member#: 469219
Default 2016 Wrx Idle Boost Reading
Hey! Probably a newbie question for many but I can't seem to find a simple and direct answer anywhere.
As the car sits in idle, the Subaru boost gauge reads between -7 to -8 Psi most of the time in "D" (CVT transmission). In "P" it'll typically sit between -8 to -9 Psi. Please advise wether or not this is normal.
Info: 2016 WRX CVT, Cobb big sf intake system / 91oct stage 1+ map.
BOL3RO is offline   Reply With Quote
Old 06-19-2017, 01:16 PM   #2
david211
Member#: 432622
2017 WRX
WR Blue Pearl
Normal as in the negative numbers or normal as in those specific readings?
david211 is offline   Reply With Quote
Old 06-19-2017, 01:17 PM   #3
BOL3RO
Member#: 469219
Thanks for the reply. The specific numbers.
Old 06-19-2017, 01:20 PM   #4
david211
Member#: 432622
2017 WRX
WR Blue Pearl
I would say that that is normal, every car is different and numbers will fluctuate but I wouldn't worry about it. Mine (granted it is a 6 speed, which shouldn't matter that much) idles around the same on a "Stage 2" Etune.
Old 06-19-2017, 01:25 PM   #5
BOL3RO
Member#: 469219
Thank you! When I purchased the wrx in march the climate was cool/cold with an average reading of -9psi in "D". I was also curious if current summer climate would contribute to the subtle difference at all.
Old 06-19-2017, 01:45 PM   #6
david211
Member#: 432622
2017 WRX
WR Blue Pearl
No problem!
The ECU has a wastegate duty cycle Intake Air Temperature compensation table (WGDC IAT) that pulls WGDC based on the intake air temperature. It starts pulling WGDC around 40 degrees ambient, so you will start underboosting in cold temperatures if the tune wasn't adjusted for this.
Old 06-19-2017, 01:50 PM   #7
BOL3RO
Member#: 469219
No problem!
Ahh, ok. The subtle increase in a warmer climate makes sense now.
Old 06-19-2017, 06:09 PM   #8
rich3389
Member#: 207322
No problem!
This has nothing to do with idle.
rich3389 is offline   Reply With Quote
Old 06-19-2017, 07:08 PM   #9
NewToThisWRXThing
Member#: 469542
My 2016 WRX idles at around -7 psi. Does this mean it's restricting airflow into the engine as opposed to when the psi is positive and pushing more air in?
NewToThisWRXThing is offline   Reply With Quote
Old 06-19-2017, 07:20 PM   #10
GlarryHoodDIT
Member#: 460907
2016 WRX
Phatron Tuned
No, it means your engine is taking in air, but not compressed air from the turbo. The air is still passing through from the intake through yhe turbo and into your manifold, but the turbine isnt spinning so the air isnt compressed and thus more powerful.
GlarryHoodDIT is offline   Reply With Quote
Old 06-19-2017, 07:54 PM   #11
tramp
Member#: 459629
2017 WRX base
WR Blue
Turn the A/C on at highway speeds and watch it change.
tramp is offline   Reply With Quote
Old 06-20-2017, 09:10 AM   #12
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
1050 Triumph Speed Triple
Call your dealer with new car questions.
Old 06-20-2017, 09:24 AM   #13
SoapBox
Member#: 204578
My wife said she'd
buy me a Lotus, AKA REX8
Isn't there a bit more drag on the motor in D vs. P? That would explain the slight reduction in vacuum?
SoapBox is online now   Reply With Quote
Old 06-20-2017, 09:26 AM   #14
SoapBox
Member#: 204578
My wife said she'd
You could use that as an answer to 1/2 the threads started on here. No one would be getting any help from your average dealership worker anyway...generally clueless.
Old 06-20-2017, 09:30 AM   #15
SoapBox
Member#: 204578
My wife said she'd
Even at idle, the turbine is certainly spinning, might even be several thousand RPMs.
Old 06-20-2017, 09:47 AM   #16
GlarryHoodDIT
Member#: 460907
2016 WRX
Phatron Tuned
Sorry, spinning but not building boost.
Tgis from the guy who posts "stop buying ejs thats ur problem lololol" in lile 8/10 threads?
