06-22-2017, 10:37 PM | #3051 |
Member#: 33782
MAIC
Vehicle:96 3MI Racing search FIRST, then PM!!! |
so as to not pick up and unbiased yaw and excess roll, closer to CG for the mounting, the better....but probably not very doable. Might place it up in front of the shifter up under where the stock radio would be.
06-23-2017, 11:48 AM | #3052 | |
Top Scoob 009
Member#: 68273
MAIC
Vehicle:2012 WRX GD Race Car |
06-29-2017, 01:43 PM | #3053 |
Top Scoob 009
Member#: 68273
MAIC
Got the Cosworth manifold installed. It certainly looks nice, now let's see how much power it makes up top!
07-01-2017, 01:46 AM | #3054 |
Member#: 465737
Looking great!
07-02-2017, 06:00 AM | #3055 |
Member#: 470278
Absolutely love this build. Have been going to IAG since 09, my car probably has more time there than on the road Im looking forward to seeing your Samsonas sequential trans installed. I have heard its way more reliable than PPG sequential. How many K can you get out of it before a rebuild?
07-02-2017, 12:26 PM | #3056 | |
Top Scoob 009
Member#: 68273
MAIC
07-02-2017, 03:12 PM | #3057 |
Member#: 470278
Very nice can't wait to see it on yours with paddles.
07-02-2017, 08:34 PM | #3058 |
Member#: 33782
MAIC
Most dog box trans rebuild cycles depend on how well they're shifter. The better you setup those paddles, the more money it'll save you.
07-05-2017, 10:56 AM | #3059 |
Top Scoob 009
Member#: 68273
MAIC
Yep, the paddles should help a lot with wear once they're set up correctly. A computer will time the downshifts better than a human every time!
07-05-2017, 05:43 PM | #3060 |
Member#: 470278
When will we get some pics
07-06-2017, 10:26 AM | #3061 |
Top Scoob 009
Member#: 68273
MAIC
08-08-2017, 04:45 PM | #3062 |
Top Scoob 009
Member#: 68273
MAIC
A little bit more aero work on the car this past weekend. I worked with DHP Composites on a custom set of barge boards, which I was able to test fit but still need to work out final mounting. This should help quite a bit with overall downforce by separating the vortices moving down the side of the car, as well as the turbulent wake off the front tires, from the high velocity airflow underneath the car and into the rear diffuser.
I also fabricated some carbon bumper spats, which will help create front downforce by stalling the airflow over the top of the splitter and creating high pressure zones. They should also reduce drag by redirecting air around the front tires. Next order of business is to replace the front bumper latches with Quik Latch fasteners. Besides being an eyesore, they are actually large enough that they're probably disturbing airflow and interrupting the vortices coming off the dive planes. More on this later. |
08-10-2017, 02:13 PM | #3063 |
Top Scoob 009
Member#: 68273
MAIC
With the flat bottom retaining heat, cockpit temp can reach 130+ degrees. This new cool suit system from Ultra Chiller should keep me comfortable, rather than sweating out half my body weight during a 40 minute race. And it's only around 10 lbs fully loaded!
08-10-2017, 02:30 PM | #3064 |
Hoodbridge!
Moderator Member#: 560
MAIC
Vehicle:2006 STi, 16 Outback Crystal Gray, Silver |
Going back to transmission talk. What oil did you run, and did you use an transmission cooler?
Been having trouble with the trans overheating. Was running 75W90, but switched to 75W140 Motul comp oil. Still having issues. Afraid it might be time to open up the trans after 10 years of track abuse. |
08-10-2017, 02:39 PM | #3065 | |
Top Scoob 009
Member#: 68273
MAIC
It's also possible you're just in need of a rebuild/new synchros. Buy my JDM 5/6 and install it while you're in there |
08-10-2017, 03:10 PM | #3066 |
Hoodbridge!
MAIC
08-10-2017, 03:20 PM | #3067 | |
Top Scoob 009
Member#: 68273
MAIC
08-10-2017, 04:04 PM | #3068 | |
Member#: 158864
Vehicle:2003 SOHC destroker |
08-10-2017, 04:41 PM | #3069 | |
Top Scoob 009
Member#: 68273
MAIC
08-10-2017, 05:22 PM | #3070 |
Member#: 158864
So it turns out it was completely relevant lol
08-10-2017, 08:22 PM | #3071 |
Member#: 458149
I might have missed it, but is the samsonas in?
08-10-2017, 10:08 PM | #3072 |
Member#: 33782
MAIC
I think the external line features went away with the introduction of the GR cars (08).
08-11-2017, 09:04 AM | #3073 |
Top Scoob 009
Member#: 68273
MAIC
Ugh it's been sitting in customs since July 26. Some jackass flagged it as "agricultural goods" so they can hold it for up to 30 days for inspection before they clear it. So ridiculously frustrating since it means I'm now going to have to bow out of Gridlife. Can I blame Trump for this one?
08-11-2017, 10:33 AM | #3074 |
Member#: 458149
You can blame me....I'm full of bad luck and July 26 is my birthday.
08-11-2017, 11:31 AM | #3075 |
Top Scoob 009
Member#: 68273
MAIC
Well then...THANKS A LOT
Similar Threads | ||||
Turn in Concepts 2010 Track Car Build | Turn in Concepts | Press Releases | 374 | 12-30-2016 02:06 PM |
My GC Race car build | rrsettgast | Member's Car Gallery | 3 | 04-27-2010 12:19 PM |
Came out to my car... belt on the ground and this (pic). | Padge | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 03-11-2009 10:36 PM |
Getting my car closer to the ground | BluScopion | Vancouver Impreza Club Forum -- VIC | 12 | 02-02-2007 02:30 AM |
got car back from the shop, now lights are messed up | X2.5RS01X | New England Impreza Club Forum -- NESIC | 1 | 02-21-2005 09:41 PM |
