Welcome to the North American Subaru Impreza Owners Club Tuesday March 19, 2024
Old 06-22-2017, 10:37 PM   #3051
Homemade WRX
Member#: 33782
96 3MI Racing
search FIRST, then PM!!!
so as to not pick up and unbiased yaw and excess roll, closer to CG for the mounting, the better....but probably not very doable. Might place it up in front of the shifter up under where the stock radio would be.
Old 06-23-2017, 11:48 AM   #3052
boost junkie
Top Scoob 009
Member#: 68273
GD Race Car
Originally Posted by Scargod View Post
Same here with the DCCD Pro. I've yet to go through the process of finding a level spot for the car and zeroing the dual axis G sensor. Did you zero everything per their instructions?
And you're running the stock center diff??
That's exactly where the sensor is mounted. IAG machined an aluminum enclosure for the controller board that also houses the G sensor. The whole thing is mounted on top of the tunnel in front of the shifter. I may move it back several inches now that the shifter is gone.
boost junkie is offline   Reply With Quote
Old 06-29-2017, 01:43 PM   #3053
boost junkie
Top Scoob 009
Member#: 68273
GD Race Car
Got the Cosworth manifold installed. It certainly looks nice, now let's see how much power it makes up top!
Old 07-01-2017, 01:46 AM   #3054
Brinnerz
Member#: 465737
Looking great!
Brinnerz is offline   Reply With Quote
Old 07-02-2017, 06:00 AM   #3055
09blacksti
Member#: 470278
Absolutely love this build. Have been going to IAG since 09, my car probably has more time there than on the road Im looking forward to seeing your Samsonas sequential trans installed. I have heard its way more reliable than PPG sequential. How many K can you get out of it before a rebuild?
09blacksti is offline   Reply With Quote
Old 07-02-2017, 12:26 PM   #3056
boost junkie
Top Scoob 009
Member#: 68273
GD Race Car
Apparently some are getting several seasons out of them before rebuilding, they are pretty stout.
Old 07-02-2017, 03:12 PM   #3057
09blacksti
Member#: 470278
Very nice can't wait to see it on yours with paddles.
Old 07-02-2017, 08:34 PM   #3058
Homemade WRX
Member#: 33782
96 3MI Racing
Most dog box trans rebuild cycles depend on how well they're shifter. The better you setup those paddles, the more money it'll save you.
Old 07-05-2017, 10:56 AM   #3059
boost junkie
Top Scoob 009
Member#: 68273
GD Race Car
Most dog box trans rebuild cycles depend on how well they're shifter. The better you setup those pedals, the more money it'll save you.
Yep, the paddles should help a lot with wear once they're set up correctly. A computer will time the downshifts better than a human every time!
Old 07-05-2017, 05:43 PM   #3060
09blacksti
Member#: 470278
When will we get some pics
Old 07-06-2017, 10:26 AM   #3061
boost junkie
Top Scoob 009
Member#: 68273
GD Race Car
Nothing gearbox related yet. But I have been working on fine tuning the aero for a bit more front downforce. Added some splitter end plates and still working on a few more small tweaks.
Old 08-08-2017, 04:45 PM   #3062
boost junkie
Top Scoob 009
Member#: 68273
GD Race Car
A little bit more aero work on the car this past weekend. I worked with DHP Composites on a custom set of barge boards, which I was able to test fit but still need to work out final mounting. This should help quite a bit with overall downforce by separating the vortices moving down the side of the car, as well as the turbulent wake off the front tires, from the high velocity airflow underneath the car and into the rear diffuser.
I also fabricated some carbon bumper spats, which will help create front downforce by stalling the airflow over the top of the splitter and creating high pressure zones. They should also reduce drag by redirecting air around the front tires.
Next order of business is to replace the front bumper latches with Quik Latch fasteners. Besides being an eyesore, they are actually large enough that they're probably disturbing airflow and interrupting the vortices coming off the dive planes. More on this later.
Old 08-10-2017, 02:13 PM   #3063
boost junkie
Top Scoob 009
Member#: 68273
GD Race Car
With the flat bottom retaining heat, cockpit temp can reach 130+ degrees. This new cool suit system from Ultra Chiller should keep me comfortable, rather than sweating out half my body weight during a 40 minute race. And it's only around 10 lbs fully loaded!
Old 08-10-2017, 02:30 PM   #3064
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
Going back to transmission talk. What oil did you run, and did you use an transmission cooler?
Been having trouble with the trans overheating. Was running 75W90, but switched to 75W140 Motul comp oil. Still having issues. Afraid it might be time to open up the trans after 10 years of track abuse.
Old 08-10-2017, 02:39 PM   #3065
boost junkie
Top Scoob 009
Member#: 68273
GD Race Car
I've been running Motul Gear FF 75W140. It was working for awhile but with the flat bottom, it just gets too hot. We're going to add trans and rear diff coolers, and I'm going to build some heat shielding to separate the downpipe from the trans case.
It's also possible you're just in need of a rebuild/new synchros. Buy my JDM 5/6 and install it while you're in there
Old 08-10-2017, 03:10 PM   #3066
mav1c
Hoodbridge!
Member#: 560
Hmmmm...What state is your JDM 5/6 in? Does it need to be rebuilt at all? Will it work with the existing Diff and DCCD?
Old 08-10-2017, 03:20 PM   #3067
boost junkie
Top Scoob 009
Member#: 68273
GD Race Car
It's brand new, I never installed it. Was planning to but then I decided to do the Samsonas instead. It just replaces your stock 5th and 6th drive gears, and the 5/6 driven gear cluster. Everything else remains the same.
Old 08-10-2017, 04:04 PM   #3068
vicious_fishes
Member#: 158864
2003 SOHC destroker
Not that this is really relevant to you with the sequential, but several of the factory 6mt's from the spec C (and I think other models) had an external line that fluid was pumped through for precisely this reason - disconnect the factory plumbing and connect an oil cooler, threads etc already tapped, pump already installed, ready & waiting
Old 08-10-2017, 04:41 PM   #3069
boost junkie
Top Scoob 009
Member#: 68273
GD Race Car
04-05 (and maybe 06?) USDM 6mt's are the same. Since the sequential uses the stock case, we will be using the internal fluid pump to circulate oil through the cooler. In stock form it's just a crossover that moves fluid around within the case but it's easy to replace the crossover pipe with lines to a cooler core like you said.
Old 08-10-2017, 05:22 PM   #3070
vicious_fishes
Member#: 158864
2003 SOHC destroker
So it turns out it was completely relevant lol
Old 08-10-2017, 08:22 PM   #3071
03threefiftyz
Member#: 458149
I might have missed it, but is the samsonas in?
03threefiftyz is offline   Reply With Quote
Old 08-10-2017, 10:08 PM   #3072
Homemade WRX
Member#: 33782
96 3MI Racing
I think the external line features went away with the introduction of the GR cars (08).
Old 08-11-2017, 09:04 AM   #3073
boost junkie
Top Scoob 009
Member#: 68273
GD Race Car
Ugh it's been sitting in customs since July 26. Some jackass flagged it as "agricultural goods" so they can hold it for up to 30 days for inspection before they clear it. So ridiculously frustrating since it means I'm now going to have to bow out of Gridlife. Can I blame Trump for this one?
Old 08-11-2017, 10:33 AM   #3074
03threefiftyz
Member#: 458149
You can blame me....I'm full of bad luck and July 26 is my birthday.
Old 08-11-2017, 11:31 AM   #3075
boost junkie
Top Scoob 009
Member#: 68273
GD Race Car
Well then...THANKS A LOT
Turn in Concepts 2010 Track Car Build Turn in Concepts Press Releases 374 12-30-2016 02:06 PM
My GC Race car build rrsettgast Member's Car Gallery 3 04-27-2010 12:19 PM
Came out to my car... belt on the ground and this (pic). Padge Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-11-2009 10:36 PM
Getting my car closer to the ground BluScopion Vancouver Impreza Club Forum -- VIC 12 02-02-2007 02:30 AM
got car back from the shop, now lights are messed up X2.5RS01X New England Impreza Club Forum -- NESIC 1 02-21-2005 09:41 PM
