Welcome to the North American Subaru Impreza Owners Club Sunday October 20, 2019
Old 06-27-2017, 08:16 PM   #51
youknowho47s
Member#: 467796
2012 wrx
grey
installing my cobb stage 1 short shifter kit tomorrow in my12 wrx. I've seen reviews that the bolts are very easy to strip has anyone had this issue installing these?? anything else i should look out for?
youknowho47s is offline   Reply With Quote
Old 07-01-2017, 09:25 PM   #52
hamsamsquanch
Member#: 470264
- Oil change
- Upgraded grounds (engine and battery grounds are now all 4awg)
- Upgraded alternator wiring (4awg)
- Rotated tires
- Fixed subwoofer amp power supply wiring
tomorrows list
- Add floor lights
- Detail interior
- Tire shop for my other wheels
hamsamsquanch is offline   Reply With Quote
Old 07-08-2017, 02:25 AM   #53
blackseafleet
Member#: 463024
2017 WRX
cleaned my wheels and tires. interior detail. cleaned windows for tint next week (hopefully).
after tint we go with new wheels and tires. grey wheels on a grey car does not look right.
blackseafleet is offline   Reply With Quote
Old 07-08-2017, 02:30 PM   #54
robschilke
Member#: 397553
2014 GR8 DGM
Subaru Ambassador
Cleaned the wheels and installing mud flaps on the GR
robschilke is offline   Reply With Quote
Old 07-09-2017, 12:09 AM   #55
terrainasaurus
Member#: 464727
2008 OB(Wan)S
OBP/DGM 2-toner
Painted the original chrome emblem ring obp, now waiting for it to cure.
And sanded my window switch panels too early. Acrylic Laquer by duplicate color takes forever to cure, it's been a week!!!!!
terrainasaurus is offline   Reply With Quote
Old 07-09-2017, 05:19 PM   #56
robschilke
Member#: 397553
2014 GR8 DGM
Subaru Ambassador
Finished the install of my mudflaps. Started late last night and got tired after installing the driver's side. finished up the passenger side today and realized I needed to move some washers around. You'd think Rally Armour would create better diagrams for their kits. Nah.
Old 07-10-2017, 04:44 PM   #57
blackseafleet
Member#: 463024
2017 WRX
pulled the ebay roof spoiler off. LA heat and 3m tape don't agree.
vinyl wrapped silver spoke on steering wheel with matte black. the glare off that thing is brutal. gloss black would have done the same thing.
Old 07-10-2017, 06:30 PM   #58
RC Pilot
Member#: 459411
Changed the oil.
RC Pilot is offline   Reply With Quote
Old 07-10-2017, 07:44 PM   #59
Sour_K
Member#: 370021
2008 WRX Hatchback
Just make sure they're tight after it's set. First 2 times I thought they were tight and the shifter slid up while trying to change gears. Crank those MFrs down. I also chose to remove the foam insert under the boot, it kept wanting to pop it out of 2nd, 4th, and R at the 2nd lowest setting. No problems now for 2.5 yrs.
Took it to a shop to smoke test after a P0172 code and bogging problems. They cleaned the MAF and it's running perfect now. Saved me $50.
Sour_K is offline   Reply With Quote
Old 07-10-2017, 09:29 PM   #60
HeavensCloud
Member#: 470096
2014 WRX Sedan
KB short shifter, cabin and engine air filters, Dynamat. Not too much.
HeavensCloud is offline   Reply With Quote
Old 07-11-2017, 12:54 AM   #61
subarumod
Member#: 468745
06 wrx
black as your girls soul.
sanded and sprayed clear coat over my headlights to make em look new. looks awesome
subarumod is offline   Reply With Quote
Old 07-11-2017, 07:21 PM   #62
srm86
Member#: 424654
2011 wrx limited
dgm
Awesome job on the trim paint. iv been thinking about wrapping mine.
srm86 is offline   Reply With Quote
Old 07-12-2017, 12:43 AM   #63
terrainasaurus
Member#: 464727
2008 OB(Wan)S
OBP/DGM 2-toner
I thought about tinting it red, like a chrome red to match the overlays. Decided on the obp for match
Old 07-12-2017, 03:19 AM   #64
chippdpanda
Member#: 466132
2016 WRX Limited
CWP
I wrapped my shifter boot trim with 3M 1080 carbon fiber. Love the way it turned out.
chippdpanda is offline   Reply With Quote
Old 07-12-2017, 09:58 AM   #65
HeavensCloud
Member#: 470096
2014 WRX Sedan
Got a pic? That sounds like it would look good.
Old 07-12-2017, 01:02 PM   #66
chippdpanda
Member#: 466132
2016 WRX Limited
CWP
Old 07-12-2017, 01:15 PM   #67
terrainasaurus
Member#: 464727
2008 OB(Wan)S
OBP/DGM 2-toner
That looks great
Old 07-12-2017, 02:33 PM   #68
M3lover1
Member#: 440553
2017 WRX STI Base
Today, drove it to work. But in the next several will have some parts installed, just waiting on delivery of last part tomorrow, and try to find a day where I can take my car to the shop.
M3lover1 is offline   Reply With Quote
Old 07-12-2017, 10:19 PM   #69
terrainasaurus
Member#: 464727
2008 OB(Wan)S
OBP/DGM 2-toner
Mocked up the grill and made sure the mesh will be snug with the backing trim/mold. Trimming and bending the aluminum has been the time consumer here, and when the mounting brackets break because they're plastic... well it sucks lol. But you've got to get it done!
Securing it now. Will need to figure out what the best primer for aluminum is and make a that purchase, then hit it with some flat black and matte clear.
Any suggestions for good aluminum primer and durable matte clear coat?
Old 07-13-2017, 09:30 AM   #70
BajaGreg
Member#: 80956
2005 Baja Turbo 5spd
Bratmobile
Default Better Late than Never
So, its been a while; but I finally got time to install the Mishimoto FMIC
I bought last year in my 2005 Baja Turbo.
Fits well, minor cutting only, and cools the intake charge 35 degrees.
http://www.sliceoftimeimages.com/Baja
BajaGreg is offline   Reply With Quote
Old 07-15-2017, 03:20 PM   #71
Ramone179
Member#: 466281
2017 WRX
CEP
Installed USR aftermarket headlights. Car looks way different, definitely still getting used to it.
Ramone179 is offline   Reply With Quote
Old 07-15-2017, 10:10 PM   #72
Infinite0180
Member#: 410716
2016 WRX
CBS
Replaced my gauge lens today. Previous owner or dealer screwed the original up...
Before:
After:
Infinite0180 is offline   Reply With Quote
Old 07-16-2017, 01:38 AM   #73
f22boy
Member#: 464019
2017 Wrx
ISM
Oil, trans and diff fluids changed today. Didnt jump on the "insert brand here" bandwagon though.
f22boy is offline   Reply With Quote
Old 07-16-2017, 02:17 AM   #74
andrewkpt
Member#: 387700
2001 IS300
BLACK
got an oil change....
last night that is - late post
andrewkpt is offline   Reply With Quote
Old 07-16-2017, 03:40 AM   #75
subarumod
Member#: 468745
06 wrx
sand n primed my door. painting it tomorrow with the grimspeed wrb spray paint..
