Welcome to the North American Subaru Impreza Owners Club Saturday April 21, 2018
Old 07-01-2017, 01:04 PM   #1
Brock31
Member#: 128115
2008 STi Hatch OBP
enginuity is cool
Default Using rear diff as jack point? OK or not
I want to change trans fluid on my '08 STI and don't have access to a lift. The car needs to be elevated and level to do so.
I want to put the front wheels on ramps and lift the rear and place on jack-stands.
To lift the rear the only place that looks feasible to lift the both sides while allowing space for jack stands to be placed is the diff, but obviously I don't want to damage it.
So...OK or not to lift at the diff or other suggestions to lift the rear.
Thanks in advance.
Brock31 is offline   Reply With Quote
Old 07-01-2017, 01:09 PM   #2
meinct
Member#: 350408
2012 wrx
dgm
Yes it is ok
meinct is offline   Reply With Quote
Old 07-01-2017, 02:54 PM   #3
xtreme98501
Member#: 431693
2005 WRX STI
I have always used the rear diff. It has the perfect little spot for the jack to hit and I've never had any problems
xtreme98501 is offline   Reply With Quote
Old 07-01-2017, 05:30 PM   #4
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
pretty sure the owners manual even indicates that as the rear center jacking point, so you should be good to go. (that's how I lifted the rear of my old 02 WRX wagon, as well as how I lift the back of my current Legacy, when needed)
DrD is offline   Reply With Quote
Old 07-01-2017, 08:00 PM   #5
terrainasaurus
Member#: 464727
2008 OB(Wan)S
OBP/DGM 2-toner
I've been using it. If you don't want to scuff it up, try using a rubber mat of some sort in between it and the jack plate.
terrainasaurus is offline   Reply With Quote
Old 07-01-2017, 11:42 PM   #6
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Agreed, it's how I lift my 98 and our 99 since new on each. Also every other Subaru I work on.
Old 07-02-2017, 04:17 PM   #7
Vancouver98STi
Member#: 459287
1998 JDM Impreza STi
White GF8 wagon
Smile A little improvisation...
I took that idea a bit further. I cut and shaped an old hockey puck to fit into the top of the metal "saddle" of my floor jack. Canadian, eh!
Vancouver98STi is offline   Reply With Quote
Old 07-02-2017, 04:33 PM   #8
g-heap
Member#: 403883
Don't need nothing fancy, a small paperback, especially one you felt was waste of good paper, should do the trick between the jack's "cup" and the differential.
I personally recommend "Midnight's Children".
g-heap is online now   Reply With Quote
Old 07-17-2017, 08:28 AM   #9
Peteypipes
Member#: 470500
HAHAHAHAHA! i do the same thing!
Peteypipes is offline   Reply With Quote
