Welcome to the North American Subaru Impreza Owners Club Sunday February 25, 2018
Old 08-12-2017, 08:05 PM   #1
a3ng25
Member#: 341599
2013 WRX Base
Default Am I about to blow up?
I recently started seeing some higher feedback knock numbers showing up while I'm driving around town or on the highway...like -(4.0-5.0) range. So I started logging full trips. I got one as high as -11.8 while just cruising on the highway.
But when I hit WOT the logs look pretty clear and normal to me.
Should I be concerned? Do I need to take it into the shop to get looked at?
Any help appreciated...
Here's a link to some logs showing the clear WOT pulls on the same day as the cruising logs with the worrisome knock corrections.
https://drive.google.com/drive/folde...k0?usp=sharing
I've got a 2013 Subaru WRX with a tbe. Those are about the only mods on the car. Running a torquedperf map.
a3ng25 is offline   Reply With Quote
Old 08-12-2017, 08:22 PM   #2
ShinjiML
Member#: 257231
2011 STI ShinjiTuned
Anything rattling in your engine bay or even in the trunk? A heavier box hitting the sides of the trunk can actually cause high knock values.
ShinjiML is offline   Reply With Quote
Old 08-12-2017, 08:31 PM   #3
a3ng25
Member#: 341599
2013 WRX Base
I do have my kayak racks in the trunk and some other misc stuff.
In the engine bay the only thing I could think of is maybe the wiring for my lights?
Old 08-12-2017, 09:43 PM   #4
JSR84
Member#: 469585
Something is causing some excessive noise if you're hitting 11.8... But no you're not going to blow up if its under low load cruising type situations.
JSR84 is offline   Reply With Quote
Old 09-03-2017, 09:35 PM   #5
MikkoBraun
Member#: 473950
Default Confused
Question. How many maps does the ecu play out when driving? I know there is a map for WOT.
MikkoBraun is offline   Reply With Quote
