Welcome to the North American Subaru Impreza Owners Club Saturday April 20, 2019
Old 02-16-2017, 02:35 PM   #251
ebo03
Member#: 111008
2011 LGT SSM, 2006
Baja Turbo ABP
Originally Posted by Bill Irwin View Post
Just bought my first Baja last week. 2005 Turbo Silver/Silver with 59,000 miles. Will be needing to replace soon, good to see one with raised white letter tires...
Damn that's low mileage. 5MT or auto?
ebo03 is offline   Reply With Quote
Old 02-16-2017, 04:50 PM   #252
Bill Irwin
Member#: 462923
Auto. Wasn't looking for one, didn't even know what a Baja was (don't see many in Dallas Tx). But when I was looking for a used truck (my wife wanted a car) we saw this and liked it !!!
Bill Irwin is offline   Reply With Quote
Old 04-09-2017, 05:12 PM   #253
Mrcrowley206
Member#: 465342
2006 Baja Turbo
Originally Posted by Patrikman View Post
Did we ever get conformation of 2009 STi struts being a direct fit?
Ya did we?
Mrcrowley206 is offline   Reply With Quote
Old 04-09-2017, 05:49 PM   #254
Mrcrowley206
Member#: 465342
2006 Baja Turbo
Old 07-25-2017, 03:13 AM   #255
jcmillet12
Member#: 331724
2015 wrx
Can anyone tell me if any of this thread applies to a 2003 subaru baja. I have owned mine since new but never bother to look for info until recently.
Also I need some body work done to it (a motorcycle hit me on the RR) and I need parts for it.
are all body panels matching for all years of the baja? I need the RR tail light, bumper cover, fender, fender cover and gas door cover.
jcmillet12 is offline   Reply With Quote
Old 07-27-2017, 10:07 AM   #256
Baja_Gernaut
Member#: 229922
2005 F-Inductd BAJA
rumble black
Default Baja Turbos: What works with What?
I believe all the models are same.
Baja_Gernaut is offline   Reply With Quote
Old 07-27-2017, 08:23 PM   #257
asalvo8
Member#: 236742
Default 3" cuts tower lift
Has anyone installed a 3" tower lift, and suddenly have a little problem with the power steering? When I turn the wheel feels like it hangs then loosens, then hangs and loosens. Power steering pump is pumping, hydraulic liquid was very black? Any suggestions.
asalvo8 is offline   Reply With Quote
Old 07-27-2017, 08:28 PM   #258
asalvo8
Member#: 236742
What are the simptoms on your passenger axle? Does your steering wheel hang then let's go?
Old 07-30-2017, 06:10 PM   #259
Baja_Gernaut
Member#: 229922
2005 F-Inductd BAJA
rumble black
I flushed my power steering not too long ago and it feels a lot better. Go in YouTube and search for subaru power steering flush. It's real simple. You got nothing to lose because that oil is black anyway
Old 07-31-2017, 11:33 AM   #260
asalvo8
Member#: 236742
Default Thanks
Thanks, after replacing a bad cv axle, ps fluid, found the problem to be the rack and pinion coupling was starting to freeze. Sprayed on pb penetrating blaster on the cross members and it's working like new. Total cost of fix 3.99 on sale at oreillys.
Old 09-06-2017, 09:53 PM   #261
deuter
Member#: 416291
Default CV axle
Hi All,
I just wanted to input in my experience with the CV axle problems. I had similar problems with the local auto parts stores. Hopefully my post will help someone avoid the same headaches I was having. It was getting confusing with turbos vs non-turbos as well as manual vs automatic transmissions.
I used this PART #: 1AACV00109 from 1A Auto.
http://www.1aauto.com/subaru-cv-axle...=731649&y=2005
I used this in a 2005 Subaru Baja Turbo with Manual transmission. It fit perfectly.
Best,
Tim
Austin
deuter is offline   Reply With Quote
Old 09-08-2017, 10:48 PM   #262
Patrikman
Member#: 234499
2004 Outbrat XT
Regatta Red/Silverstone
Originally Posted by deuter View Post
Hi All,
Best,
Tim
Austin
I'd only use OEM axles, and I'd use the Forester XT part number.
Patrikman is offline   Reply With Quote
Old 09-12-2017, 10:45 AM   #263
Mrcrowley206
Member#: 465342
2006 Baja Turbo
Should the same model year be used? like 06' Baja uses 06' forester xt axle?
Old 09-12-2017, 10:47 AM   #264
Mrcrowley206
Member#: 465342
2006 Baja Turbo
Oh and Sub002 AP doesn't work with stock ECU. Some early post said it does.
Old 09-13-2017, 10:12 AM   #265
Mrcrowley206
Member#: 465342
2006 Baja Turbo
Originally Posted by honda killer View Post
Axles:
Turbo Baja use axles from the 2004 Forester XT.
The axles listed for the Baja Turbo at O'Rielly, Auto Zone, & Pep Boys is wrong. I've been fight with them to up fate there system.
Sent from my iPhone using Tapatalk
What year Baja or does it not change from 03-06'?
Old 09-13-2017, 10:13 AM   #266
Mrcrowley206
Member#: 465342
2006 Baja Turbo
06' Baja, does it matter what year forester? 06'? 04'?
Old 09-13-2017, 10:56 AM   #267
Benhart21
Member#: 149617
There's a ton of posts saying you use the ECU out of an '04 Forester XT if you want to use an AP.
Benhart21 is offline   Reply With Quote
Old 09-15-2017, 09:00 AM   #268
Mrcrowley206
Member#: 465342
2006 Baja Turbo
Yeah I bought an 06 sti ecu to utilize it. I only saw the post on this thread that said it worked with stock ECU.
Old 09-15-2017, 06:43 PM   #269
Benhart21
Member#: 149617
The problem with that is that they started using keys with immobilizers in '05.
Old 09-25-2017, 08:44 PM   #270
Patrikman
Member#: 234499
2004 Outbrat XT
I can only assume it would be the same, the Forester XT used the same platform from 2003-8 so you should be good with whatever. I don't know for sure though, I'd feel safer saying 2003&2004 though.
Old 10-21-2018, 03:34 PM   #271
Threebones
Member#: 493009
Default Hood scoop
I have an 05 Baja Turbo is there a direct replacement off say a legacy that would work? I would really like a carbon fiber one
Threebones is offline   Reply With Quote
Old 02-24-2019, 09:49 AM   #272
srtings184
Member#: 472381
2004 WRX
Anybody got anything on the AT turbo transmissions? Any other models interchangeable?
srtings184 is offline   Reply With Quote
Old 03-03-2019, 06:20 PM   #273
SpyrouBaja
Member#: 498559
2006 Baja
Default 2006 Baja Seats
looking into replacing seats in my '06 Baja. Anybody selling or have recommendations?
SpyrouBaja is offline   Reply With Quote
Old 03-13-2019, 02:37 AM   #274
Chi_San
Member#: 53558
2005 Baja Turbo
White/Silver/Black 3tone
A replacement what?
Anything that fits a Legacy/Outback from 2004 should drop right in.
Chi_San is offline   Reply With Quote
Old 03-23-2019, 02:52 PM   #275
Flowmastered87GL
WCSS Drunk
Member#: 8914
2005 Baja Sport
Regal Blue Pearl
In general 1993-2007 Impreza or WRX stuff will fit in the front.
1995-2004 Legacy and Outback should fit (unsure of 90-94) the front.
Rear would be closest to a 2000-2004 Legacy or Outback wagon.
Flowmastered87GL is offline   Reply With Quote
clutch and flywheel what works with what?!?! scobaru Subaru Conversions 10 01-06-2005 10:21 PM
What Works with Borla Hush? HerculesPeanut Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 06-28-2004 04:21 PM
ej20's and what works with what scobaru Subaru Conversions 4 10-24-2003 07:28 PM
Advan RG works with what brakes??? Subaruist Brakes, Steering & Suspension 1 10-22-2002 11:23 PM
Which cold air intakes work with what FMICs? Diversion Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 07-15-2002 07:55 AM
