Welcome to the North American Subaru Impreza Owners Club Saturday January 20, 2018
Old 09-07-2017, 04:39 PM   #1
Ishbu0062
Member#: 375051
2016 WRX STi
Default Will the 2018 STI brakes work with the 2015-2017 STI
Just being curious if the 2018 STI brakes will work on a 2015-2017 STI and if it will clear the 18 inch wheels.
Tried to research on google but couldn't find anything definitive or even if someone tried test fitting them.
Once again, just being curious.
Ishbu0062 is offline   Reply With Quote
Old 09-07-2017, 04:54 PM   #2
mustard tiger
Member#: 238531
The 2018 STI brakes will clear the 2015-17 base Enkei 18" rims as in Canada they are still the same base wheels for 2018 STI.
mustard tiger is offline   Reply With Quote
Old 09-07-2017, 05:22 PM   #3
Ishbu0062
Member#: 375051
2016 WRX STi
Same base wheels as in manufacturer? The 2018 STI has 19 inch wheels and the 2015-2017 STI has 18 inch wheels and the 2018 STI has the 6 pot front brakes so I'm just curious to see since the brakes are bigger will they clear the 18 inch wheels
Old 09-07-2017, 09:27 PM   #4
Momo1970
Member#: 448344
2016 WRX CVT
Will they fit 2015-17 WRX which are also 18"?
Momo1970 is offline   Reply With Quote
Old 09-07-2017, 09:29 PM   #5
gaugeof12
Member#: 132859
2015 WRX
CWP
In Canada only the upper trim STi got the 19s. So yes, the new brakes will at least clear the OEM 18's.
gaugeof12 is offline   Reply With Quote
Old 09-08-2017, 07:14 AM   #6
rtv900
Member#: 428511
2016 STI
But is the caliper mount the same?
because the new caliper would have to be used since the 15-17 ones fits a smaller rotor.
rtv900 is offline   Reply With Quote
Old 09-08-2017, 10:24 AM   #7
gaugeof12
Member#: 132859
2015 WRX
CWP
This thread has a little more info, however I dont think anyone knows for sure yet. If i was betting I would put my money on needing a bracket like the Brembo GT kit to make it work on anything else.
https://forums.nasioc.com/forums/sho....php?t=2849217
Brembo GT kit...
https://www.rallysportdirect.com/par...slotted-rotors
Old 09-08-2017, 12:20 PM   #8
car_freak85
Member#: 13530
EA63 , EA81T, EJ20G,
EJ205
If I were betting I would say that an OEM like Subaru could ask nicely and Brembo would design the new 6-pot calipers to bolt onto the existing STI steering knuckle.
Cheaper to have a supplier design a new product around your existing hardware than to adapt something and have to deal with a potential warranty/recall issue down the road.
car_freak85 is offline   Reply With Quote
Old 09-09-2017, 01:11 PM   #9
gaugeof12
Member#: 132859
2015 WRX
CWP
I have to admit you are likely correct. Especially after some additional reading that many think these are the same 6 pots used on special edition STis in Japan since 2008.
Old 09-10-2017, 03:31 AM   #10
jdmct9mr
Member#: 289223
2015 STI
CBS
I asked Ravspec a similar question. I recently picked up some 18X10 +40 CE28SL's for my 15 STI. If I remember correctly, they stated that the new 6 piston caliper was longer but more thin if that helps or makes any sense.
I asked because I was debating on selling my 15 STI to get a 18 STI and wanted to know if my new Volks would clear or not. They said they should clear the new 18 STI brakes.
jdmct9mr is offline   Reply With Quote
Old 09-11-2017, 09:13 AM   #11
Ishbu0062
Member#: 375051
2016 WRX STi
Brembo GT kit...
That actually brought more insight. The video they showed, the guy stated that his set of 18s were able to clear the rotors.
Thanks for the vid
Old 09-11-2017, 04:23 PM   #12
jamal
Member#: 71875
I'm about 99.9% sure the calipers have the right tabs to bolt to the uprights without any adapters, and that nothing changed with the upright from 2017.
Wheel clearance, someone would have to try. 18" sti wheels, likely.
Buying the OEM parts would be $texas.
jamal is offline   Reply With Quote
Old 09-11-2017, 10:28 PM   #13
grex07
Member#: 167116
2013 STi 5Dr
grex07 is offline   Reply With Quote
Old 09-12-2017, 01:19 PM   #14
aggarcia
Member#: 330146
2018 STI Limited
Pure Red
$4k for the front 6 piston caliper/rotor upgrade and $5800 for both front and rear STI brake upgrade. That's some serious money for a big brake kit.
aggarcia is offline   Reply With Quote
Old 09-12-2017, 03:05 PM   #15
grex07
Member#: 167116
2013 STi 5Dr
Ya, brembos aint cheap. You could prob source the calipers separate and get the rotors and pads for cheaper.
Old 09-12-2017, 04:01 PM   #16
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Actually, most likely not.
The kits usually wind up costing you less, as long as you are using the same quality components.
Old 09-13-2017, 11:18 AM   #17
grex07
Member#: 167116
2013 STi 5Dr
The calipers are $1k each from subaru. Getting pads and rotors for under $2k should be easy.
Old 09-13-2017, 11:41 AM   #18
Plecain
Member#: 453598
2017 WRX Base
Red
It wouldn't cost a huge amount more to trade in my 2017 WRX and get a 2018 STI.
Fortunately my state has no sales tax so I don't need to worry about that.
Plecain is online now   Reply With Quote
Old 09-13-2017, 11:43 AM   #19
Plecain
Member#: 453598
2017 WRX Base
Red
Probably true.
I wouldn't want the drilled rotors on a street car anyway.
Old 09-13-2017, 12:23 PM   #20
rtv900
Member#: 428511
2016 STI
Originally Posted by Plecain View Post
Probably true.
why?
they look cool as hell
Old 09-13-2017, 12:34 PM   #21
Samurai Jack
Member#: 21145
2002 Enemy of Aku
I'm surprised the 6-pot calipers are not more than $1000 each. I thought they would be more like $1500 each
Old 09-13-2017, 02:32 PM   #22
Plecain
Member#: 453598
2017 WRX Base
Red
Originally Posted by rtv900 View Post
why?
I had them on a 911 Turbo (stock). They warp and crack much more easily than a grooved disk if you use them hard.
