Welcome to the North American Subaru Impreza Owners Club Tuesday May 21, 2019
Old 02-16-2016, 01:10 PM   #451
Labelkilss
Member#: 440576
Originally Posted by Unabomber View Post
Congrats on your new car and welcome to the forums!
Now before you start posting, please keep the following in mind:
1. Your car is brand new. Yes, it's just a new year, but for all intents and purposes, it might as well be a Jeep Cherokee as pretty much 100% of the car is new.
2. Will XXX fit my car? Probably not. The turbo is different, the intercooler is different, the exhaust is different, etc.
3. When will manufacturers start making XXX parts? We don't know, please bug the manufacturers.
4. I found XXX parts that will fit, can I bolt them up? Your best bet is to wait for engine management before you start bolting up things. Each car has something called open/closed loop fueling issues mandated by the EPA that can negatively affect vehicle modifications. The wise/safe course of action is to wait for engine management then modify. Yes, you can probably safely get away with simple mods, but the smart thing to do is engine management first, then parts.
5. But I found out that XXXX from an older Subaru will fit on my 2008. Well post that crap here and we'll update this for all to see.
If anyone sees anything to add, please post. The genesis behind this post is to prevent 9000 posts of will XXX fit my 2008. This is an annual annoyance and I'm hoping this may stem some of that.
Old parts that WONT fit:
Exhausts
TMICs
FMICs
Rear sway bars
Intakes for Legacy GT
Old parts that WILL fit:
Downpipes for Legacy GT
BPV/BOV for Legacy GT
Lightweight crank pulley
short throw shifters/bushings
front sway bar
TMIC for Legacy GT
FMIC for Legacy GT (may have to mod to fit)
Turbos for Legacy GT
Clutch and flywheel
THIS LINK contains a huge list of parts that will fit 08/09 cars
STI Exhausts that will fit
Thank you
Labelkilss is offline   Reply With Quote
Old 09-22-2016, 05:30 PM   #452
Subimatt365
Member#: 455146
I've gone through two turbos in the past two weeks. Really don't get it
Subimatt365 is offline   Reply With Quote
Old 10-23-2016, 05:04 PM   #453
MrTickleBottoms
Member#: 380455
Was the second turbo new?
MrTickleBottoms is offline   Reply With Quote
Old 11-07-2016, 08:28 PM   #454
adam sti
Member#: 457414
2004 STi
motor blew at 20k miles
adam sti is offline   Reply With Quote
Old 06-19-2017, 01:05 PM   #455
cannibalcorpuscle
Member#: 431111
2008 WRX 5-door
Default possible update to "WILL fit" list
Exhausts
TMICs
FMICs
Rear sway bars
front sway bar
TMIC for Legacy GT
Clutch and flywheel
Skimmed through and noticed no one's pointed out the 08+MY has a redesigned shift assembly. From personal experience I can tell you a pre-08 shifter won't fit because of an increase to the ball diameter for the shifter pivot point. As for the plastic cup used for the pivot point... a pre-08 cup has a greater height, as well as a smaller diameter, than 08+MY and also doesn't fit properly. Pulled an adjustable SS (05MY) from the boneyard so maybe the trouble started there but that's my $0.02 in hopes hopes of saving someone a headache.
2008 WRX 5-door for anyone wondering.
cannibalcorpuscle is offline   Reply With Quote
Old 08-03-2017, 01:11 AM   #456
CaverSubie
Member#: 472190
I'm doing this so I can post..
CaverSubie is offline   Reply With Quote
Old 08-03-2017, 01:11 AM   #457
CaverSubie
Member#: 472190
Same reason
Old 08-03-2017, 01:11 AM   #458
CaverSubie
Member#: 472190
And again...
Old 08-28-2017, 09:29 AM   #459
640k
Member#: 160315
2008 STI
so my 08 dieded... should i fix or sell?
640k is offline   Reply With Quote
Old 09-20-2017, 09:46 PM   #460
Usmc75
Member#: 469554
Hey i own a 2012 subaru wrx sedan and Iíve been looking all over the web to find out what type of stock turbo is on my wrx. Is it a VF22, VF34 ...etc not of the above?
Thank you .
Usmc75 is offline   Reply With Quote
Old 09-20-2017, 10:31 PM   #461
Stretch18
Member#: 239822
2010 WRX
pandiculation
Thank you .
Vf52...
Stretch18 is offline   Reply With Quote
Old 09-21-2017, 07:39 AM   #462
Usmc75
Member#: 469554
Originally Posted by Stretch18 View Post
Vf52...
Hey stretch18 thank you, as a Subaru owner I should know this but kinda new to the Subaru game and searched everywhere for the specs.
Thanks again!
Old 05-23-2018, 10:50 AM   #463
dmac28
Member#: 486314
One down...
dmac28 is offline   Reply With Quote
Old 10-08-2018, 11:54 PM   #464
ObsidianDiesel
Member#: 492496
Exhausts
TMICs
FMICs
Rear sway bars
front sway bar
TMIC for Legacy GT
Clutch and flywheel
Thanks for this 👍🏻
ObsidianDiesel is offline   Reply With Quote
Old 01-19-2019, 07:23 PM   #465
RaPower
Member#: 496698
2007 WRX Wagon
New to posting. Thank you for info
RaPower is offline   Reply With Quote
Old 04-05-2019, 01:44 AM   #466
Gally316
Member#: 494541
Any updated link for list of parts that will fit 08/09 cars? Old link is no good.
Gally316 is online now   Reply With Quote
Old 05-04-2019, 08:52 PM   #467
Danman20
Member#: 501185
Default New to subie
Just wanted to know I just had and oil change in my 2013 subie Impreza wrx hatch full synthetic oil and everything should I not add oil stabilizer to the high performance synthetic oil in there
Danman20 is offline   Reply With Quote
2000 Legacy GT owners please read... Dr. Spud Funk Legacy Forum 1 06-04-2001 08:32 PM
HID owners please read wop Interior & Exterior Modification 3 12-28-2000 09:16 AM
4 door 2.5RS owners please read wop General Forum Archive 10 10-31-2000 12:00 AM
Tein Owners....Please Read! SCOOBER Brakes, Steering & Suspension 10 10-21-2000 07:01 AM
Minnam Kit FYI - Turbo weight and your header - Minnam kit owners please read. Geoff Technical Forum Archive 1 09-19-2000 09:51 AM
