#1 |
Member#: 198281
Vehicle:2005 WRX/STi WRB of course |
![]() You may have heard the rumors, or even seen a sneak peek at one of the events we attended this summer, but it's true... We have started production.
New for 2017 Killer B Motorsport V4 Cast Aluminum Performance Oil Pan Features: • Track Tested High Performance Oil Pan • Thick Walled Aluminum throughout • Advanced Heat Treatment for Improved Toughness and Strength • Machined FLAT Flange Surface for Leak Free Installs • Precision Machined Mounting Holes • 6 quart capacity • M20 Port (OEM) • 1/2NPT Port • Uses OEM Dipstick Tube • Includes Hardware Let me know if anyone has any questions ![]()
#2 |
Member#: 437417
W. Canada
Vehicle:2004 Wrx silver |
#3 |
Member#: 198281
#4 |
Member#: 402977
SCIC
![]() what is the difference in this and your current model (assume both for ej25)
#5 |
Member#: 9960
Vehicle:2002 Impreza WRX WRBlue Perl |
![]() Since these are now cast, are they going to be cheaper than the current welded units?
#6 |
Member#: 71721
Vehicle:98 RSTi, 00 RS 13 Sierra |
![]() Yesssssssssssssss! Racecar was in need of an upgrade!
#7 | |
Member#: 198281
![]() Quote:
A good comparison is look at our intercooler end-tank inlet/outlet. We can have a horn shape taper at the edge, a thinner wall provides a larger opening (more flow), and the thin wall means better exposure with less turbulence going into and out of the core. For the pan is means no tapered walls, which means no compromise to oil capacity, and an small improvement in strength, without a significant weight tax. From a performance perspective, there's no change. Both versions can handle anything you can throw at them. The cast pan is now our mainstream product, but we are still making the weld-porn fabricated on a made-to-order basis. |
#8 | |
Member#: 71721
![]() Quote:
Perfect. I'm speculating here, but since you're starting to really dip into cast aluminum fab and are more race-centric are you going to possibly focus a little on the rear of our cars in the near future... you know in the diff area ![]() |
#9 |
Member#: 397836
Vehicle:2015 WRX STi Lightening Red |
![]() Are these shipping already with your 3-piece ej25 pickup, pan and baffle? Thanks
#10 | |
Member#: 198281
![]() Quote:
Yes they are! |
#11 | |
Member#: 9960
![]() Quote:
#12 | |
Member#: 198281
![]() Quote:
Castings require a material cert at melt (samples for the mass spectrometer), the pour, band-saw trimming gates/vents/etc., x-ray inspection, grinding gates/vents/flashing/etc. flush and any other abnormalities, inspection, heat treat to T5, test, heat treat to T6, test, bead blast, then off to machining, post machining inspection reports, welding the baffles, final fitment and QC checks, then washing. With the previous process the sheetmetal certs from the supplier (made in the USA of course), laser cut, inspected, CNC brake, inspected, fit-up, welding, finishing, final fitment and QC checks, etching, and washing. We are trading labor for materials and process. The costs are within a few dollars of each other (not including the +$30K we've got into casting tooling costs). The fabricated version price will go up though (and only available directly through us), since they will no longer be production batch made, but instead MTO, so there are losses in productivity. |
#13 | |
Member#: 437417
W. Canada
![]() Quote:
#14 | |
Member#: 198281
![]() In my opinion this is an absolutely critical step, especial early on when you're optimizing gates, vents, etc... The casting software simulations have come a HUGE way since they first came out, but nothing replaced real world testing and verification.
#15 | |
Member#: 269226
![]() Quote:
Billet is just a huge chunk of cast metal. |
#16 |
Member#: 397836
#17 | |
Member#: 437417
W. Canada
![]() Quote:
#18 |
Member#: 90539
South East
Vehicle:My BOV goes COVFEFE! |
![]() Gummy bears are awesome, and so are KillerB parts
#19 |
Member#: 29292
SCIC
Vehicle:2004 WRX wagon silver |
![]() So.. how much are these?
#20 |
Member#: 311555
Vehicle:2011 WRX STI Dark Gray Met |
![]() Wow some manufacturing experts maybe should build there own! Just my 2 cents billet has to be cast first before it can be rolled or forged.
And the quality of a cast is totally dependent on the person and process doing the cast. Last but not least, go buy that other companies cast aluminum subie oil pan if you think your getting ripped off. Oh wait what company was that? |
#21 |
Member#: 13530
Vehicle:EA63 , EA81T, EJ20G, EJ205 |
#22 |
Member#: 90539
South East
![]() -When will it be on your site so we can check cost?
(edited, somehow missed the capacity) Last edited by 2slofouru; 10-29-2017 at 08:35 PM. |
#23 |
Member#: 90539
South East
![]() -Is it lower down than the oem pan / less ground clearance?
-Does the oil pickup tube have to use adapters to lower like on your other oil pan? -What do the internal baffles look like? |
#24 | ||
Member#: 198281
![]() No casting is perfect. If you've seen enough billet, even it can have imperfections. The casting process we use produces parts on the high end of the casting scale in regards to capabilities and quality. At this point we've processes just under 500 units and there were 2 units that had a visible void beyond my comfort level. So we hit them with the TIG torch to see how they react. So far, it's been uneventful, adding a dab of filler rod and all is good. a 'bad' void will have contaminants or may be so deep it can blow through the thickness once you apply heat. We've not seen this yet.
As far as QC goes, the parts pass through several hands for visual inspection and x-ray inspection. Anything questionable gets evaluated to determine a coarse of action; back into the pour, scrap, or rework. Having worked with many castings over the years, I am really impressed with the process. As far as durability goes, I would say these are stronger than our fabricated version. Same price. The fabricated pans will be having a price increase probably around the 1st of the year. They take a ton of time to make. Yes they did. It was widely accepted too. Quote:
Yes. It still fit under the OEM bellypan though ![]() Quote:
Same as on the fabricated units, flow through style. This design performs much better than anything we've ever seen or have test data on. The flat baffles (or worse baffle plates sandwich between pan and block) are horrible, some performing worse than OEM. |
#25 |
Member#: 90539
South East
![]() Cool deal. Anyone have a photo of one installed yet, and ground clearance?
