Welcome to the North American Subaru Impreza Owners Club Saturday February 24, 2018
Old 10-12-2017, 02:52 PM   #1
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Default xluben's 2010 Subaru STI SE | Project Dark Knight 2.0
Car: 2010 Subaru STI SE
Engine: IAG Closed Deck EJ257
Turbo: ETS Rotated Kit with PTE 6466
Transmission: Stock STI 6MT
Body Style: 5 Door Hatchback
Color: Obsidian Black Pearl
Old 10-12-2017, 02:52 PM   #2
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Engine:
  • IAG Closed Deck 2.5L Case
  • IAG Pinnned Mains
  • IAG Cylinder O-Rings
  • IAG 14mm Head Studs
  • OEM Subaru Crank
  • Cosworth Head Gaskets
  • Manley 99.75mm Pistons
  • Manley Turbo Tuff I Beam Rods
  • King Rod and Main Bearings
  • OEM 2010 STI Heads
  • BC Stage 3 (280) DAVCS Camshafts
  • BC Stock Size Valves
  • GSC Beehive Springs w/Retainers
  • Aluminati Solid Billet Motor Mounts
Intake/Exhaust/Fuel:
  • Precision 6466 Turbo
  • MAPerformance 4-1 EL Header
  • FobiaFab Gate Dump on Header Secondary
  • TurboSmart 40mm HP EWG (35psi)
  • ETS Rotated Uppipe and Downpipe
  • Invidia Q300 Catback
  • ETS 4" Intake and Filter
  • ETS 3.5" FMIC Kit
  • TurboSmart Race Port BOV
  • Radium Dual Pump Hanger
  • Dual AEM 50-1200 E85 320LPH Pumps
  • -8AN Fuel Feed Lines
  • -6AN Fuel Return Lines
  • ID1700cc Injectors
  • IAG Fuel Line Kit
  • Aluminati Billet TGV Deletes
  • Aluminati Billet Fuel Rails
  • TurboSmart FPR 1200
Drivetrain/Transmission
  • Stock STI 6 Speed
  • Kartboy Short Shifter
  • Anarchy Motive Shift Knob
  • Aluminati Solid Billet Tranny Mount
  • Aluminati Solid Billet Pitch Stop Mount
  • ACT HD Pressure Plate
  • ACT 4 Puck Disk
Suspension/Wheels:
  • Konig Hypergram 17x8" +35, 16.3lbs (Winter)
  • Hankook i-Pike Snow Tires (Winter)
  • Konig Rennform 17x8" +35, 17lbs (Summer)
  • Summer Tires - TBD
  • Lowering Springs
Interior/Electronics:
  • COBB AccessPort V3
  • ProSport EVO Oil Pressure Gauge
  • AEM Wideband O2 Gauge
  • FlexConverter E85 Sensor
  • Odyssey PC680 Battery Relocated
Exterior:
  • OEM Mesh Grill
  • Black Front Lip
  • Black Headlight Housings
  • Black Taillight Housings
  • Window Tint
  • Debadged
https://forums.nasioc.com/forums/sho....php?t=2078765
https://forums.nasioc.com/forums/sho....php?t=2528768
Old 10-12-2017, 02:53 PM   #3
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Save 2
Old 10-12-2017, 02:53 PM   #4
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Save 3
Old 10-12-2017, 02:53 PM   #5
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Save 4
Old 10-12-2017, 03:16 PM   #6
zohh_amaze
Member#: 158592
2004 4Runner V8
Oh god, here we go...
zohh_amaze is offline   Reply With Quote
Old 10-12-2017, 03:21 PM   #7
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
After previously having a 2011 WRX and then a 2002 WRX (with cage, seats, harness, etc) I decided I wanted to go back to the GR chassis and build something more street/daily friendly. I started looking and eventually found a 2010 STI SE Hatch in TX. I was originally looking at WRX's (planning to swap my 6 speed over), but it was the color and body style I wanted and at a good price.
The car was previously built and then taken back to stock with a motor from a totaled car with supposedly only 20k miles. It included a few items that I would have likely purchased anyways (COBB AP, fuel, clutch, etc). I flew down to TX and then drove the car back to MN. It was just over 1,000 miles and I made 3 stops along the way. It took around 16 hours to drive it back (including the stops).
Here are some more photos from along the trip.
Old 10-12-2017, 04:14 PM   #8
Obviously Tyler
Member#: 395955
2016 WRX Premium
Rock Chip Metallic
Looking forward to this one.
Obviously Tyler is offline   Reply With Quote
Old 10-12-2017, 04:32 PM   #9
TDagen
Member#: 163648
2002 Resurrected WRX
Bad ass. Long drive but well worth it.
TDagen is offline   Reply With Quote
Old 10-12-2017, 04:57 PM   #10
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
Was this why the Bugeye went up for sale?
Looking forward to seeing progress here as well!
Old 10-13-2017, 08:38 AM   #11
LeMikeJames
Member#: 460881
2018 WRX Limited
Cool - looks awesome.
Assuming you meant to put Obsidian Blank Pearl?
LeMikeJames is offline   Reply With Quote
Old 10-14-2017, 12:42 PM   #12
Bnuts01
Member#: 293328
Damn Daniel. Back at it again?
Bnuts01 is offline   Reply With Quote
Old 10-16-2017, 11:17 AM   #13
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Thanks all. Yes a long drive, but worth it for a rust free car at the right price, and had some useful things already on the car.
Bugeye wasn't getting much use after the race car items were added so I decided to go back to what was most enjoyable - street car. And black GR was my preference. Still have the Bugeye and have only sold a few things. Need to decide what to keep and what to part out.
I meant Black. Looks like autocorrect might have gotten you too. Haha.
Old 10-16-2017, 11:21 AM   #14
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Here's a set of better photos that I took over the weekend.
Old 10-16-2017, 11:29 AM   #15
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Since then I swapped the tail lights for stock ones. No photos yet. Hoping to get red overlays at some point. I also updated the feed and return line routing from the rail to FPR. I am working on getting some more parts together and then getting it tuned.
Before: -8AN Feed into FPR, FPR to Stock Rail Feed and to -6AN Return to Tank, Stock Rail Return Capped Off
After: -8AN Feed into Stock Rail Feed, Stock Rail Return to FPR, FPR to -6AN Return to Tank
Before:
After:
Old 10-17-2017, 04:28 PM   #16
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Installed some parts last night.
Aluminati Air Pump Deletes
ID1000 Injectors (Already Installed)
Invidia Catless 2 Bung Downpipe
COBB AP V3 (Already Installed)
GrimmSpeed Gaskets for DP Install
I was able to install some parts last night. Went to install injectors and found that the car already had ID1000 installed, so I left them. Should be plenty for now. Then I moved onto the air pump deletes and it was a much bigger pain than I remembered. Driver's side wasn't too bad, but I ended up leaving the passenger side and blocking it off on top. I will remove at a later date. Also had to cut the atmospheric sensor out of the driver's side solenoid.
After that I pulled off of the stock downpipe and put on the Invidia catless. Used GrimmSpeed gaskets instead of the included Invidia one. It all bolted up without issue. I also took photos of the COBB AP while I had other parts in the photo studio. Going to try and get a few more parts on and then hopefully get things sorted out to go to the track this weekend (last weekend anything around here is open). All pending weather and getting the car running well.
Old 10-17-2017, 05:07 PM   #17
taxkourel
Member#: 333315
I have read every single page of Dark knight version 1 and canít wait to see this one out on the streets of the Twin Cities area!If you ever see a grey 09 WRX waving like a madman it will be me!!!
taxkourel is online now   Reply With Quote
Old 10-17-2017, 05:08 PM   #18
Dave D.
Member#: 130990
06 Red Ltd.Wagon
The Memo!
Engine: Stock EJ257
Turbo: Stock VF48
More to come...
Expecting 8's before this is over.
Old 10-17-2017, 09:42 PM   #19
baggedhawk
Member#: 344203
Did you have to tune the air pump delete?
baggedhawk is offline   Reply With Quote
Old 10-18-2017, 07:57 AM   #20
my9999
Member#: 319314
Makes no difference to tune. Its just for cold start emissions.
Removing Airpump though will require disabling the CEL's
@xluben Very nice
my9999 is offline   Reply With Quote
Old 10-18-2017, 10:20 AM   #21
TDagen
Member#: 163648
Quick question. Do you have any certain reason or reasons for choosing the GR platform to build your street/daily besides having the 2011 prior and liking it? Possibly better ride quality or something?
Old 10-18-2017, 10:47 AM   #22
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Will do!
Not likely. The difference between mid 9's and getting into 8's is a lot of money and a lot of broken parts. That's one of the main reasons I decided not to continue forward with the Bugeye project. It felt like that was the point of diminishing returns. Probably even high 9's would have been the most reasonable point to stop when considering cost and the ability to make multiple passes without something failing.
@xluben Very nice
Correct. No specific tuning, but CEL's need to be disabled.
Basically came down to this:
  1. Nostalgia
  2. Wanted a hatchback
  3. Like the GR looks
Old 10-18-2017, 11:09 AM   #23
Dalessio
Member#: 358693
2015 WRX
  1. Nostalgia
I completely understand that, I'm considering ditching my '15 for another GR, I miss it.
Dalessio is offline   Reply With Quote
Old 10-18-2017, 11:12 AM   #24
Obviously Tyler
Member#: 395955
2016 WRX Premium
Rock Chip Metallic
Your parts photos are always so good. They're my favorite part of your build threads.
Old 10-19-2017, 02:50 AM   #25
JLEET
Member#: 357043
2013 WRX HATCH
PBP
Yay! Found it! A reason for me to get back on Nasioc!
JLEET is offline   Reply With Quote
