Welcome to the North American Subaru Impreza Owners Club Sunday February 28, 2021
Go Back   NASIOC > NASIOC Classifieds > New Product Development
Old 07-19-2017, 04:58 PM   #1
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Default Killer B Motorsport V4 CAST Performance Oil Pan
You may have heard the rumors, or even seen a sneak peek at one of the events we attended this summer, but it's true... We have started production.
New for 2017 Killer B Motorsport V4 Cast Aluminum Performance Oil Pan
Features:
Track Tested High Performance Oil Pan
Thick Walled Aluminum throughout
Advanced Heat Treatment for Improved Toughness and Strength
Machined FLAT Flange Surface for Leak Free Installs
Precision Machined Mounting Holes
6 quart capacity
M20 Port (OEM)
1/2NPT Port
Uses OEM Dipstick Tube
Includes Hardware
Let me know if anyone has any questions
Old 08-30-2017, 12:38 AM   #2
boostinsticnd
Member#: 437417
2004 Wrx
makes for hard welding oil returns now
boostinsticnd is offline   Reply With Quote
Old 08-30-2017, 01:17 PM   #3
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Nah. Welds the same as the sheetmetal pans
Old 08-31-2017, 01:57 PM   #4
Twisty mountain road
Member#: 402977
what is the difference in this and your current model (assume both for ej25)
Twisty mountain road is offline   Reply With Quote
Old 09-01-2017, 08:41 PM   #5
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
Since these are now cast, are they going to be cheaper than the current welded units?
jigga is offline   Reply With Quote
Old 09-01-2017, 08:49 PM   #6
Aczwild
Member#: 71721
98 RSTi, 00 RS
13 Sierra
Yesssssssssssssss! Racecar was in need of an upgrade!
Aczwild is offline   Reply With Quote
Old 09-02-2017, 11:01 AM   #7
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
We're not a company known for doing anything on the cheap. The advanced casting process we use allows for thinner, stronger, and lighter products.
A good comparison is look at our intercooler end-tank inlet/outlet. We can have a horn shape taper at the edge, a thinner wall provides a larger opening (more flow), and the thin wall means better exposure with less turbulence going into and out of the core.
For the pan is means no tapered walls, which means no compromise to oil capacity, and an small improvement in strength, without a significant weight tax.
From a performance perspective, there's no change. Both versions can handle anything you can throw at them. The cast pan is now our mainstream product, but we are still making the weld-porn fabricated on a made-to-order basis.
Old 09-02-2017, 12:47 PM   #8
Aczwild
Member#: 71721
98 RSTi, 00 RS
13 Sierra
Perfect. I'm speculating here, but since you're starting to really dip into cast aluminum fab and are more race-centric are you going to possibly focus a little on the rear of our cars in the near future... you know in the diff area
Old 09-04-2017, 06:19 PM   #9
eolivas
Member#: 397836
2015 WRX STi
Lightening Red
Are these shipping already with your 3-piece ej25 pickup, pan and baffle? Thanks
eolivas is online now   Reply With Quote
Old 09-04-2017, 08:13 PM   #10
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Rear end? Like what specifically?
Yes they are!
Old 09-07-2017, 02:57 AM   #11
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
I'm not insinuating that you are a company that does things on the cheap. I could only make the deduction that since you no longer have a skilled professional slaving over welding up these oil pans from individual pieces of aluminium, and you can now knock these things out like proverbial sausages, savings might be passed on to the consumer. Would you say that casting the oil pans is a more labour intensive process than your previous construction technique?
Old 09-07-2017, 08:17 AM   #12
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I think you are solely looking at material costs and assuming after the pour they are completed. There is far more process time that goes into the cast product than the fabricated version. The machine work requires a CNC operator with some experience, so you're also trading welding labor for CNC labor.
Castings require a material cert at melt (samples for the mass spectrometer), the pour, band-saw trimming gates/vents/etc., x-ray inspection, grinding gates/vents/flashing/etc. flush and any other abnormalities, inspection, heat treat to T5, test, heat treat to T6, test, bead blast, then off to machining, post machining inspection reports, welding the baffles, final fitment and QC checks, then washing.
With the previous process the sheetmetal certs from the supplier (made in the USA of course), laser cut, inspected, CNC brake, inspected, fit-up, welding, finishing, final fitment and QC checks, etching, and washing.
We are trading labor for materials and process. The costs are within a few dollars of each other (not including the +$30K we've got into casting tooling costs). The fabricated version price will go up though (and only available directly through us), since they will no longer be production batch made, but instead MTO, so there are losses in productivity.
Old 09-07-2017, 04:26 PM   #13
boostinsticnd
Member#: 437417
2004 Wrx
You are X-ray inspecting these? Have you found any defects? My earlier comment about harder to weld, Is the fact that cast is a dirty metal and much more difficult to weld, 90% of time cast isn't welded its replaced
Old 09-07-2017, 05:50 PM   #14
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
In my opinion this is an absolutely critical step, especial early on when you're optimizing gates, vents, etc... The casting software simulations have come a HUGE way since they first came out, but nothing replaced real world testing and verification.
It's not harder to weld? It requires some adjustments, but lots of cast aluminum things get welded, like our cast endtanks to our intercooler cores We make three different kinds of headers that use a cast collector section as well.
Old 09-07-2017, 09:10 PM   #15
spdracerut
Member#: 269226
A whole lot of sportbike motorcycle rear swingarms consists of cast pieces welded together.
Billet is just a huge chunk of cast metal.
spdracerut is offline   Reply With Quote
Old 09-08-2017, 11:52 AM   #16
eolivas
Member#: 397836
2015 WRX STi
Lightening Red
You are 50% correct, Billet is also formed by hot rolling as well as continuous casting.
Old 09-08-2017, 10:11 PM   #17
boostinsticnd
Member#: 437417
2004 Wrx
Have you found any defects in your castings yet?
Old 09-09-2017, 12:03 AM   #18
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Gummy bears are awesome, and so are KillerB parts
Old 09-09-2017, 01:24 AM   #19
subaru_gc8
Member#: 29292
2004 WRX wagon
So.. how much are these?
Old 10-02-2017, 02:24 PM   #20
hopsyn
Member#: 311555
2011 WRX STI
Dark Gray Met
Wow some manufacturing experts maybe should build there own! Just my 2 cents billet has to be cast first before it can be rolled or forged.
And the quality of a cast is totally dependent on the person and process doing the cast. Last but not least, go buy that other companies cast aluminum subie oil pan if you think your getting ripped off. Oh wait what company was that?
hopsyn is offline   Reply With Quote
Old 10-02-2017, 05:14 PM   #21
car_freak85
Member#: 13530
EA63 , EA81T, EJ20G,
EJ205
ARC made one.
car_freak85 is offline   Reply With Quote
Old 10-15-2017, 07:06 PM   #22
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
-When will it be on your site so we can check cost?
(edited, somehow missed the capacity)
Old 10-29-2017, 08:34 PM   #23
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
-Is it lower down than the oem pan / less ground clearance?
-Does the oil pickup tube have to use adapters to lower like on your other oil pan?
-What do the internal baffles look like?
Old 10-31-2017, 08:41 AM   #24
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
No casting is perfect. If you've seen enough billet, even it can have imperfections. The casting process we use produces parts on the high end of the casting scale in regards to capabilities and quality. At this point we've processes just under 500 units and there were 2 units that had a visible void beyond my comfort level. So we hit them with the TIG torch to see how they react. So far, it's been uneventful, adding a dab of filler rod and all is good. a 'bad' void will have contaminants or may be so deep it can blow through the thickness once you apply heat. We've not seen this yet.
As far as QC goes, the parts pass through several hands for visual inspection and x-ray inspection. Anything questionable gets evaluated to determine a coarse of action; back into the pour, scrap, or rework.
Having worked with many castings over the years, I am really impressed with the process. As far as durability goes, I would say these are stronger than our fabricated version.
Same price. The fabricated pans will be having a price increase probably around the 1st of the year. They take a ton of time to make.
Originally Posted by car_freak85 View Post
ARC made one.
Yes they did. It was widely accepted too.
If you buy through the site, you will get a cast pan. We're going to be updating the pics soon.
Yes. It still fit under the OEM bellypan though
Yes, when going to a deeper pan, the pickup needs to be brought down with it. We've been using this setup since ~2010 without issue.
Same as on the fabricated units, flow through style. This design performs much better than anything we've ever seen or have test data on. The flat baffles (or worse baffle plates sandwich between pan and block) are horrible, some performing worse than OEM.
Old 10-31-2017, 09:04 AM   #25
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Cool deal. Anyone have a photo of one installed yet, and ground clearance?
