Welcome to the North American Subaru Impreza Owners Club Monday September 23, 2019
Old 08-27-2017, 12:36 PM   #676
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
disappointment doesnt even describe it. first pass, i bogged..ok. adjusted rev limiter to 5k. second launch felt better then the clutch **** the bed again. right lane car 2295. i was doing 1.75 60 foots last year. 2nd time at track for the car
first
https://youtu.be/2peowHcAU4s
second
https://youtu.be/459zW4XDzPA
no694terry is offline   Reply With Quote
Old 11-05-2017, 07:15 PM   #677
wheeliesteve
Member#: 455200
2017 WRX
Default 2017 WRX full bolt-on's and Flex Fuel 12.7 1/4
wheeliesteve is offline   Reply With Quote
Old 11-06-2017, 09:47 PM   #678
taxkourel
Member#: 333315
Originally Posted by wheeliesteve View Post
Nice time! Mods and dyno results?
taxkourel is offline   Reply With Quote
Old 11-06-2017, 09:51 PM   #679
wheeliesteve
Member#: 455200
2017 WRX
My fist dyno results was 341/397 on a mustang dyno but he tuned it down and I dyno'ed again at 330/351. My mods are:
Process West Black Verticooler with Charge Pipe
IAG Street Series AOS
IAG TGV Deletes
IAG EGR Deletes
ETS Catted J-Pipe
ETS CAI with Air Box
Cobb EBCS
Cobb Flex Fuel Kit
AEM 320lph E85 Hi Flow In-Tank Fuel Pump
ETS Extreme Catback resonated exhaust with muffler deletes
Perrin Pitch Stop Mount including stainless steel clutch line
Kart Boy Pitch Stop
Perrin Transmission Mount
Perrin Motor Mounts
Perrin Shifter Stop
Perrin Brass Shifter Bushing
Perrin Short Shift Adapter
Raceseng Weighted Shift Knob
Cobb Access Port
Pro Tuned by Keith Fields at AWDTuning
Old 11-16-2017, 05:35 PM   #680
rayconlin97
Member#: 477827
2016 Wrx
Mint
2016 wrx Mikey Botti tuned video is on my Instagram @rayconlin97
Stock turbo,headers,internals,and clutch.
Tomei Expreme Ti Catback
Invidia Catless Downpipe
ETS Front Mount Intercooler 3.5in
ETS Intake with box
IAG AOS Street
IAG EGR Delete
Turbo XS TGV Delete
Grimspeed EBCS
Boomba BPV
Dw300c Fuel Pump
Cobb Flex Fuel
Cobb AP V3
rayconlin97 is offline   Reply With Quote
Old 05-15-2018, 08:06 PM   #681
Boss Paco
Member#: 176723
2005 WRX STi
Platinum Silver Metallic
I just wanna go fast.
Here's the footage:
It's a 2.1L pinned EJ205 with Crower 280s, PTE6466 targeting 42psi (boost gauge is off about 3psi) on 91 octane with Devil's Own methanol injection (50/50). There's STi drivetrain, a Competition triple disc, IAG output shaft, and DSS axles/carbon driveshaft. Car is full interior, AC, and I drive it often on the street.
It's made lots of 9.8 passes, and tons of bottom 10's. PB was 9.8 set a couple of weeks before this weekend where Friday we made a couple of low 9.8's, then on race day we got this 9.7. Super happy with the car. Hope to find a way deeper into the 9's.
--Boss Paco
Boss Paco is offline   Reply With Quote
Old 05-15-2018, 08:31 PM   #682
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
--Boss Paco
Got any pin pics. I pinned my 22e block. Never tried running 45psi on it though
Old 05-15-2018, 11:11 PM   #683
Boss Paco
Member#: 176723
2005 WRX STi
Six pins around each cylinder. Works well.
Old 07-10-2018, 12:00 AM   #684
MGigantelli44
Member#: 234591
2004 STI
MGigantelli44 is offline   Reply With Quote
Old 09-12-2018, 04:27 PM   #685
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
New PB for the car, this was on E85 (500whp/500wtq) with street tires still on the Gen 1 gtx3076 .82a/r. Car and driver weight is 3046 rolling down the track:
20180906_061733 by Bret Stevens, on Flickr
Scuby04STi is offline   Reply With Quote
Old 09-14-2018, 02:32 AM   #686
petersensignej
Member#: 490223
Cobb Stage 2 square, FP-18g turbo, 3" catless fumes, TurboXs TMIC, TurboXs tuned UTEC, STi injectors, walbro fuel pump, Perrin fuel rails, Perrin up-pipe, stock heads/cams, stock airbox, 4 gallons of 93 octane to 1 gallon 100 octane as a cushion.
petersensignej is offline   Reply With Quote
Old 10-14-2018, 09:42 AM   #687
AnthonyF24
Member#: 482700
2013 STi Hatch
I've only had the car for 6 months but im a drag racer at heart so I had to see what she could do. Consisten 13.2's but my fastest was a 13.1 @ 103 (only mod on car when purchased was the Injen Intake)
2013 STi Hatch
"Mods"
IAG TGV deletes
Catless DP
Agency Power mufflerless duals
Crawford AOS
Air Pump delete
Injen Intake
throttle body coolant mod
Cobb short Throw
Cobb AP v3
It was 80* with 78% humidity....yayyyy Georgia
AnthonyF24 is offline   Reply With Quote
Old 10-21-2018, 09:25 AM   #688
carnz-pj-410
Member#: 110994
1995 Turbo Impreza
4 other Subarus
1995 Subaru Impreza
2.0/2.5 Hybrid
JE Pistons
K1 Rods
Crower 264s
GSC Springs/Retainers
ID1300x2
AEM320 FP
Killer B Holy Header
Grimmspeed Uppipe
Custom Rotated Setup
Borg Warner S362SX-E .82AR Turbo
93 Octane
etc...
2004 STi 6MT with 07 3/4 gears
Comp Stage 2 Clutch
DSS Level 4 Rear Axles
225/45/17 Falken RT615K+ Tires @36psi
04 STi BBS
Didnt air down at the track, spun all thru first, didnt get a good launch. Comp clutch couldnt handle the torque and started to slip. ACT 6 puck is in and i will be going for 10s before the season is over
was about 52 degrees out at the track
carnz-pj-410 is offline   Reply With Quote
Old 02-16-2019, 12:30 PM   #689
DansharSti04
Member#: 458775
2004 Impreza WRX STI
World rally blue
Congrats!! Which street tires and size were you on for the run?
DansharSti04 is offline   Reply With Quote
Old 02-18-2019, 11:51 AM   #690
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
Toyo R888R's 235/40r17 with 36psi front 32 rear
Originally Posted by carnz-pj-410 View Post
1995 Subaru Impreza
2.0/2.5 Hybrid
JE Pistons
K1 Rods
Crower 264s
ID1300x2
AEM320 FP
Grimmspeed Uppipe
93 Octane
etc...
Comp Stage 2 Clutch
04 STi BBS
Ever make it back to the track last year?
Old 02-18-2019, 04:27 PM   #691
DansharSti04
Member#: 458775
World rally blue
[quote=Scuby04STi;45940991]Toyo R888R's 235/40r17 with 36psi front 32 rear
I have them on the list. How do you like them? Surprised they hooked at those pressures. Do you drive on them to the track and feel they can take you deeper in the 10s?
Old 02-18-2019, 09:38 PM   #692
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
I love them. Only thing I dislike is they look directional but are not, so one side of the car has backward looking tread. They are my only set of wheels/tires so they are dailys and im ok with that. 100% yes I can go deeper with these tires, I don't ffs or anything so I know Im leaving a little on the table there. Plus that was the first night of drags with that tune. 129mph has some potential.
But as far as the launch goes I think I am just an oddball, I spin 1st gear everytime and I make sure of it by upping launch rpm if the track is sticking too well. I like to do that simply because I can duplicate it everytime.
Old 07-31-2019, 12:14 AM   #693
closevo
Member#: 268031
2006 Forester XT
06 FXT in Albuquerque @ 5400 DA
closevo is offline   Reply With Quote
Happy Birthday cassieswrx your inappropriate pics here car_cursed Rocky Mountains Impreza Club Forum -- RMIC 11 07-11-2008 02:23 AM
Add Your Timeslip Today! Nick Proven Power Bragging 29 07-20-2004 10:06 AM
get your Hatorade pics here! RidinLow Tri-State Area Forum 16 10-16-2002 11:24 PM
Post your leather pics here! Fernely Interior & Exterior Modification 12 10-30-2001 10:15 AM
