Welcome to the North American Subaru Impreza Owners Club Friday December 14, 2018
Old 11-13-2017, 04:51 PM   #29951
Ladeef
Member#: 318753
2012 Impreza
Dark Grey
Hi all, try the ignore button on drpoop, it makes this forum actually tolerable. cheers!
Ladeef is offline   Reply With Quote
Old 11-13-2017, 05:13 PM   #29952
Obviously Tyler
Member#: 395955
2018 Mazda 3 GT
2018 Crosstrek
I hated the seats in my 14 Impreza.
But oddly enough I love the cloth seats in my WRX, considering they're just about the same as the Impreza's but with more side bolster and lumbar support. And less squeaking.
That god awful squeaking...
Obviously Tyler is offline   Reply With Quote
Old 11-13-2017, 06:37 PM   #29953
drpoop
Member#: 421858
2012 Impreza
Thanks for continuing to post about seats, I kept forgetting to put my seat heater pad back on the seat now that it's cold out. Now I can finally remember to do that. I know I could just install a heater pad into the seat but it's something like $150 and an hour or two of work or $10 and 30 seconds of work. I go for functionality over looks so the fact that it looks kinda cheap doesn't bother me at all, it works.
drpoop is offline   Reply With Quote
Old 11-13-2017, 07:37 PM   #29954
subypete
Member#: 324361
2012 Impreza Sport
ICM 5MT
Originally Posted by flyboy1100 View Post
Good news: no external leaks
Bad news: car is using oil
I think next time it is down a qt i will dump in seafoam or marvel or kerosene and idle it as suggested then dump it for new oil.
I tried Marvel, same burn rate (1/2 qt per 1200 miles) before and after. I haven't tried sea foam yet but if you do let me know how that works out for you.
subypete is offline   Reply With Quote
Old 11-13-2017, 10:06 PM   #29955
drpoop
Member#: 421858
2012 Impreza
What about PCV valves flyboy?
Old 11-14-2017, 01:46 PM   #29956
drpoop
Member#: 421858
2012 Impreza
Lol **** subaru ��
First, fuel pressure release procedure does absolutely nothing at all. Maybe it goes from 100psi or whatever to 90psi, but it does nothing, even going well beyond what they say for cranking.
Unless you actually ran your tank dry it makes a mess.
The service manual leaves out important steps.
Never doing that again. If I have this turd at 120k I'm having a dealer service center do that.
Also, flyboy, do you throw some dirt in with your gas? I took the filter out of the old canister thing and mine was just kinda greyish, probably could have gone to 100k without a problem. I remember yours was black.
Old 11-14-2017, 02:11 PM   #29957
CalTech87
Member#: 348055
2013 Impreza 5MT
ISM
On a road trip last month I was cruising up toward Yosemite when a heavy duty tote lid, an RV skylight, or something of the sort flew off an oncoming RV right into my front end. It shattered a bit on impact despite its thickness and sent shrapnel all over.
I hit the breaks enough that it didnt land directly on my windshield which probably would have ended my trip. In hindsight it would have been a lot cheaper to let the windshield go though.
I cant even open my hood now because its warped as seen in the second picture. Anyone have experience with this sort of thing? Should I try to finagle it so it can be opened? I dont plan on a permanent fix until after I move in a couple months but need to put some oil in at LEAST.
CalTech87 is online now   Reply With Quote
Old 11-14-2017, 02:36 PM   #29958
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Just changed it, old one still rattled though too. Might try another.
Old 11-14-2017, 02:37 PM   #29959
drpoop
Member#: 421858
2012 Impreza
You didn't think to... you know... chase them down and call 911?
Old 11-14-2017, 02:41 PM   #29960
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Lol **** subaru ��
I didn't have issues with fuel spraying
I also changed my filter closer to 100k, pretty severe lack of top tier around here, at least where i used to work.
Interval is 75k btw, not 60k IIRC
Old 11-14-2017, 03:39 PM   #29961
drpoop
Member#: 421858
2012 Impreza
I meant to ask that, I still think mine was barely dark at all for 61k.
http://www.cars101.com/subaru/maintenance3.html it's 60k according to this
I don't know why fuel sprayed. First, I did the fuel pressure release thing and cranked it longer than they said to anyway. It was still super high pressure so I put everything back and went and cranked and cranked and cranked and probably made my starter cry, it still poured out fuel with a bit of pressure.
To get the pressure back up after I replaced the filter, I just cycled the ignition several times, I mean, you can hear the fuel pump priming when you turn the key to on.
Old 11-14-2017, 05:45 PM   #29962
theoutbackdream
Member#: 301179
2013 WRX Limited
First off.... WTFFFFFFF!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
It would've been cheaper, but it could've also beheaded you if it did fly through the windshield.
Never had experience with that, but you could try getting underneath the car and try pushing up on the hood while trying to open up the latch to release it.
Did you at least get the persons info to pay for damages?
theoutbackdream is offline   Reply With Quote
Old 11-14-2017, 06:45 PM   #29963
ObewanKenobi
Member#: 428583
2017 Impreza Sport
Venetian Red Pearl
ObewanKenobi is offline   Reply With Quote
Old 11-14-2017, 08:51 PM   #29964
drpoop
Member#: 421858
2012 Impreza
Forgot to add there was also a big ass mouse nest (that fluffy stuff they somehow find, kinda looks like torn up firewall but it's not) on top of the filter/pump. I'm sure it's been abandoned for probably years now, in MN I used to get them in my air filter box once in a while, nothing since though.
Old 11-14-2017, 09:40 PM   #29965
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Had one in exact same spot. Probably should check other side too, same thing over there on mine. At least the insulation came from my neighbors truck and not my car :/
Old 11-14-2017, 09:43 PM   #29966
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
My service manual says 75k, i trust that more than a dealer website
Old 11-14-2017, 10:10 PM   #29967
drpoop
Member#: 421858
2012 Impreza
Dunno, usually the service centers match up with the recommended service from Subaru. Either way, not really a huge deal whether it's 60 or 75k, the parts and labor will always cost too much.
Old 11-14-2017, 10:40 PM   #29968
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Changed pcv again with last new one i had. Only 2500 miles on it and it didn't rattle until spraying a tiny bit of brake cleaner through it, but it is also 25f outside.
Might try to get one of the new shiny ones vs plain steel
Old 11-14-2017, 10:42 PM   #29969
drpoop
Member#: 421858
2012 Impreza
I may have no idea what I'm talking about here but wouldn't your intake manifold probably be coated in oil if the PCV valve was stuck? I can't remember what connects to what now.
Old 11-15-2017, 12:09 AM   #29970
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Default 2012 Impreza thread
Yes, there is some oil in the intake manifold. It's possible it's sticking but i doubt it because it isn't carboned up, just a bit of oil and at cold temps would make it stick until warmed up.
My catch can had a minimal amount of oil in it before I removed it for winter, this engine produces so much condensation it isnt funny, it will just freeze up my catch can if I don't remove it for winter.
When I removed the catch can i did change pcv valves for the heck of it, and if either isn't the issue or i went from a mediocre one to a bad one, but a pcv is such a simple device it is hard to believe any could be bad
Old 11-15-2017, 11:38 PM   #29971
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
So in "what the heck, can't hurt" fashion i was thinking about my oil issues today and my oil consumption started about the exact same time I went from rev3a to rev5 tune, so possibly just coincidence but I did flash back to 3a tonight.
Old 11-16-2017, 07:06 AM   #29972
CLL_OBP
Member#: 310435
'12 Sport Limited
Magnatec 0W20 164,237 mi
OMG! Like nothing I've ever seen before either. About two weeks ago I put an aluminum duct over the tail pipe and ran it under the garage door because I had the car idling after a cold start. When I removed it about 15 minutes later, my right foot got drenched with water.
Fingers crossed on flashing the tune to a previous setting.
Old 11-16-2017, 09:52 AM   #29973
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I would love to run my oil collector bottle all year but the condescension fills it up in about 2 weeks and then freezes solid :/
Gonna be a while before i see if a new pcv and the tune reversion makes a difference since I currently rotate between 3 vehicles (subaru, my truck, excursion)
Old 11-16-2017, 12:06 PM   #29974
drpoop
Member#: 421858
2012 Impreza
That would be from fuel. Anything that makes it out the exhaust is from burned fuel. Hydrocarbon + oxygen = H20 and CO2.
Old 11-16-2017, 01:20 PM   #29975
supertoast
Member#: 425248
2015 Impreza Prem 4d
Dark Grey Metallic
These engines burn the absolute p*** out of fuel when cold starting too. Probably not much different than most other modern engines.
supertoast is offline   Reply With Quote
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 03:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 08:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 05:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 10:48 PM
