Welcome to the North American Subaru Impreza Owners Club Wednesday December 19, 2018
Old 11-14-2017, 03:30 AM   #1
revlimit408
Member#: 407008
02 2.1 stroker
fpgreen htz v9 sti 6speed
Default manley h-tuff rods on a 2.1 stroker question
Anyone running manley h-tuff with a 2.1 stroker? I am not sure how much grinding I need to do on the block . I was using sti rods on my last build so no clearance issue . Let me know please . thanks
revlimit408 is offline   Reply With Quote
Old 11-14-2017, 02:46 PM   #2
subaru_gc8
Member#: 29292
2004 WRX wagon
what grinding are you talking about?
Old 11-14-2017, 05:59 PM   #3
revlimit408
Member#: 407008
02 2.1 stroker
the rod cap when is on compression the clearance on the other side of the case , and from my previous stroker build the sti crank was hitting the case , i might need to upload some picture , its hard to explain. I did some research and i cant find anyone running with the h-tuff with 2.1 stroker ,ive seen only the regular h/beam , the h tuff is wider than the h beam.
Old 11-14-2017, 09:30 PM   #4
subaru_gc8
Member#: 29292
2004 WRX wagon
that sounds like it would be a question for the manufacturer. as it is a wierd thing to deal with. I have a 2.1 stroker but I used Tomei rods and had no problems like that at all. Im running about 400 on 91 and 450 on E with a gtx 3067
Old 11-14-2017, 11:10 PM   #5
Homemade WRX
Member#: 33782
96 in the garage
search FIRST, then PM!!!
I never had an issue with rods in a 2.1 stroker. Do you already have the Manley rods?
Old 11-15-2017, 01:35 AM   #6
stu
Member#: 25768
2003 GEN 2 GTX35R
OFCD Bugeye Slowbaru
Yah that seem weird. Pics would help for sure...
stu is offline   Reply With Quote
Old 11-15-2017, 01:44 AM   #7
revlimit408
Member#: 407008
02 2.1 stroker
not yet still debating what to get, the h tuff is my first choice , but I haven't seen anyone using it on a 2.0 liter with 79 crank . Talked to Manley and told me I need to do some block clearance work with stroker set up.
Old 11-15-2017, 02:21 AM   #8
subaru_gc8
Member#: 29292
2004 WRX wagon
can I ask what your HP goals are?
Old 11-15-2017, 02:37 AM   #9
revlimit408
Member#: 407008
02 2.1 stroker
400-500 whp . I have a fully build head supertech valves , manley spings with retainers ,sti cams and shimeless buckets . For fuel dw300 hardwire , id1300 and e85 fuel. for turbo Fp green htz and supporting mods. speed density tune.
Old 11-15-2017, 11:41 AM   #10
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Did you ask them specifically what needs to be clearanced and by how much?
That would have been my 2nd question to Manley
