Welcome to the North American Subaru Impreza Owners Club Sunday February 18, 2018
Old 09-30-2017, 02:16 AM   #401
remski
Member#: 151895
Since some of you enjoy the wiring pr0n... here's more....
Many break outs here..
Fat blue wire is 044 ground, with intank ground and misc grounds.
Blue/Gray are both rear speed sensors as well as hand brake, fuel temp and float.
1st breakout from the rear. 044 feed, meth relay connector as well as meth level float. O yeah..trunk release is purple.
Since I was experimenting with the boots.. I had to build up on the in-tank fuel pump breakout so it would shrink properly.
Some kapton tape right before boot application.
Both breakouts almost ready for epoxy and boot.
Power windows and power locks wrapped together.
Again with a build up so the original door grommet would seal properly.
Used some of the white cheaper heat shrink to wrap the door lock wiring.
Fender wiring wrapped alongside with sidemarker.
Old 10-13-2017, 11:35 PM   #402
remski
Member#: 151895
Onto the updates.
Coolant tank was finished. Painted and shaved.
Trunk harness is almost completed.
Battery+, fuel pump feed and tail junction.
044 harness merged.
Meth run on the right, washer on the left.
Main harness installed.
L+R wheel speed sensor along with hand brake switch.
Last but not least.. CAD designing the center console.
As in Cardboard Aided Design.
Old 10-15-2017, 12:49 PM   #403
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
What do you use the spec c tank for? I see it tapped for nylon hose
Also the 4l tank is for meth? I hear it doesn't long last with big injectors
Hyper is offline   Reply With Quote
Old 10-15-2017, 01:48 PM   #404
remski
Member#: 151895
Spec C is for meth.
Small tank is for windshield fluid.
Old 10-15-2017, 05:14 PM   #405
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
Ah
You should look into baffling the meth tank if you plan to do any racing
I am currently using surge tank in addition to spec c tank, but plan to ditch it in favor of some decent baffling
Old 10-16-2017, 12:16 PM   #406
remski
Member#: 151895
Tank did OK...
Low light came on when I had about 1/3 left.. so after 2 sessions I had to top it off.
I thought about baffling the thank but that would require opening it up..
Ah
Old 10-16-2017, 02:29 PM   #407
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
Originally Posted by remski View Post
Tank did OK...
You don't need to "open it up" to add baffling, look up "baffling blocks" they work great. You just need to confirm the material used works with the fluid your tossing in the tank but you should be fine on that side of things.
Scuby04STi is offline   Reply With Quote
Old 10-19-2017, 12:37 PM   #408
remski
Member#: 151895
Oh... fuel foam... great idea..
Why i didnt think of it before...
Old 10-19-2017, 01:50 PM   #409
remski
Member#: 151895
Seems there is no foam that is alcohol safe..
Old 10-19-2017, 06:04 PM   #410
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
You have some fab/wiring skills but you could work on the whole google search thing, LOL.
Here: https://www.summitracing.com/parts/a...0/applications
Old 10-20-2017, 12:22 AM   #411
remski
Member#: 151895
I read few posts and gave up....
It scared me that even a little particle would clog up the meth injector.
Then we all know what happens next...
Thanks anyway... there is an option.
Old 10-20-2017, 12:23 AM   #412
remski
Member#: 151895
Its been quite a few years since I last have seen this.
I got DCCD hooked up and most of the lights taken care of.
Only one is the BRAKE light..
Looking at the diagram alternator feed should turn it off...
Also seems like I need the outside temp sensor alongside with some home made voltage controller...
Ah.. yes.. i'd be nice to reset the odometer...
Old 10-21-2017, 09:39 PM   #413
midnit
Member#: 139435
Spent the last couple hours looking through this... so amazing! Subscribed!
midnit is offline   Reply With Quote
Old 10-22-2017, 06:47 PM   #414
remski
Member#: 151895
Glad you guys are enjoying it.
Old 10-30-2017, 12:04 AM   #415
remski
Member#: 151895
Spent some time working on the cluster wiring.
All connections wrapped.
And few hours later... Its complete.
Old 11-05-2017, 07:54 PM   #416
Russell Rogers
Member#: 27261
I'm Ron Burgundy?
Just waiting for the weekly update
Russell Rogers is offline   Reply With Quote
Old 11-09-2017, 11:51 PM   #417
remski
Member#: 151895
Lately I've been demotivated....
I've managed to break the alternator that i put 5hrs into..
Old 11-13-2017, 11:18 PM   #418
WhatLipIsThat
Member#: 477678
1993 Impreza L
The amount of work that has gone into this thing is absolutely incredible!
WhatLipIsThat is offline   Reply With Quote
Old 11-14-2017, 02:14 AM   #419
Shipman
Member#: 312847
2006 WRX STi
2008 Legacy/2003 Forester
I've said it before and I'll say it again. This is legit the only real build thread worth reading through on this site.
Shipman is offline   Reply With Quote
Old 11-14-2017, 06:11 PM   #420
remski
Member#: 151895
Thanks, that means a lot.
I need all the motivation I can get !!!!
Old 11-19-2017, 09:14 PM   #421
remski
Member#: 151895
Time for long overdue updates.
Some glue, few days of itching and finally we have a center console.
Here it is installed, sitting pretty.
Cluster was installed and new wiring is on its way.
Finally reached a milestone ...
For the first time the car was powered on.
It was just a heater fan :biglaugh: but the car now has power.
Old 11-19-2017, 11:35 PM   #422
TheBlackPowder
Member#: 477628
2006 Impreza WRX Li
Steel Gray Metallic
She is nice
TheBlackPowder is offline   Reply With Quote
Old 11-22-2017, 09:43 PM   #423
remski
Member#: 151895
Day in .. day out...
The birth of yet another wiring harness.
This will feed the brake pedal, clutch and all the buttons on the steering wheel.
Reay for the 24gauge motec connections.
This is just a signal to ground so gauge can be tiny.
This harness is done for now... Also feeds the heater fan and power locks...
Almost forgot.. windshield washer and the horn.
A well hidden trunk release solenoid.
Power windows and power locks harnesses were merged.
Now all I need is the connector for that BMW windows switch..
Last but not least.. DCCD/cluster connector was completed..
Sooo nice to see the cluster on.
Btw.. I've decided not to switch to Subaru's DCCD controls.
So.. both switches are for sale if anybody wants.
Things are becoming organized.. right ?
Old 11-24-2017, 12:14 AM   #424
meinct
Member#: 350408
2012 wrx
dgm
Keep it up man. You're doing an awesome job. Can't wait to see the finished product.
Happy Thanksgiving!
meinct is offline   Reply With Quote
Old 11-24-2017, 02:51 PM   #425
Russell Rogers
Member#: 27261
I'm Ron Burgundy?
I love this thread! Keep it up!
