Welcome to the North American Subaru Impreza Owners Club Friday January 18, 2019
Old 01-04-2018, 12:38 PM   #7151
8404WRX
Member#: 356970
2004 Subaru WRX Wago
Sparco Assetto Gara
16x7 5x100 et48
Michelin X-Ice XI3 winter snow tires
205/55/16
Will this clear 4/2 pots on my 04 wagon?
8404WRX is offline   Reply With Quote
Old 01-04-2018, 01:22 PM   #7152
SubLGT
Member#: 207528
2005 Legacy GT
Originally Posted by tdekany View Post
...I have zero experience with studded tires, but I can not believe how good these Nokiaís are...
You have the Hakka9s? How noisy are they?
Nokian has this to say about them:
The [special clinch] rubber compound presses flexibly against the wheel flange, providing the bead area with more durability. The innovation also effectively minimises the interior noise, since it dampens the vibrations from the tyre body, preventing them from passing into the tyre and further inside the vehicle.
SubLGT is offline   Reply With Quote
Old 01-05-2018, 11:00 AM   #7153
xEJ20x
Member#: 49362
2013 DGM STI
Cobb Stg 2
Sparco Terra
17x7.5 +45
General Altimax Arctic 12
235/45R17
xEJ20x is offline   Reply With Quote
Old 01-05-2018, 12:26 PM   #7154
left footed whooten
Member#: 44652
16 Colorado diesel
ATC Bobcat Pop-up
Originally Posted by 8404WRX View Post
Sparco Assetto Gara
16x7 5x100 et48
205/55/16
Probably. Check tireracks site. If they offer this wheel in this spec for your car, then it will fit. Tire size is tire size is tire size. Thats your OEM size, of course it will fit.
left footed whooten is offline   Reply With Quote
Old 01-05-2018, 12:28 PM   #7155
left footed whooten
Member#: 44652
16 Colorado diesel
ATC Bobcat Pop-up
Originally Posted by xEJ20x View Post
Sparco Terra
17x7.5 +45
235/45R17
Want? Have? What you mean, Dean?
Cant go wrong with a general.
Is that your stock tire size? That would mean youre only changing the offset and width. Check tirerack, if they offer it, then it will fit
Old 01-05-2018, 12:31 PM   #7156
left footed whooten
Member#: 44652
16 Colorado diesel
ATC Bobcat Pop-up
Personally, I think finding takeoffs is a better option for winter tires. I dont like to change the offset, it can have negative effects in slippery conditions. Too bad aftermarket wheels dont come in more stock offsets as well. Its most times cheaper than a new set of low end aftermarkets like rota or sparco, even if you have them refinished first. Theres a lot to be said for OEM spec. Subarus are so plug and play too, you can put nearly any model tire/wheel on there.
Finding this to be more of an issue with my truck, very limited options to begin with, odd bolt circle spec, waiting for aftermarket to catch up. What is available, all poor taste and bling aside, has predominantly large changes in offset. No thanks. Prob gonna get a set of takeoffs in spring instead of unmounting my snow tires.
Old 01-06-2018, 01:30 AM   #7157
8404WRX
Member#: 356970
Thanks for the reply, Iím in a rush to get tires and these will be bought off a friend, my 04 WRX Wagon has swapped 4/2 pots, and just wondering if these will clear them. Iíve hand mixed responses so I just wasnít to sure.
Old 01-06-2018, 10:41 AM   #7158
xEJ20x
Member#: 49362
2013 DGM STI
Cobb Stg 2
Sorry, I must've misunderstood what this thread's purpose really was or didn't finish reading the full title.
I assumed we were posting our current winter wheel/tire set up, not asking for help/advice.
Old 01-06-2018, 11:59 AM   #7159
8404WRX
Member#: 356970
I mustíve misunderstood as well, since I read the title as all winter tire questions go here, than rather starting a single thread about my dilemma.
Old 01-06-2018, 12:02 PM   #7160
krzyss
Member#: 8365
2013 Ford Focus SE
"all winter tire questions go here" - from the topic title.
Krzys
krzyss is offline   Reply With Quote
Old 01-08-2018, 01:19 PM   #7161
SubLGT
Member#: 207528
2005 Legacy GT
The Nokian Hakkapeliitta R2 is being replaced with the new R3 this year. Nokian has not yet released a photo or details. They also introduced the new WRG4 all weather tire.
Old 01-08-2018, 07:33 PM   #7162
left footed whooten
Member#: 44652
16 Colorado diesel
ATC Bobcat Pop-up
Its a little bit of everything, this thread and thats A-OK. We're all just here to dork out.
Old 01-11-2018, 01:39 AM   #7163
dambikeracer
Member#: 480332
2008 STI
GREY
Default Time for new snow tires
My currently snow tires are 245/40/18's on the factory rims. I know a narrower snow tire tends to grip better. I'm thinking of getting 225/45/18's, thoughts?
dambikeracer is offline   Reply With Quote
Old 01-11-2018, 08:58 AM   #7164
krzyss
Member#: 8365
2013 Ford Focus SE
Narrower do not grip better. They cut to hard surface easier, if there is hard surface reachable.
Wider may be better on ice, dry and deep snow. Narrower helps in deep water, slush and snow.
What is OE size of tires and wheels?
Krzys
Old 01-11-2018, 09:34 AM   #7165
point78
Member#: 344329
2008 Wrx, 6mt
Interesting, I really like the R2's. Had them on a couple of cars.
Nokian had a Hakka SUV 9 display tire randomly sitting at the center village walkway at Copper Mountain.
It looks like a beast of a tire.
(Gf put a set of the General Arctic 12 studded on her MDX this year. Obviously not a performance ride, but the tires work very well)
point78 is offline   Reply With Quote
Old 01-11-2018, 11:51 AM   #7166
left footed whooten
Member#: 44652
16 Colorado diesel
ATC Bobcat Pop-up
Krzys
Hes right, especially for your area, which isnt very different in characteristics than mine, Id stay stock with the size, it will spilt the diference between conditions well. The ony advantage I can see is a few dollars less per tire, if that.
Old 01-13-2018, 11:47 AM   #7167
SubLGT
Member#: 207528
2005 Legacy GT
Nokians new all weather WRG4 tire:
https://www.nokiantires.com/company/...rmance-all-se/
...With a new All Weather Dual Performance Compound, the Nokian WR G4 features longer lasting tread life and draws inspiration from nature with its Centipede Siping - jagged 3D sipes on the center rib that resemble the legs of a centipede - which grip the surface to maximize biting edges while maintaining stable handling.
The size selection ranges from 14 to 19 inches and speed ratings from H up to V. The full size selection of this new premium product will be available to consumers in early 2018..
...The Nokian WR G4 steers as precisely as an all-season tire on dry or wet highways or in busy traffic. For winter driving, it has the Mountain Snow Flake designation, ensuring predictable grip both in thick snow and slush. Additionally, the 3D locking sipes of the tread blocks improve lateral stiffness...
The all weather WRG4 appears to be a North American version of the WR-A4 winter tire, which has been for sale in the European market for about 2 years. They appear to have identical tread designs. But the WR-A4 has speed ratings up to W, and sizes up to 21 inch. It would not surprise me if the WRG4 has a different rubber formulation and/or internal construction than the WR-A4, to better suit the North American market.
https://www.nokiantyres.com/winter-tyres/nokian-wr-a4/
Old 01-13-2018, 01:39 PM   #7168
RussianTiny
Member#: 387467
2018 WRX Limited
WRB Stage 2 FlexFuel
Thatís awesome! Iím new to all weather Tires. Iíve done winter tires before (blizzaks) and now performance winter Tires (also blizzaks). Where do All weather Tires rank between winters, perf winters, all season?
RussianTiny is offline   Reply With Quote
Old 01-13-2018, 06:00 PM   #7169
SubLGT
Member#: 207528
2005 Legacy GT
For me, an all-weather tire is like a performance winter that can be used all year long, even during hot summers. A good choice for people who rarely drive on ice, but do drive on snow and slush, and don't want to have 2 sets of tires. For winter performance on snow, ice, and slush the AW will likely be superior to an AS, and likely a little inferior to a performance winter.
Old 01-13-2018, 06:12 PM   #7170
Dr No
Member#: 480479
Default Winter tires
Thorough. Thanks.
Dr No is offline   Reply With Quote
Old 01-13-2018, 07:06 PM   #7171
the_saintusa
Member#: 171486
2004 WRX STI
FWIW the Hakka 4 studded that I drove on years ago were pretty quiet. Definitely the quietest studded tire I have heard.
Outside the car you can definitely tell that it is a studded tire.
I was most impressed by the minimal wear of the studs despite the winter tires seeing a lot of pavement.
the_saintusa is offline   Reply With Quote
Old 01-14-2018, 04:01 PM   #7172
hys420
Member#: 18315
2017 STI Limited
WR Blue (Classic!!)
Originally Posted by fr4c View Post
Just picked up a set of stock 2015+ WRX 17" wheels, and they came with a set of lightly used Dunlop SP Winter Sport 3D. Anyone have experience with these tires?
Deal was too good to pass up, $600 for the set.
Excellent tires, have used them over 12,000 miles so far, fourth season now, on my '08 STI on 17" BBS wheels. Great choice. $600 for the wheels and tires! Wow! Amazing deal!
Now I'm moving on to a '17 STI Limited, this time I have ordered a set of the Yokohama V905's in 18" size (keeping the original STI wheels!) from tirerack - handful of reviews and videos online seem to be pretty positive and I like the look of that tread pattern (similar to the Dunlops), for a great price
hys420 is offline   Reply With Quote
Old 01-14-2018, 04:10 PM   #7173
hys420
Member#: 18315
2017 STI Limited
WR Blue (Classic!!)
Originally Posted by WaNtEdAmErIcAn View Post
Hey all, I'm in the market for some winter tires. I'm planning on getting performance winters, because I live in Connecticut and my daily commute to work is 50 miles each way (95% highway). I'm leaning towards Yokohama W.drive V905, mainly because Consumer Reports rates them the best out of the performance winters that they tested (including the Michelin Pilot Alpin PA4's). Before I take the leap though, I have a couple of questions for all you tire people:
  • Does anyone have any experience with the V905's? How'd they perform/last compared to other Perf winters you've driven?
  • I see that Tirerack only offers the new "Bluearth" V905's (not the original V905's). Has anyone heard if any of the "Bluearth" changes have/will negatively impact the tire's performance? Has the performance of other Yokohama tires been negatively impacted when they were changed for the Bluearth line?
  • Is there any reason why I shouldn't get these?
Thanks in advance.
I'm in CT too, familiar with all the driving you're talking about. For a few years I've been running 17" Dunlop Winter Sport 3D's on my '08 STI. Now I'm getting a new '17 STI Limited and I just ordered a set of these Yokohamas in 18" from tirerack (keeping the original STI wheels!) Looks like a great bargain. I didn't find any negative reviews of these anywhere online.
Old 01-14-2018, 04:13 PM   #7174
hys420
Member#: 18315
2017 STI Limited
WR Blue (Classic!!)
Originally Posted by mnrex View Post
I've got an '18 and loooove the stock wheels, so they'll stay dedicated summers for now.
Think I'm just going to go with the Enkeis. For just over $1200 I can get a set of great looking, quality wheels with decent winter rubber.
Great choice
Old 01-16-2018, 12:36 PM   #7175
SubLGT
Member#: 207528
2005 Legacy GT
The Nokian Hakkapeliitta R2 is being replaced with the new R3 this year...
https://www.nokiantyres.com/company/...ta-r3-suv-pea/
https://www.nokiantyres.com/hakkapeliitta-r3
This here is the Android OS thread. All phones, news, general info welcome. under pressure Off-Topic 10849 12-13-2011 11:10 PM
WTB: Winter wheels/ or All season tires on wheels, or just all season tires! Robstunner MWSOC Private Classifieds 0 10-29-2009 12:42 PM
Winter Tires vs. All Season Tires wrx425 Tire & Wheel 22 01-16-2009 12:34 AM
same tire thread all around for AWD? MystikalDawn Newbies & FAQs 6 10-15-2008 12:28 PM
Anybody get tired of all your mods and go back to stock or somewhere in between?? Farnsrocket Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 31 09-11-2007 11:06 PM
