Welcome to the North American Subaru Impreza Owners Club Saturday December 15, 2018
Old 01-12-2018, 04:04 PM   #1
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Default xluben's 2010 Subaru STI | PTE 6466 | E85 @ 38PSI | 608WHP / 583WTQ |
Event: Dyno Tuning
Ambient Temp: ~55F
Elevation: ~900ft
Weather: Cold Outside
Tires: 215/55R17 Hankook Winter Tires with Konig Hypergram 17x8" +35 Wheels
Car: 2010 Subaru STI
Tuner: Devin @ JM Automotive
Dyno Info: Dyno Dynamics @ JM Automotive
Transmission: OEM STI 6 Speed
Gear: 4th
Peak HP at RPM: 608 WHP @ 6k-7.5k RPM
Peak Torque at RPM: 583 WTQ @ 5000 RPM
Baseline hp/tq for a stock on same dyno: 220 WHP / 218 WTQ (Stock STI)
Shootout Mode: 767 WHP / 720 WTQ (Similar to Dynojet)
Target Boost: 38psi
Target AFR: 11's
Fuel: E85
608 WHP / 583 WTQ
Full Build Thread:
https://forums.nasioc.com/forums/sho....php?t=2855524
Engine:
  • IAG Closed Deck 2.5L Case
  • IAG Pinnned Mains
  • IAG Cylinder O-Rings
  • IAG 14mm Head Studs
  • OEM Subaru Crank
  • Cosworth Head Gaskets
  • Manley 99.75mm Pistons
  • Manley Turbo Tuff I Beam Rods
  • King Rod and Main Bearings
  • OEM 2010 STI Heads
  • BC Stage 3 (280) DAVCS Camshafts
  • BC Stock Size Valves
  • GSC Beehive Springs w/Retainers
  • Aluminati Solid Billet Motor Mounts
Intake/Exhaust/Fuel:
  • Precision 6466 Turbo
  • MAPerformance 4-1 EL Header
  • FobiaFab Gate Dump on Header Secondary
  • TurboSmart 40mm HP EWG (35psi)
  • ETS Rotated Uppipe and Downpipe
  • Invidia Q300 Catback
  • ETS 4" Intake and Filter
  • ETS 3.5" FMIC Kit
  • TurboSmart Race Port BOV
  • Radium Dual Pump Hanger
  • Dual AEM 50-1200 E85 320LPH Pumps
  • -8AN Fuel Feed Lines
  • -6AN Fuel Return Lines
  • ID1700cc Injectors
  • IAG Fuel Line Kit
  • Aluminati Billet TGV Deletes
  • Aluminati Billet Fuel Rails
  • TurboSmart FPR 1200
Drivetrain/Transmission
  • Stock STI 6 Speed
  • Kartboy Short Shifter
  • Anarchy Motive Shift Knob
  • Aluminati Solid Billet Tranny Mount
  • Aluminati Solid Billet Pitch Stop Mount
  • ACT HD Pressure Plate
  • ACT 4 Puck Disk
E85 tune completed at JM Auto. The car made 608WHP and 583WTQ at 38psi on their dyno. It is known to be low reading, so the "Shootout Mode" numbers are used as a reference to the local Dynojet. The numbers aren't too important to me as long as the trap speeds are there. Overall the power seems to be holding great and is about where I would expect based on the boost and fuel.
Dyno Video
Engine Bay
Old 01-12-2018, 05:28 PM   #2
flat4lover
Member#: 181867
2016 gtx35r sti
red
How do you like the maperformance header? just bought mine but haven't got it on yet
flat4lover is offline   Reply With Quote
Old 01-12-2018, 05:47 PM   #3
toph
Member#: 78640
14 LTZ 6.2
04 STi
Why didn't you have NF tune this one? Going to keep power at this level?
toph is offline   Reply With Quote
Old 01-12-2018, 07:51 PM   #4
DavC825
Member#: 201736
12 IS-F Sold!! :(
Slowest 07 STi
what gen 6466?
DavC825 is offline   Reply With Quote
Old 01-13-2018, 12:30 AM   #5
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
It fit great and it seems to be working well. Honestly didn't really seem to add much on the stock turbo setup, but I may have been limited by intake or TMIC. But on this setup it is really holding the top end well. Power is flat all the way to redline with no drop off.
NF is no longer tuning cars. JM is only a few miles from me, specializes in Subaru's, and has an AWD dyno. It's a good match and they've been good to work with so far. Power will stay at this point. The parts were all sized for this level (pumps, injectors, turbo, etc). Trying to avoid breaking driveline parts, but it will probably happen anyways.
Originally Posted by DavC825 View Post
what gen 6466?
Gen 2. The 6466 was only ever offered with the Gen 2 configuration.
Old 01-13-2018, 12:32 AM   #6
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Tried to make a speedo video, but it wouldn't hook. Need to get some warmer weather.
Old 01-13-2018, 12:33 AM   #7
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Photos from today.
Old 01-13-2018, 11:35 AM   #8
taxkourel
Member#: 333315
Looks like a complete build! Do you feel the injector size is pushing its limits or are the IDCs reasonable (you have a bunch of other fueling mods). This is very cool! Damn that power curve is so flat. In your opinion is this because of the rotated setup or cams mostly?
taxkourel is offline   Reply With Quote
Old 01-14-2018, 09:30 AM   #9
sackytar
Member#: 149262
03WR rallycarFXTleg
PrimerGrey
Gheesh looks good and reliable.
Old 01-14-2018, 07:25 PM   #10
Gnagel
Member#: 469484
Hot damn I need to make more money haha
Gnagel is offline   Reply With Quote
Old 01-15-2018, 12:15 PM   #11
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Geeeeeeezzzzz, and those numbers on snow tires, so they'll only go up!
Shoot me an email, I got something for you. [email protected] you know where.
Chase
Engineering
Old 01-16-2018, 12:32 AM   #12
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Looking good! I need to go for a ride!
Old 01-16-2018, 10:00 AM   #13
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
The fuel system is the limit. Pumps and injectors are basically maxed out. Which one depends on where the fuel pressure is set to.
The header, rotated setup, and cams all seem to be working well to hold power up top. The top end looks a lot flatter than my 2002 WRX setup ever did (no drop off).
Thanks! Hopefully it lasts...
Chase
Engineering
Sent. Thanks!
Yes, someday for sure!
Old 01-16-2018, 10:01 AM   #14
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Small updates since the original post (not power related).
Kirkey seat mock up.
Impreza scoopless hood installed.
Old 01-16-2018, 11:44 AM   #15
tomtom84
Member#: 167794
08 STI 6266 e85 DD
91 miata and 05 STI
what oil pump did you use?
great results, I need to put up my dyno/build sheet at some point. I emulated your 6266 setup and made 543whp on a dyno dynamics.
how is the 4 puck?
tomtom84 is offline   Reply With Quote
Old 01-16-2018, 12:50 PM   #16
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
how is the 4 puck?
11mm OEM oil pump. That sounds like a good result on the 6266.
I prefer the solid disc compared to the sprung (6 puck) disc. It's definitely touchy either way, but I like the quick shifts the lighter disc can provide and seems to have less chatter than the sprung (puck style) discs.
Old 01-16-2018, 08:35 PM   #17
taxkourel
Member#: 333315
Your posts are a wealth of knowledge! Going back to fueling : you think other than injectors this setup would not be enough to hit 700ish whp (irrespective of turbo size)? If so what would you add? It looks pretty complete aside for small injector size (small for future applications, it clearly works great now)
Old 01-16-2018, 09:21 PM   #18
Android287
Member#: 180861
2005 IAG Closed Deck
Larry's Power built heads
How and where are your feed and return lines run??
Nice set up!
Android287 is offline   Reply With Quote
Old 01-17-2018, 12:08 PM   #19
tomtom84
Member#: 167794
08 STI 6266 e85 DD
91 miata and 05 STI
thanks for feedback, interesting point on the disc. I have run the sprung 6 puck on at least 4 cars (I've had a few scoobs) and I know what you mean on chatter. I always go to braided clutch line, new slave cylinder and I have tried different combos of pulleys/flywheels. Right now I have the oem flywheel, fluid dampr, and fully balanced. It has barely any chatter and I just installed the clutch pedal ITS bracket and GS master cylinder brace, which made a noticeable difference in pedal feel.
I plan to go to gsc stage 2 cams and closed deck when I refresh the motor, but we shall see.
glad to see you back in a hatch
Old 01-17-2018, 03:25 PM   #20
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I sized my fuel system for the 700-750WHP range (Dynojet) and the results are about what were expected. For someone who runs only E85 and the car can often sit for a while at a time, the newer "X" series injectors made sense.
http://injectordynamics.com/true-motorsport-injector/
The AEM 320 pumps are also made for E85, have lower current draw, and a bit flatter response as boost pressures rise. The Walbro 450's would provide a bit more flow at this boost but draw a lot more current.
I could swap to 2000cc injectors and new pumps and likely get a bit more power, but I'm going to leave it as-is for now. I feel that this may already be past the limit of having a reliable drivetrain so I'd like to figure that out first.
Nice set up!
They run where the stock hardlines were.
I prefer the OEM flywheel and a solid disc. I've found this to be the best way to hold a lot of power but still be reasonably easy to drive. The car came with the 6 puck sprung and it chattered just like it's done for me on other cars. The solid 4 puck is a much smoother engagement. I have an ITS bracket, but I have not attempted to install it yet.
Old 01-18-2018, 12:25 AM   #21
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I got my hands on a pre-production prototype of the upcoming GrimmSpeed catback for the GR hatch and did a quick video. It looks and sounds really good. Full review coming soon.
Old 01-18-2018, 09:54 PM   #22
user1029
Member#: 57064
2008 STi IAG built
HTA86 E85 Kel272s Cos IM
^^^damn that civic just ghosted
user1029 is offline   Reply With Quote
Old 11-04-2018, 10:14 PM   #23
blh701
Member#: 411417
2015 STI
Dark Grey Metallic
Awesome build
blh701 is offline   Reply With Quote
