Welcome to the North American Subaru Impreza Owners Club Sunday April 22, 2018
Old 01-12-2018, 12:35 PM   #1
Njmccor
Member#: 480486
05 Impreza
Grey
Unhappy Help! Flashing check engine light
After waiting at a stoplight I started to go heard like a thud and then my check engine light started flashing really rough idle IDK what happened
Njmccor is offline   Reply With Quote
Old 01-12-2018, 12:39 PM   #2
rtv900
Member#: 428511
2016 STI
me neither
keep us updated
rtv900 is offline   Reply With Quote
Old 01-12-2018, 12:39 PM   #3
shagfagon
Member#: 337836
2002 WRX Wagon
Genuinely curious, what do you actually expect any of us to do with that information?
What are you expecting here?
shagfagon is offline   Reply With Quote
Old 01-12-2018, 12:47 PM   #4
Samurai Jack
Member#: 21145
2002 Enemy of Aku
If you don't have a code reader, go to Autozone or someplace like that and get the code read.
Tell us what the code # is.
You can also Google the code # and it will give you an idea of what may be wrong, if anything.
BTW, how about filling in your profile so we know what you drive and where you are located?
That comes in handy when something applies to your location.
Old 01-12-2018, 01:05 PM   #5
rtv900
Member#: 428511
2016 STI
What, you can't figure out what is wrong based on that info?
It's pretty clear.
1) He has a car.
2) It has a problem.
pretty basic
Old 01-12-2018, 01:37 PM   #6
Abismo
Member#: 99707
2018 WRX Premium CWP
This is like trying to do neuro surgery in the dark... dude we have zero idea how to help you.
0 car details
0 location details
pretty much what rtv said... you have a car it has a problem. We cant solve issues in a vacuum.
Abismo is offline   Reply With Quote
Old 01-12-2018, 01:47 PM   #7
Maner
Member#: 220962
2007 Impreza WRX STI
Thumbs up
LOL, right! But in all seriousness, not to beat a dead horse. We can assist you if you let us know what you drive and what CEL code you have. Like stated above, go to Auto Zone, they can check your ECU to see what the CEL code is. Write down the code, and go from there. If the problem is not that big, the Auto Zone staff could possibly fix it there if you like, or you could search on NASIOC if they are unsure what to do. More than likely, someone else on here has run into the same problem. You have to help yourself out, so go from there.
Maner is offline   Reply With Quote
Old 01-12-2018, 01:49 PM   #8
Samurai Jack
Member#: 21145
2002 Enemy of Aku
It's pretty clear.
1) He has a car.
pretty basic
Are you sure?
Old 01-12-2018, 02:17 PM   #9
monkeyposeur
Member#: 333468
1993 SS
03 WRB GD 205/22T 20G-XT
I guess burnt valve!!!
monkeyposeur is offline   Reply With Quote
Old 01-12-2018, 02:18 PM   #10
mishapopa
Member#: 393629
2015 WRX
i guess misfire!!
mishapopa is offline   Reply With Quote
Old 01-12-2018, 02:21 PM   #11
Jack
Add Lightness
Member#: 13699
not my president
(From General)
Well, I will assume that this was in a 1919 Ford Model T. These cars were not equipped with factory indicators so I'll assume that this was a Wesson Model 3844 air speed indicator lamp. As you may know, if a human exceeds 30 mph, he will be unable to breathe, so this indicator lamp shows that you were perilously close to hitting 30 mph. You need to drive your horseless carriage at a rate of speed that is lower than you have recently been attempting.
Old 01-12-2018, 02:41 PM   #12
tramp
Member#: 459629
2017 WRX base
WR Blue
Due to lack of details no concrete conclusion. However I have one thing for you. STOP!!!! Park the car. A flashing CEL is a warning that a severe misfire (or other condition) exists that is dumping fuel at a rate raising the temperature of the catalyst that will damage it at minimum.
It could be as simple as a fouled plug. As serious as major component failure. Have the code read and report back. But do it without driving the car.
tramp is offline   Reply With Quote
Old 01-12-2018, 03:38 PM   #13
rtv900
Member#: 428511
2016 STI
Turns out it was the low battery light on his vape unit flashing
Old 01-12-2018, 04:09 PM   #14
Whiteb0y
Member#: 480069
2006 WRX Limited Wag
⬆⬆⬆ hahaha
Whiteb0y is offline   Reply With Quote
Old 01-12-2018, 07:35 PM   #15
Njmccor
Member#: 480486
05 Impreza
Grey
Ok yes SHE is a noob.... Getting live help is even more difficult then you all.... So its a 05 impreza wrx almost 180000 on it... Not sure what all has been done I've only had it a couple months.. But he was running perfect earlier in the day, went out a few hours later. Then this... I drove it right back home maybe a 1/2 mile checked all the fluids, changed the plugs today, waiting for my son to bring me a scanner
Old 01-12-2018, 07:50 PM   #16
Njmccor
Member#: 480486
05 Impreza
Grey
Thanks for all the positive comments tho I do know some stuff I'm not just some dumb girl, and would really appreciate some input thanks again, and btw I parked the model t cuz it only topped out at 25 thank goodness
Old 01-12-2018, 09:08 PM   #17
jasonwrx86
Member#: 472037
2018 WRX Limited
CWP
Flashing usually means misfire.
jasonwrx86 is offline   Reply With Quote
Old 01-12-2018, 10:30 PM   #18
Njmccor
Member#: 480486
05 Impreza
Grey
Unhappy
Misfire on cylinder 2
Old 01-12-2018, 10:58 PM   #19
Maner
Member#: 220962
Thumbs up
First, make sure that the electrical connector is securely on the ignition coil at cylinder 2 (Front driver-side). If that's good, then I would suggest swapping the #2 ignition coil with another ignition coil, I would suggest cylinder 1 (Front passenger-side) because it's easier to get to. Connect everything back up, and start the engine up after the swap, if the misfire follows the ignition coil, then that's your problem.
Old 01-13-2018, 03:41 AM   #20
Njmccor
Member#: 480486
05 Impreza
Grey
Talking
Thank you... Will try I, the am
Old 01-14-2018, 12:16 AM   #21
Njmccor
Member#: 480486
05 Impreza
Grey
So changed the plugs and the #2 coil, still the same!!!! The light went off for a min, then went to just on Not flashing, for it up to temp then started FLASHING again? I think I can hear a little tick, but not like a no oil tick? Someone suggested maybe something to do with the turbo? IDK?
Old 01-14-2018, 03:11 AM   #22
Maner
Member#: 220962
Okay, so you ruled out the ignition coil and spark plugs. Clean out your MAF amd O2 sensors. See if that helps, and please update us.
Old 01-14-2018, 04:41 AM   #23
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
Originally Posted by jasonwrx86 View Post
Flashing means catalyst damaging misfire.
Always.
CosmoTheCat is offline   Reply With Quote
Old 01-14-2018, 04:51 AM   #24
CosmoTheCat
Member#: 3409
98 My FMIC
Drop the exhaust and look to see if your valve guides have dropped.
Old 01-14-2018, 11:42 PM   #25
Njmccor
Member#: 480486
05 Impreza
Grey
I did drop the exhaust yesterday, all seemed ok... Scanned again today said misfire on 3..... SO.... I moved some **** around double checked all the plugs and stuff reset everything scanned again..... And.... The light is still OFF!!!! Yay!!! Thank you all for the advice and info
