Old 08-07-2017, 11:08 AM   #1276
krenberry
Member#: 394464
2016 WRX
6MT Crystal Black Silica
I have a 16 wrx premium and recently discovered a crazy creak (wouldnt call it a squeak or rattle) coming from either the rear deck, back windshield, possibly c pillars, or maybe even suspension. It sounds like a metal on metal creak and happens when I drive slowly going in and out of my driveway . Does anyone else have this? I'm dying to find the source and fix it!
Its hard to locate the source....I need someone in the backseat while I replicate the sound
krenberry is offline   Reply With Quote
Old 08-07-2017, 11:31 AM   #1277
96accord
Member#: 145105
2015 Honda Accord
There is a thread for '15+ WRX/STi Defects and I believe your rattle was discussed. https://forums.nasioc.com/forums/sho...647817&page=73
A member on here has a YouTube channel (he's a bit anal which isn't a bad thing to most) posted this video about his rattle in the rear deck.
96accord is offline   Reply With Quote
Old 08-07-2017, 06:01 PM   #1278
blackseafleet
Member#: 463024
2017 WRX
'17 WRX. Rear rattles from three places. Rear 3rd brake light fix: i laid some thin open cell foam under the light, then put thin heatshrink around the two hinge clips next to the glass and around the clip in the back.
lastly, stuffed the rest of my foam up under the circle hole just like the video above (just watched that after doing my fix).
the center seatbelt container rattles like crazy. Haven't figured out a fix for that yet.
last rattle is the metal bars underneath. i'll look at that soon as well, but the brake light was the worst
blackseafleet is offline   Reply With Quote
Old 10-08-2017, 06:00 PM   #1279
sebhockey
Member#: 138957
2016 WRX STI Limited
Finally tracked down and fixed a rattle/squeak that has annoyed me for several months today in my 16 STI. It always sounded like a metal on metal sound coming from driver's door or dash, hard to pinpoint. Finally I randomly put pressure on the knee air bag cover under the steering wheel and it stopped. After some searching, the bolt that holds the airbag on was loose causing the brackets to rattle/squeak against each other.
sebhockey is offline   Reply With Quote
Old 10-08-2017, 06:46 PM   #1280
YungBoba
Member#: 450808
2017 WRX Premium
WR Blue Pearl
Recently developed a rattle that sounds like it's coming from the passenger side of the car. Only occurs at very low speeds i.e. pulling into a parking lot. The noise sounds as if some plastic pop clips were left in the cubby but all my cubbies are completely empty. All panels feel firm and I checked the glovebox as well. Will update when I find out what it is.
YungBoba is online now   Reply With Quote
Old 10-13-2017, 02:32 PM   #1281
fleezy
Member#: 436768
2004 WRX
2. Driver side A Pillar, Vent cover - put puressure on the vent cover piece by the A-Pillar and rattle stops. -
Things I tried
- siliconing the white clips..
- taping the vent cover piece to the bottom piece..
- strips of fuzzy side of velcro (helped a bit but still there)
- removing the entire vent cover
i have an a-pillar rattle but it's not my vents. idk what it is; im thinking maybe some retaining plug/screw is loose at the bottom of the trim, but i really don't want to take apart the dash.
fleezy is offline   Reply With Quote
Old 10-17-2017, 11:38 PM   #1282
Bluefoton
Member#: 141373
2022 Crosstrek Sport
6MT
Did anyone try going bonkers and spraying each gap/clip/crack with a PTFE dry lubricant? seems to me it's the only lube that will last, silicone or oil just evaporates or leaks.
Bluefoton is offline   Reply With Quote
Old 10-17-2017, 11:55 PM   #1283
Cab0oze
Member#: 443914
2021 WRX
Well I'm not familiar with the older subies, but if it's anything like the new ones, just pull off every interior panel (door cards) and pillar cover you can get to, and put electrical tape where the plastic clips are clipped on to so that they hold everything more securely. Then with the door cards off, check to make sure every connector is secure and doesn't make noise when you wiggle it. Jam electrical tape, or use a hot glue gun ($7@ walmart) as required.
50cents of electrical tape has made my interior completely silent and did a way better job than the dealer ever did.
if you still have rattles, have a friend crawl around your car while driving to figure out where it is coming from. I did this "full treatment" on my friend's 2017 wrx (and fixed his 3rd brake light and trunk torsion bar squeaks by crawling around the trunk) his car went from noisy rattle bucket to silent.
Cab0oze is offline   Reply With Quote
Old 10-20-2017, 12:22 PM   #1284
whiplash willy
Member#: 424843
2016 WRX Limited 6MT
ISM
Has anyone found a fix for the glove box rattle on a 2015+ WRX?
whiplash willy is offline   Reply With Quote
Old 10-20-2017, 01:37 PM   #1285
JavaBot
Member#: 156723
17 2.5i foz dgm
rip wrx/rs/2.5i/foz1
Any fixes for the extremely dumb miscalculation of manual shifter reverse ring lockout rattle from 15+ manual vehicles? I actually have a ticket open with SOA for this so anything I can give them will help speed this crap up.
link I have given them with fix at 3:26 in this vid
As complex as this part is, I can't believe they haven't addressed this in 2 years.
JavaBot is offline   Reply With Quote
Old 10-21-2017, 08:13 PM   #1286
96accord
Member#: 145105
2015 Honda Accord
Nope.
Trade it in.
Old 12-13-2017, 06:31 AM   #1287
StuWRX
Member#: 457283
Any updates on this, my new rattle is coming somewhere from the passenger side. Sounds like its something hitting up against a metal panel, like a tinny sound. Hard to tell exactly where it's coming from. Sometimes it sound like it actually in the dash close to the pillar but lower down. Drives me crazy.
StuWRX is offline   Reply With Quote
Old 12-13-2017, 06:38 AM   #1288
StuWRX
Member#: 457283
2017 here. My new rattle is coming somewhere from the passenger side dash area. Sounds like its something hitting up against a metal panel, like a tinny sound. At first I thought it could be the plastic corrugated wire covering hitting against the inner fender right by the door. I looked all inside between the door jam and hing and everything looks tight and still clipped in place. Hard to tell exactly where it's coming from. Sometimes it sounds like it actually in the dash close to the pillar but lower down. Drives me crazy.
Any suggestions would be great. thanks.
Old 12-13-2017, 08:02 AM   #1289
WRB17REX
Member#: 479144
Originally Posted by 96accord View Post
Nope.
Trade it in.
I put some foam insulation sticky tape on the inside of the glove box at the top (on the dash part) and put two layers thick. Now the glove box is tighter as it presses against the foam tape so the rattle is gone.
WRB17REX is offline   Reply With Quote
Old 12-13-2017, 10:02 AM   #1290
96accord
Member#: 145105
2015 Honda Accord
Nope.
Trade it in.
I traded mine in about a month ago
Old 12-15-2017, 12:51 AM   #1291
SUBZERO_WRX
Member#: 479220
2017 WRX
Default Passenger window switch rattle and driver seat belt pillar???
When listening to music with heavy bass or even while driving the passenger window switch starts to rattle. Also while driving the driver seat belt pillar rattle as well. Does anyone know how to fix this. Step by step LOL
SUBZERO_WRX is offline   Reply With Quote
Old 12-15-2017, 07:23 AM   #1292
Cab0oze
Member#: 443914
2021 WRX
For the window switch, you need to take the door cards off. There are plenty of how to videos
Once you have that off, use a hot glue gun or electrical tape to jam in to everywhere that's rattling or tape off. I also removed every plastic clip on the door card, put a piece of electrical tape over the hole where it was and put the clip back on such that the tape would jam up and keep it from rattling around. I did this on all my doors and my friends doors and I have zero rattles from any of them, and the doors sound much more solid when closing.
Old 12-19-2017, 08:15 AM   #1293
Jgz1994
Member#: 409888
2015 WRX
I think I can contribute to this thread. Ever since we removed the radio, there was a small rattle coming from it. After I bought a new phone mount, rattle is gone. The trick is just to wedge something in the gaps.
Jgz1994 is offline   Reply With Quote
Old 01-12-2018, 04:50 PM   #1294
amiexploited
Member#: 251061
18 Trek 6mt,
garage queen 15 WRX 6mt
ok my turn to ask for help. Heard this new squeak/chirp from around the passenger dash area. Even with the air off it still makes the sound. Small bumps (can't replicate it with hitting the door or dash area).
2015 WRX
amiexploited is offline   Reply With Quote
Old 01-12-2018, 08:23 PM   #1295
SkunkworksGT
Member#: 165695
2003 wrx wagon, been hunting a recent rattle coming from the rear area. Happens on bumps, closing the hatch, etc. Fixed all trunk fasteners, tightened hatch spoiler and that helped a lot but rattle was still present. One day i noticed small rust on the cargo area and found the problem on the upper area that attaches to the headliner clip. Removed headliner, cleaned and treated area with POR-15, repaired remaining area from hatch gasket and all is good!
SkunkworksGT is offline   Reply With Quote
Old 01-13-2018, 12:14 PM   #1296
Cab0oze
Member#: 443914
2021 WRX
2015 WRX
Have you checked your glovebox, and soundproofed your doors cards and A-pillar trim yet (i.e. take them off and give it a full electrical tape treatment)? If you haven't done that, do it, makes a world of difference even if it ends up not being your problem.
Having a passenger sit in the car and help track down the sound might also be helpful.
Old 01-13-2018, 01:03 PM   #1297
amiexploited
Member#: 251061
18 Trek 6mt,
I haven't yet, going to be my spring time project. Ya I had my lady friend help but...here I am. I might have my brother drive my car while I poke around.
It has like a loose bracket metal on metal squeak/chirp on rough roads.
Old 01-13-2018, 01:12 PM   #1298
Cab0oze
Member#: 443914
2021 WRX
You'd think that, but it's a Subaru, so 99% sure it's hard plastic on hard plastic lol, especially when the temps start dropping.
Sounds are notoriously hard to track down, so like I said, I'd start with the obvious culprits that make noise in most people's cars. While you have the panels off, wiggle everything to see if there is any chance of noise. The window control connectors are often a problem.
Old 01-13-2018, 01:52 PM   #1299
sebhockey
Member#: 138957
I had something similar with my 16, spent months trying to locate, sounded like metal rubbing and seemed to come from different areas of the car. Turned out to be my knee airbag bracket was loose. Snugged it up a little and gone.
Also had a 15 with metal on metal sound, turned out to be my seat belt latch. Put a little silicone grease on the bottom of the stem where it was rubbing against the stop and gone.
Old 01-13-2018, 02:29 PM   #1300
amiexploited
Member#: 251061
18 Trek 6mt,
Thanks for the input fellas! The sun is out today so I'll start taking off panels.
SF5 forester thread doublej Member's Car Gallery 20 07-26-2012 01:30 PM
Can We Get a DIY Thread Going? STIckySTIfee General Community 17 04-03-2008 12:00 PM
Can we get another ice thread going? forced4 Texas Impreza Club Forum -- TXIC 0 01-17-2007 11:41 AM
Can we get an OT sing-a-long going? BEGIN! snvin Off-Topic 27 12-01-2005 01:15 PM
