Welcome to the North American Subaru Impreza Owners Club Thursday March 4, 2021
Old 09-20-2017, 08:44 PM   #1
Kijho
Member#: 311882
2016 WRX
CWP
Default Engine Bay Detailing (Cleaning)
I get asked this every time I open my hood haha! I use a few different products to keep my engine bay looking clean!!
What are your guys favorite tips / engine bay cleaning products or methods?
Kijho is offline   Reply With Quote
Old 10-07-2017, 02:36 PM   #2
cknowlen
Member#: 189077
2011 STI limited
Give scrubbing bubbles a try. yes, the stuff you would use to clean your bathroom. There is a whole thread on it on this site. Works like a champ. Best part is, if you dont like the way it works or the results, just use it on your bathroom.
cknowlen is offline   Reply With Quote
Old 10-07-2017, 02:45 PM   #3
tmcquinn
Member#: 310769
2018 WRX, 2002 WRX,
2003 WRX, 2012 Impreza
tmcquinn is offline   Reply With Quote
Old 10-09-2017, 04:14 PM   #4
MtnXfreeride
Member#: 228010
2019 WRX Limited
Crystal White Pearl
I just some APC diluted 1:7ish in a bottle.. spray the engine bay.. hit with a few various size brushes, and rinse with a spray bottle of water. Blow dry with shop vac, then wipe dry left overs. Finally, apply 303 protectant to plastics. I avoid the alternator and am careful around the air intake box.
Anyone concerned about removing light oil/grease hanging around in the engine and causing rusting/corrosion sooner? That grease/oil in the bay is kind of protecting the metal.
MtnXfreeride is offline   Reply With Quote
Old 11-28-2017, 06:19 PM   #5
PrimoSub
Member#: 478409
'10 ImpOutbackSport
Blue/Silver
Default Cleaner
Never heard of Poor Boys World products. Going to try it.
PrimoSub is offline   Reply With Quote
Old 11-28-2017, 06:33 PM   #6
T-37
Member#: 175624
0304 WRX WRX
SY WRB
+1 to Scrubbing Bubbles. It's as easy as it gets, and it won't oxidize your aluminum. They work hard so you don't have to...
I use some Adam's VRT on the plastics occasionally.
Old 12-06-2017, 02:50 AM   #7
Thetrumpwon
Member#: 478799
Anal wRts
Thetrumpwon is offline   Reply With Quote
Old 12-06-2017, 02:20 PM   #8
Six WRX
Member#: 477886
2017 Base WRX
Was doing an oil change, and noticed my engine bay was pretty dirty/dusty. Have any of you sprayed it down with a pressure washer after the cleaning products? I'm a little hesitant to do this as there are a lot of exposed areas...
Six WRX is offline   Reply With Quote
Old 12-22-2017, 01:09 PM   #9
Bo Bandy
Member#: 464271
2003 WRX Wagon
I wouldn't use a pressure washer because it can spray water into places it shouldn't. Spray off with a hose if anything which doesn't produce high pressured water.
I use simple green and LA's totally awesome(best cleaning product ever) from the dollar store with a soft brush or cloth
Bo Bandy is offline   Reply With Quote
Old 12-27-2017, 08:23 PM   #10
MtnXfreeride
Member#: 228010
2019 WRX Limited
Crystal White Pearl
It takes more than pressurized water to do it right.. its not worth the risk for how crap it would work anyway.. how good does a car look after using only a pressure washer without a mitt?
Might as well use a diluted all purpose cleaner or scrubbing bubbles and a few detail brushes to scrub for a couple minutes..its a 15 minute job total.
Old 01-01-2018, 12:49 AM   #11
evans312
Member#: 479935
2016 WRX Base
CWP
To be honest, I just take quick detailer, spray it on a micro fiber towel and wipe away. Not the most effective but it works.
evans312 is offline   Reply With Quote
Old 01-01-2018, 01:47 PM   #12
VR4ownzU
Member#: 122700
Does the Scrubbing Bubbles have any lasting effect on metal pieces inside the engine bay? Does it leave any residue? Is it safe on paint as long as you clean it off right away? I'm just curious how safe it really is?
VR4ownzU is offline   Reply With Quote
Old 01-01-2018, 05:35 PM   #13
T-37
Member#: 175624
0304 WRX WRX
SY WRB
It doesn't etch aluminum. It doesnt leave residue. Don't spray it on your exterior paint, it probably wouldn't hurt anything, but it may strip wax. I use it on most everything under the hood when it's dirty enough to need it (maybe once a year or less.) Brush as needed to loosen grime, rinse it off and dry it. Once the bulk of the grime is gone you can maintain it by rinse/wiping off accessible spots after every wash or so.
This is my DD in the midst of some repairs being done.
http://i.imgur.com/xo1BIsA.jpg
And after cleaning with scrubbing bubbles
http://i.imgur.com/ltoEE35.jpg
Old 01-04-2018, 09:18 PM   #14
drivequickly
Member#: 480138
^^^ waow what a huge difference !
drivequickly is offline   Reply With Quote
Old 01-07-2018, 07:56 PM   #15
Deckersixx
Member#: 472696
17 Wrx
Awesome man!! My engine bay needs a good cleaning this will def help out
Deckersixx is offline   Reply With Quote
Old 01-12-2018, 08:03 PM   #16
MD_Subae
Member#: 477035
2011 Impreza WRX STi
Charcoal Metallic
Probably going to try this after all the snow and salt we have been experiencing on the east coast. Ill report back!
MD_Subae is offline   Reply With Quote
Old 01-12-2018, 08:30 PM   #17
Nib
Member#: 472886
2013 WRX Spoolinator
Dawn liquid detergent.
Use a spray on wax like Meguiars supreme shine
Nib is offline   Reply With Quote
Old 01-12-2018, 11:17 PM   #18
VR4ownzU
Member#: 122700
I tried it on my wife's 9-2x Aero and it seemed to work okay. Used it on her rubber floor mats and it worked okay.
What do you guys use for dressing under the hood?
Old 01-13-2018, 04:55 PM   #19
driftredemption
Member#: 480551
Does anyone use a claybar? I noticed there are references to quick detailer - but didn't know if anyone uses a claybar. I have an 1990 white scooby that looks like it has years of dirt build up. Thinking about getting a claybar to remove the grime.
driftredemption is offline   Reply With Quote
Old 01-14-2018, 10:54 PM   #20
VR4ownzU
Member#: 122700
If you are doing a car that is pretty bad I would do the following: I haven't tried it yet (should be here Tuesday) but I've read a lot about doing Carpro Iron-X before you clay. It pulls some of the contaminants out of the clear coat making it easier to clay later. You can also use it to clean your wheels.
Old 01-15-2018, 09:05 PM   #21
SD_scooby
Member#: 466103
i use dawn dish soap, then follow with turtle wax plastic spray, shines everytime.
SD_scooby is offline   Reply With Quote
Old 01-16-2018, 04:30 AM   #22
samb
Member#: 177235
2016 Focus RS
2002 WRX Wagon
Looks great!
Except for that air filter. It looks like it needs some TLC
samb is offline   Reply With Quote
Old 01-16-2018, 03:42 PM   #23
MtnXfreeride
Member#: 228010
2019 WRX Limited
Crystal White Pearl
I used Tuff Stuff multipurpose foam cleaner to do my wifes and my cars last week. Worked great. Spray on.. let it sit a few (2) minutes, hit it with some detail brushes.. wait a few more minutes (3), rinse with a spray bottle or pump garden sprayer with water. Let drip dry a minute. Hit pools of water with mini blower (Ryobi high volume, low pressure tool), dry with microfibers. Dry again with Ryobi tool. Finish plastics with 303 protectant.
I avoid the alternator and spraying water heavily into electrical parts.
Old 01-27-2018, 06:39 PM   #24
BeardedBaxter
Member#: 475996
09 Forester
Wow wow wow to Scrubbing Bubbles! +10
BeardedBaxter is offline   Reply With Quote
Old 01-29-2018, 05:21 PM   #25
TheGrayAero
Member#: 481348
I tried the Walmart brand of scrubbing bubbles on my wife's Aero. Seemed to work okay.
TheGrayAero is offline   Reply With Quote
