Welcome to the North American Subaru Impreza Owners Club Monday December 9, 2019
Old 01-28-2018, 04:37 PM   #1
Jsubie18
Member#: 350459
2009 WRX
Default 2003 WRX fuel tank leak
Hi Guys,
I wasn't able to find any posts with the same issue I'm having, please feel free to move this post if necessary.
First off, this is a project car, not my DD. I've had it for almost a year now, and finally finished my JDM ej205 swap. Ecu came in last weekend, I was stoked to finally take the car out for a drive . All was well, I put around 100 miles on the car throughout the weekend. At the end of the day, I filled it up at the local gas station and drove home.
At this point, I was starting to smell raw gas in the cabin. Fortunately I only live 1 mile from the gas station. When I pulled into the driveway, I got out to inspect why it was smelling like raw fuel, and gas was (heavily) dripping from the drivers side rear tire well. I threw a catcher underneath to see how much was actually being lost. I then took the rear seat out, and the driver side was soaked in gas.
This happened a week ago, and I was finally able to do some testing this weekend. My fuel gauge was now reading 3/4 full, so I put 3 gallons in a canister, and then proceeded to pour that into the wrx. Sure enough, going anywhere over 3/4 mark and the tank starts leaking again. I checked the three lines which come up under the rear seat, but they don't seem to be leaking. Also, fuel is seeping up through two rubber grommets on the body under the seat (see pictures). It literally melted the rubber insulation which was on the body. The gas looks like it's coming somewhere on top of the tank, dripping over the seam (see pictures below)
I'm not sure if the leak is caused by lines on top of the tank, or the tank itself. I checked the sending unit and fuel pump gaskets, and nothing is leaking from them. Any advice is appreciated. I'm probably going to schedule a time to get it looked at in the near future.
Jsubie18 is offline   Reply With Quote
Old 01-28-2018, 06:29 PM   #2
Valarius Starchaser
Member#: 459312
2004 WRX Wagon
Hybrid 6MT Swapped WRB
Photo links are dead use something other then photobucket
Valarius Starchaser is offline   Reply With Quote
Old 01-28-2018, 08:14 PM   #3
Jsubie18
Member#: 350459
2009 WRX
Sorry, try these:
https://i.imgur.com/pj2tv16.jpg
https://i.imgur.com/VS98jv2.jpg
https://i.imgur.com/pHF5ATU.jpg
Old 01-29-2018, 10:50 AM   #4
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Where is the fuel pump located in your car, Driver or Passenger side?
Maybe fuel is leaking from the fuel pump gasket?
Old 01-29-2018, 02:25 PM   #5
Jsubie18
Member#: 350459
2009 WRX
Hey Jack,
Fuel pump is on the passenger side, sending unit on driver side. Both appear to be fine, no fuel leaking. I'm leaning towards a hole in the tank...
Old 01-29-2018, 04:15 PM   #6
wtdash
Member#: 59182
2002 WRX GG>>
2016 Focus RS
Yeah...that's a rusty NE car, based on 1st pic. Check your 'fuel filler neck' too.
wtdash is offline   Reply With Quote
Old 01-29-2018, 04:46 PM   #7
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Except the fuel filler neck is on the passenger side.
Old 01-29-2018, 04:47 PM   #8
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Originally Posted by Jsubie18 View Post
Hey Jack,
That's what is really starting to sound like
I just couldn't remember which side the fuel pump was on.
Old 01-29-2018, 04:55 PM   #9
wtdash
Member#: 59182
2002 WRX GG>>
2016 Focus RS
Yep...just like a Forester that has the 'infamous' fuel filler neck' rot.
Just another thing for the OP to check when they're dropping "shudder" the tank.
Old 01-29-2018, 10:37 PM   #10
Jsubie18
Member#: 350459
2009 WRX
Thanks for the replies everyone. I've decided to attempt removing the tank within the next few weeks with a few friends. What a waste of $40 worth of 93 octane.
I'll post what I find.
Old 01-30-2018, 10:22 AM   #11
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Just collect it in a gas container and put it back when the repair is complete.
Oh wait, that's like 13 gallons so you'll need several 5 gal cans
Old 01-30-2018, 11:49 AM   #12
Valarius Starchaser
Member#: 459312
2004 WRX Wagon
Yeah there’s two drain bolt on either side. I got a new oil drain pan and then went from that to the gas cans to make it a nearly no loss operation granted I spent 15 on the drain pan but I needed another anyways
Old 01-30-2018, 08:24 PM   #13
Jsubie18
Member#: 350459
2009 WRX
I might attempt dropping the tank this weekend if weather isn't too bad. I'll check the filler neck just to be certain first. I'll reply back with what I find on the tank regardless.
Old 01-31-2018, 11:44 PM   #14
monkeyposeur
Member#: 333468
93 SS - 06 OB XT
03 WRB GD 205/22T 20G-XT
Some have reported that their gas tanks didn't have any drain bolts. I couldn't find any on my 03 WRX wagon, but that's not to say that they aren't there.
The easiest way (for me) to drain the gas tank is to pull the ignition fuse and crank the engine to relieve fuel pressure. Connect the two green test mode connectors under the dash. Attach a long clear hose to the output fuel line post fuel filter. Stick the other end of the hose in a gas can and turn the key on. The fuel pump will cycle on and off and pump the gas into the containter.
monkeyposeur is offline   Reply With Quote
Old 02-01-2018, 10:24 AM   #15
Samurai Jack
Member#: 21145
2002 Enemy of Aku
I don't think I've ever seen any drain bolts on my 2002 wagon either.
How about just taking a big ass nail and drive it into the bottom of the gas tank? I mean, you're not going to re-use it anyway
Old 02-01-2018, 10:35 AM   #16
Jsubie18
Member#: 350459
2009 WRX
Those are both good ideas! I'll probably use monkeyposeur's method and store the gas. I also didn't see any drain bolts when looking around last night.
Old 02-01-2018, 01:17 PM   #17
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Well, I meant to use a big ass nail and drain into a storage container.
Fuel is too expensive to just throw it away like that.
Old 05-14-2019, 08:24 PM   #18
FL4TOUTWRX
Member#: 501586
My 03 is doing this exact same thing, what did you find??
FL4TOUTWRX is offline   Reply With Quote
Old 11-09-2019, 10:19 AM   #19
Boosdsubie
Member#: 508085
Find anything? I have same exact problem
Boosdsubie is offline   Reply With Quote
Old 11-11-2019, 02:43 AM   #20
Shik
Member#: 132
2006 GT Ltd 5spd sdn
'15 WRX 6spd CWP, '02 WRX
My son's 2002 did the same thing only it leaked in the passenger side. It was NOT the fuel filler neck, but rather where the neck goes into the tank where it rotted. Would only drip for a little after filling it up, but I wasn't having any fuel leaks with my kid driving, soooo...
I replaced the tank with a brand new oem tank, plus the white valves on top of the tank, as you can't get the gaskets for them separately, plus some rubber fuel lines, plus new nuts for the fuel pump hanger. Not the most fun i had replacing something on a Subaru, but at least it's done and I shouldn't have to worry about it for a while.
Shik is offline   Reply With Quote
