Welcome to the North American Subaru Impreza Owners Club Wednesday January 16, 2019
Old 04-27-2017, 03:51 PM   #51
Dreamtribejay
Member#: 432274
2011 Forester
so that didn't work as hoped. Also i noticed the data log i didn't even see the OCV log. Ill try to call cobb again to see how to properly upload it on to this fourm
Dreamtribejay is offline   Reply With Quote
Old 04-27-2017, 04:36 PM   #52
Dreamtribejay
Member#: 432274
2011 Forester
called cobb and they told me how to change the parameters to data log. i was just assuming that it was data logging the 6 that were on the screen. so i will change those and upload that.
Old 04-27-2017, 06:24 PM   #53
Dreamtribejay
Member#: 432274
2011 Forester
Finally was able to figure out how to upload data logs
This is after startup and reeving to 2100rpms(or at least trying to keep it consistent but it keeps bogging down
https://docs.google.com/spreadsheets...it?usp=sharing
This is cruising back roads
This was on the highway
Old 04-27-2017, 09:45 PM   #54
Subie_
Member#: 419354
2007 STI
Crystal gray metallic
Default P0021 code??
Just saw page 3 of this thread. I'll take a closer look in the AM.
Don't bother with the ECU, it's not the problem.
Subie_ is offline   Reply With Quote
Old 04-28-2017, 02:25 PM   #55
Subie_
Member#: 419354
2007 STI
LH works, but it definitely lags relative to the RH. On the left side of the graph, you can see the RH move to position, however the LH just hangs out at 0. The ECU waits a second or two and slowly ramps up the juice until it finally moves.
I believe the issue is a physical restriction or faulty OCV. Curious of what RPM it most frequently occurs, I took the absolute value of the difference between RH & LH and plotted it against RPM. Large deviations (anything greater than 2 degrees apart) most frequently occur between 1,000 & 1,700 ish. I think this makes sense though... it's harder to move an object from a stand-still compared to keeping an object in motion, especially with higher oil pressure.
You said you replaced the OCV, but for some reason I still suspect it. I'd remove both OCVs and measure the resistance between the 2 pins on each and let us know. Spend some time and very carefully compare the two to each other and to the "old" one that you removed (if you still have it). are the mounting tabs identical? are the little slots the same width, length, and position on the cylinder? If you somehow have the incorrect part number installed, or if LH & RH are different numbers you'll get data like this.
Swap them when reinstalling - put the LH in the RH, and RH in the LH. Take it for another drive and record data. If the RH AVCS lags then the OCV is highly suspect. You did this before, but you were looking for an "on or off" CEL which doesn't describe system performance - the devil is in the details and data doesn't lie.
Old 04-29-2017, 01:14 PM   #56
Dreamtribejay
Member#: 432274
2011 Forester
I switched the LH OCV and the RH OCV and did a good inspection and they both look the exact same other then the numbers on the plug. I got the new one straight from Subaru. I did do a resistance check on the plugs and i dont know if i did it wrong but both sides read 0.00 on the meter i was using. But he is the data log from after i switched them.
Old 04-29-2017, 11:59 PM   #57
Subie_
Member#: 419354
2007 STI
If that doesn't trigger CEL then I don't know what will! Swapping OCVs made it go from bad to worse. The LH side basically doesn't work at all now (isn't data fun?!)
Swap them back and measure resistance - it's the symbol that looks kinda like a horseshoe. This link should help: https://www.ifixit.com/Guide/How+To+...r/25632#s65006
and then PM me your address. I'm going to send you a super low mileage 0921AA080 OCV. MY 2011 is on the cusp of when Subaru changed part numbers. Unless the resistance on your new OCV is greater than 12 ohms, I suspect you need 0921AA080... I'm happy to eat the shipping cost to find out.
If in fact you have the correct part number then replacing the 'old' OCV will probably benefit the RH side's performance.
Old 04-30-2017, 12:08 AM   #58
Dreamtribejay
Member#: 432274
2011 Forester
So i think theres where i may have messed up. I was measuring the resistance of the actual blue plug on the wire harness. I should be measuring the resistance of the actual OCV?
Old 04-30-2017, 12:10 AM   #59
Subie_
Member#: 419354
2007 STI
Originally Posted by Dreamtribejay View Post
So i think theres were i may have messed up. I was measuring the resistance of the actual blue plug on the wire harness. I should be measuring the resistance of the actual OCV?
Sounds like it. You need to measure resistance across the 2 prongs on the OCV, not the harness.
Old 04-30-2017, 12:15 AM   #60
Dreamtribejay
Member#: 432274
2011 Forester
Haha whoops im a newb with electrical. Ill do that hopefully tomorrow and report back.
Old 04-30-2017, 10:03 AM   #61
Rustys13
Member#: 339770
my WRX through the same code p0022 on Friday, can't start the car with the key but I can push start it but it doesn't run great. Would this cause a no start issue?
Rustys13 is offline   Reply With Quote
Old 04-30-2017, 07:28 PM   #62
Subie_
Member#: 419354
2007 STI
No.
Check your timing
Old 05-01-2017, 02:21 PM   #63
Dreamtribejay
Member#: 432274
2011 Forester
So just did the resistance check on both ocv and ot seems to be there both at 9.3 when i hold the probes steady.
Im going to swap them back and go for a long drive and get the cel to pop up while im data logging
Old 05-01-2017, 07:16 PM   #64
Dreamtribejay
Member#: 432274
2011 Forester
I ended up finally data logging when the cel came on and ill post the data tomarrow at work.
Old 05-02-2017, 12:11 PM   #65
Dreamtribejay
Member#: 432274
2011 Forester
here is the data log from when the CEL popped up.
Old 05-03-2017, 02:12 AM   #66
pet3r
Member#: 283134
2015 STi LE
EFR7163 500whp/550wtq
I had this exact same problem on my built 15 STi. Car ran just fine, idled fine, made power. Had P0017. Changed oil, changed OCV, and a lot of what you've done. I was able to see from the AP that my LHOCV was stuck at 0. It wouldn't budge. You can read my thread here if it helps: http://www.iwsti.com/forums/2-5-lite...-symptoms.html
Checked timing and it had skipped two teeth. Installed a new timing belt and it hasn't come back since. I didn't read through this thread in super detail, but I'm not sure if you've completely inspected the timing belt or replaced it.
pet3r is offline   Reply With Quote
Old 05-03-2017, 07:41 PM   #67
Dreamtribejay
Member#: 432274
2011 Forester
I wish it was kust the timing belt but unfortunately its not looking like the case. I replaced the cam gear and had the timing belt off and made sure it was all lined up but the problem still exists?
Old 05-03-2017, 11:46 PM   #68
Subie_
Member#: 419354
2007 STI
Cool story brah
You should probably let the 2 guys you left hanging 2.5 months ago know the first reply you completely disregarded corrected your CEL.
Good looks.
Old 05-16-2017, 10:16 AM   #69
Dreamtribejay
Member#: 432274
2011 Forester
Dos anyone have a OCV plug with some wires i can buy/have? The blue one that plugs into the ocv. I have reson to believe that that may be the culprit to this p0021 problem.
Old 06-03-2017, 05:00 PM   #70
Dreamtribejay
Member#: 432274
2011 Forester
not that anyone pry reads this anymore but id like to say that the problem was found!!1
I was driving it normal on memorial day and it started making noise from the engine like a rod knock but from the cam shaft. A couple min later the car stalled and wouldn't start. So i took it to the builder and here said the the crank seemed to have some resistance. he then dropped the oil pan and said there where a bunch of material in there including a fun BERRY and stem!!! I kid you not! Ive never heard of this. So it starved the motor of oil and its done now. He claims then its not his fault and wont cover the 10000mile motor build.
Old 06-04-2017, 12:42 AM   #71
viper_crazy
Member#: 298403
2008 WRX Premium
Spark Silver
Lawsuit?
viper_crazy is offline   Reply With Quote
Old 06-04-2017, 08:19 PM   #72
Dreamtribejay
Member#: 432274
2011 Forester
Talking with another attorney tomorrow. Hopfully theres something we can do.
Old 06-05-2017, 02:08 AM   #73
viper_crazy
Member#: 298403
2008 WRX Premium
Spark Silver
I'd be interested in how that turned out, but it's mostly curiosity and unrelated to this thread, haha
Old 02-11-2018, 12:37 AM   #74
Dreamtribejay
Member#: 432274
2011 Forester
Sorry it's been awhile before I got back on here because I finally got my car back and finished. The company who built the previous motor ended up splitting the cost of a new-build for me and I had someone who knew what they were doing do it this time. Ive had it back 3 days now!!
Old 02-13-2018, 11:19 AM   #75
Owen_
Member#: 421262
2015 STi
WR Blue
I don't know if you've solved this or not, but I had this and a couple other cam related codes after building my engine a month or so ago.
I finally fixed it by replacing the cam gear itself. Afterward, we took apart the old cam gear and found that the rotor inside of it that is supposed to have some left/right play was completely seized and wouldn't move freely.
Owen_ is offline   Reply With Quote
