Welcome to the North American Subaru Impreza Owners Club Thursday November 15, 2018
Go Back   NASIOC > NASIOC Reviews > Car Part Reviews
Old 02-12-2018, 06:16 PM   #1
fredrik94087
Member Sales Rating: (2)
Member#: 337075
2015 WRX Stg3 SOLD
Default Killer B Motorsport Performance Radiator for 2015+ WRX
For now this review is just on quality and fitment as I have not had any track days since install. Should that happen, I will update.
Quick background:
I tried the Koyo Racing Radiator a while back and had serious fitment issues with factory fan and shroud. It required a slim fan. I learned that the slim fan with no shroud was no Bueno. I found a slim fan with shroud, but decided not to go that route.
I stayed with factory radiator/fans/shrouds for cooling until I got a sleeved block. The sleeved block gets a little bit hotter than the factory block. I already had a Perrin thermostatic oil cooler. I contemplated upgrading the oil cooler but was advised by some with a lot more experience to upgrade my radiator cooling.
This is where the KB unit came into play. It is (this may be an exaggeration...but) only millimeters thicker than the factory unit. You can read all about the core on the KB site.
Previously, I had chosen to swap my Grimmspeed Charge Pipe for a Perrin Charge Pipe for clearance. The GS pipe's rubber coupler is close to the factory fan motor, and moving that fan any closer would be an issue IMHO. The Perrin pipe with factory radiator had visibly more space.
Still, when the KB radiator was installed, the Perrin pipe had to be pushed further in toward the GS TMIC, but it all worked out well.
My installer was very impressed with quality, welds and fitment. In his opinion, the $1500 price was on par with the radiator he got for his race truck.
fredrik94087 is offline   Reply With Quote
Old 02-13-2018, 02:47 PM   #2
JarHarms
Member Sales Rating: (47)
Member#: 138994
06 WRX Ltd
Appreciate the review since I was interested in one of these. Although this is a $1500 built-to-order radiator so an installer's impression leaves me lacking... I guess it sure as heck better be nice and install with ease. This sort of radiator isn't one to compare to Mishi, CSR, Koyo, etc. radiators though. This seem more race purpose price point.
Killer B's web-store installed photos are nice and all but... I wish they provided more photos of the radiator itself so one could determine if it's worth the time calling in for more specific details.
No GD-version installed photos?
No idea what low-mount means (but I have an idea)?
Fan assembly mounts are threaded boss instead of tapered screw (usual aftermarket fare).
What does it have for a drain plug, how is it located?
Does it have provisions to mount all of the OEM coolant pipes, or not?
Are the overflow and deaeration nipples welded in alloy or are they threaded in fittings?
For that price, does it come with a pass-through heat exchanger built into the lower endtank?
JarHarms is offline   Reply With Quote
