02-14-2018, 01:53 PM | #1751 |
Member#: 460907
RMIC
Vehicle:2020 Golf GTI |
That log shows no overboosting and no boost creep. .5PSI over target is well within acceptable parameters- especially if it's that incredibly brief.
In the future you don't need to wind it out to 6700- the car is dead on power about 700rpm before that.
02-14-2018, 02:13 PM | #1752 |
Member#: 459692
South East
Vehicle:2019 WRX STI silica black |
No need to go past 6k? Is that for this particular tune or FA20s in general?
02-14-2018, 02:15 PM | #1753 |
Member#: 454701
If your car is dead on power at 6000 you need a new tuner
02-14-2018, 03:04 PM | #1754 |
Member#: 460907
RMIC
02-20-2018, 11:48 AM | #1755 |
Member#: 473595
-2017 WRX USDm
- Stock with Stage 1 93 OTS - 6MT - 93 - Stage 1 Cobb OTS - Mostly 3rd one of them was 4th https://datazap.me/u/bubbaracing/log...?log=1&data=12 https://datazap.me/u/bubbaracing/log...?log=0&data=12 https://datazap.me/u/bubbaracing/log...?log=2&data=12 Let me know if you see anything out of ordinary. Sometimes I get what feels like timing being pulled but I don't think it occurred on any of these logs. I'm use to tuning ls cars with hp tuners but am new to the AP and wrx tuning. I just received TGV deletes but haven't installed yet. Are there nay OTS maps for the delete or only custom tuning. Thanks! |
02-20-2018, 12:45 PM | #1756 |
Member#: 453427
MWSOC
Vehicle:2017 WRX Crystal White Pearl |
Looks pretty standard for OTS, no knock in the WOT areas just some small FKL during cruise in one of the logs (unavoidable on OTS, normal).
We need need AFR logged as well as commanded to get a better picture but I have a feeling its probably swinging richer than commanded. If you want to run the TGV deletes get the EGR delete kit and do both at the same time. You will need a custom map to run TGV deletes, also a 3 port boost control solenoid (Grimmspeed) is recommended by most tuners. |
02-20-2018, 01:16 PM | #1757 | |
Member#: 473595
Are you saying AFR on wideband? Or another AFR setting? I logged commanded fuel map and final, is there something else? Thanks guys! |
02-20-2018, 03:48 PM | #1758 | |
Member#: 327563
MWSOC
Vehicle:2018 Civic Type R 2008 N54 335i |
02-20-2018, 04:43 PM | #1759 |
Member#: 459692
South East
Is anyone in the process of getting an e tune from Mikey Botti?
02-20-2018, 06:00 PM | #1760 | |
Member#: 453427
MWSOC
02-20-2018, 06:07 PM | #1761 | |
Member#: 424692
Vehicle:2015 WRX WRB |
But agreed, skip delicious and get the Cobb setup. Way better. |
02-20-2018, 06:09 PM | #1762 |
Member#: 453427
MWSOC
I just recall them not tuning very well on flex and I also recall a MAF cable on an older unit that caused issues.
02-20-2018, 06:14 PM | #1763 |
Member#: 460907
RMIC
Delicious Tuning's MK2 can be used with Cobbs AP that any ProTuners can tune. Says that in the first sentence. DT's FF kit also has more features and BT integration for your phone. DT are also highly reputable tuners throughout the industry.
https://www.delicioustuning.com/flexfuelcobb |
02-20-2018, 08:28 PM | #1764 | |
Member#: 473595
02-20-2018, 10:09 PM | #1765 |
Member#: 387467
Vehicle:2018 WRX Limited WRB Stage 2 FlexFuel |
Oo I like the Bluetooth E content feature. I don’t run with my AP hooked up and that would be nice to do a spot check before refueling with an E blend. Would most flex Fuel tuners be able to use the DT kit if they can use the Cobb?
I don’t think I’m switching FF kits but I’d like to know the options |
02-20-2018, 10:46 PM | #1766 | ||
Member#: 460907
RMIC
02-22-2018, 01:13 AM | #1767 |
Member#: 332408
Here's mine my final tune. Tuned by Ron at PhatBotti.
https://datazap.me/u/ayau/log-151927...og=0&data=9-24 2015 WRX EGR, TGV, GS EBCS 6MT 93 Custom e-tune 3rd gear Overall, I'm very satisfied with the tune. Power delivery is way more linear compared to stock tune. Can definitely feel the extra power. |
02-22-2018, 04:51 PM | #1768 | |
Member#: 419593
02-22-2018, 07:16 PM | #1769 |
Member#: 332408
For someone that isn't experienced in looking at logs, what are some key things to look for when reading a log? What makes a good or bad log?
02-22-2018, 08:56 PM | #1770 |
Member#: 478447
NESIC
Vehicle:2018 WRX WR Blue |
would love to see a COBB vs MAP tune comparison as well. I have a 2018 that I want to stage 1 but unsure of the reliability of the more "aggressive" MAP tune.
02-22-2018, 08:59 PM | #1771 |
Member#: 460907
RMIC
There's dozens of Map logs and dozens of Cobb logs. Just look through the 71 pages.
02-22-2018, 10:01 PM | #1772 |
Member#: 453427
MWSOC
Both maps 93 octane, stock car.
MAP 91 STG1: https://datazap.me/u/gn4rwhals/maper...12-13-15-21-24 COBB 93 STG1 HWG: https://datazap.me/u/gn4rwhals/cobb-...24&zoom=89-525 Between these 2 the COBB 93 HWG tune is more aggressive but runs pig rich. |
02-23-2018, 08:17 AM | #1773 |
Member#: 419593
There are many logs here and I have done plenty myself. I prefer the MAP tune but the HWG COBB v300 maps are just as strong. MAP is smoother for sure but I was getting too much cruise knock driving around with both. E tune eliminated that issue and it picked up a lot more power in the midrange. I would honestly be very happy with the MAP tune power wise if it wasn't for the random knock issues. I like this tune a lot.
02-23-2018, 10:38 AM | #1774 | |
Member#: 393629
W. Canada
02-23-2018, 02:53 PM | #1775 |
Member#: 410759
Vehicle:2015 WRX Dark Gray |
Modlist :
invidia catless J - > stock catback Grimmspeed Intake Grimmspeed EBCS Grimmspeed TMIC P&L Chargepipe PRL TGV Delete PRL EGR Delete Grimmspeed Lightweight Crank Pulley https://datazap.me/u/cbussard/log-10...23-26-29-30-31 Absolutely happy with it so far. It pulls hard Last edited by Veritas1286; 02-23-2018 at 03:34 PM. |
