Welcome to the North American Subaru Impreza Owners Club Monday December 17, 2018
Old 05-31-2017, 09:00 PM   #3426
vicious_fishes
Member#: 158864
2003 SOHC destroker
Originally Posted by Jazz30-06 View Post
Somewhat, yea. People also ten to not try and argue with 3 other people that are providing facts and reasoning. That's a lot of work...
As far as the ECU selection, the 2500 might not be the best option. It really depends on what they want out of the car. After all, a full 2500 setup is around $3k, whereas something like an EMU will run most everything most people could want for around $1500. It just depends on end user requirements.
The haltech 750 will work if you run a falcon throttle body (i'm nasioc's unofficial dealer). The only downside is losing AVCS control, but I'm fairly confident it remains in an "always on" mode.
All the people saying the ez30 can't handle boost are crackpots. There are many ez30's running raptor superchargers for years at around 350whp completely unopened.
It is the toothpick rods that eventually break, following by frying the pistons. The cylinder walls themselves have stacks of material, the most you'll ever have to do is brace (pin) them to stop flex at very high power levels, and at that point you'd be a fool not to just get the deck closed.
Can we please stop posting BS.
Old 05-31-2017, 10:18 PM   #3427
Titter
Member#: 416107
2002 WRX Wagon
EJ207 Spec C 4EAT
Default The H6 Impreza Resource Thread
the 750 handles 6 injectors? i though it only did 4. thats good to know. the 2500 will do avcs tho.
what would be the USDM equivalent to the falcon throttle body?
Titter is offline   Reply With Quote
Old 06-01-2017, 02:24 AM   #3428
vicious_fishes
Member#: 158864
2003 SOHC destroker
Yes the 750 is for 6 cyl. It doesn't have fly by wire though.
There isn't one, if you want one you'll need to get one sent over by either me or see if you can find one on the australian ebay
Old 06-01-2017, 07:34 AM   #3429
Titter
Member#: 416107
2002 WRX Wagon
EJ207 Spec C 4EAT
ahh cool good to know ty.
Old 09-10-2017, 06:55 AM   #3430
vicious_fishes
Member#: 158864
2003 SOHC destroker
So totally out of the blue I know, but does anyone have an ez30 apart or know how thick the piston ringlands are?
I'd be interested to compare to the ej25 and maybe take a rough stab at what point they'd crack if you started winding boost into the stock engine.
Old 09-25-2017, 02:57 PM   #3431
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
www.surgelinetuning.com
Originally Posted by HumanBoost View Post
. My info comes from a well known Subaru engine builder who has many customers in this forum. This same company also builds (and races) many of those pre-built "Stage" short blocks (ej20, ej25, and ez30). Regarding Jeff Sponaugle's stock sleeve EZ30 "r" build:
1. How many miles were put on it?
2. What was the max rpm limit?
3. How much boost was run consistently?
. I never said the EZ30 "r" rods were not weak, they are. My research includes everything I could find on the internet including the Australian Liberty communities where some users reported sleeve problems when surpassing 10psi on stock EZ30 engine sleeves. Also, your last statement about the td04 and HX40 is misleading if both turbo's are outputting the same volume of airflow and a good intercooling system maintains the same air temperature into the motor. Keep in mind, "boost" is merely a measure of pressure inside the intake manifold. PV = nRT
The EZ30R in my car is coming up on 8 years old now. I run anywhere between 13 and 18psi depending on the use case.
This was at about 16psi, which is a map I ran for this road since this was my first time up this hill. (it was a closed road btw).
I ran my car yesterday at ORP at 16psi for the entire day, with most of that spent between 5k and 7k rpm at full throttle.
Honestly I am surprised how well this engine has held up given the significant abuse I have put it through. I have been running E85 for most of it's life, and with the power level I am running it is certainly knock resistant. I don't think I have ran regular gas in at least 6 years.
This is not a sleeved motor, just stock sleeves, ARP head studs, Supertech pistons, valves, and springs, Pauter rods, plus a really really old 35R. Factory rod and main bearings as well.
This winter the engine is coming out so I can put in the newer EZ from Perrins car (sleeved) that I am rebuilding.
Jeff Sponaugle
sponaugle is offline   Reply With Quote
Old 09-26-2017, 08:57 AM   #3432
vicious_fishes
Member#: 158864
2003 SOHC destroker
jeff - OEM pistons? what power level is it at?
Old 09-26-2017, 10:17 AM   #3433
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
Not OEM pistons...
Old 09-26-2017, 11:22 AM   #3434
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
As Patrick mentioned, supertech pistons. The stock pistons are both high compression and high silicon content, so not ideally suited for forced induction. I am running pretty big PWCs as well ( .004' ).
When I took apart Perrin's sleeved motor, I was surprised to see the PWCs were even larger ( almost .006' ). That engine ran great.
Power is between ~400whp and ~600whp depending on boost. I have usually run 16-18psi on the track, which is probably in the 500whp range.
I have been looking through the logs from this last track day, and I did have a few dips in oil pressure during hard cornering. Nothing crazy (down from perhaps 60psi to 35psi), but enough for me to consider looking at adding an accusump.
Jeff
Old 09-26-2017, 07:39 PM   #3435
vicious_fishes
Member#: 158864
2003 SOHC destroker
Ah yes, i missed that.
Yours is basically fully built with off the shelf components then. I'd be interested to see just how much abuse it could take before it went bang. I have plans of sticking a gtx4088 on mine when i build it, one day...
Old 10-04-2017, 04:04 PM   #3436
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
Originally Posted by Patrick Olsen View Post
I picked up an '01 Outback wiring harness through car-part.com from a place out in WA. Wow, that's a helluva lot bigger bundle of snakes than I appreciated from looking at my own car!
So, it only took a couple years, but I finally culled the above down to just the connectors and pigtails that plug into the harnesses on the engine:
So, now I have a harness, I just have to figure out what the heck to do with it.
Unfortunately, this aspect ^^^ hasn't changed.
Old 12-19-2017, 05:57 PM   #3437
jvangelder
Member#: 358395
05 STI
White with Rubber marks
Time to add another car to the H6 list.
I just picked up a late model ez30 with intentions of replacing the 257 in my track car (before it gives up ideally). I plan on running the motor on low boost on the factory rods, pistons etc at first and build a second bottom end as budget permits. From what im reading 350whp is attainable on stock parts on low boost (correct me if im wrong) which will be a nice boost in power from the 272 im tracking with currently.
Obligatory engine photo, overall it looks clean on the outside. My hunch is it was pressure washed though up close under the intake its pretty clean throughout as well.
Only 'damage' i see is the oil filter is bent, a hard coolant line that t's from what im guessing is a heater core feed and the tb circuit is broken and one of the Variable valve lift diagnosis oil pressure switch's is broken in two, my guess all caused from a rushed engine pull
I do have a couple of questions, was there ever aftermarket engine mounts made? something solid or with a urethane mount? And I see the factory ez30 system is a dead-headed rail type with a return off the factory regulator. Was that system sufficient on mild builds or is it necessary to convert it to a series or parallel system?
jvangelder is offline   Reply With Quote
Old 12-20-2017, 08:32 PM   #3438
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
On FB there's a "Six Swapped Subarus" group which I joined a few months back. Through that group I've found that there's a guy over in Russia (Sergey Kein) that makes engine mounts for the EZ engines (among others applications). I haven't ordered any yet, but some other folks here in the US have, and he seems to be legit.
Old 01-13-2018, 03:10 PM   #3439
502sti
Member#: 479916
Interesting idea
502sti is offline   Reply With Quote
Old 01-26-2018, 10:02 AM   #3440
vicious_fishes
Member#: 158864
2003 SOHC destroker
You can also get the old engine mounts from the alloy manifold EZ30D, which were actually harder/tougher than the liquid filled ones that replaced them on the EZ30R
Old 02-16-2018, 08:28 AM   #3441
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
I've decided to give up and let someone else do the harness merging for me, since I'm probably never going to get it done myself. Only took me a couple years to come to that conclusion. I contacted iWire a couple weeks ago and bounced some emails back and forth. They don't normally do the Vi-pec, but they're willing to take it on. Last night I finished getting the main harness out of the car. Had a couple things that I wanted to clarify with iWire to make sure I was sending them what they needed.
Pulling the harness makes me embarrassed to see the various hack jobs that have been done over the years - vampire taps here and there for keyless entry, stereo, DCCD controller, etc.
In the middle of the harness is the Spiider DCCD (center differential) controller, which iWire will also fix up.
Old 02-25-2018, 01:20 PM   #3442
jvangelder
Member#: 358395
05 STI
Started to make some headway. I decided I dont want to use the welded mounts and will make my own. My plan was to make an adapter to use an existing mount so I didnt have to re-invent the wheel twice. In my search for some reference photos I found that someone with a FF 818 did the same with his design adapting the group N mount, which will accept any other OEM style engine mount and he agreed to share his design with me.
This is where I am at now, The base's are over 2.5lbs each and the solid ej style mount is a lb which is heavier than I want, however I will verify the fitment before I spend time taking out weight.
Old 03-04-2018, 07:35 PM   #3443
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
Got all my wiring harness stuff shipped off to iWire a couple weeks ago. I asked about paying extra for a rush job (an option they offer on their website), but Brian said they were too stacked up to take on another rush job. So, he said it should be ready around the end of April.
In the meantime, I picked up a used set of 328x28mm Stoptechs, so I'll get those on the car. They came with cross-drilled rotors, so I'll use those on the street, and I've already bought a new set of slotted rotors that will be used on track. Yeah, I may be getting a little ahead of myself, but there's a faint light at the end of the tunnel now.
Old 03-05-2018, 12:40 PM   #3444
EVO_SLAYER_01
Member#: 482940
Subaru Stars EZ30 Swap Into 01 2.5 RS
Ok, guys, I am in the process of swapping out my 2.5 for a 3.0 H6. I have a 2001 Subaru Impreza RS if that means anything at all for this. The 3.0 is out of a 04 Legacy. I have all of the wiring and computers from both vehicles. My problem currently is that I cannot find the ECU Pinpoint wiring diagram anywhere! Any of you veterans wanna help a girl out? My husband and I are going CRAZY trying to find this mythical beast.
EVO_SLAYER_01 is offline   Reply With Quote
Old 03-06-2018, 07:37 AM   #3445
FiveZigen
Member#: 434175
Here you go:
http://jdmfsm.info/Auto/Japan/Subaru...S%20ENH6DO.pdf
The ECU pin out is on page EN(H6DO)-26.
You will also need info from here:
http://jdmfsm.info/Auto/Japan/Subaru...YSTEM%20WI.pdf
Best of luck with your build.
Ryan
FiveZigen is offline   Reply With Quote
Old 03-07-2018, 06:19 PM   #3446
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
anyone experimented with headerbacks? trying to find out best flowing diameters for runners/header to Y pipe joint, and Y pipe to muffler
Hyper is online now   Reply With Quote
Old 03-13-2018, 08:39 PM   #3447
Samiam1017
Member#: 334068
for my 818 project i repoured the factory mounts with liquid urethane. made them thinner so i can space the engine back up to where i wanted it easily.
Samiam1017 is offline   Reply With Quote
Old 04-30-2018, 05:33 PM   #3448
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
Just talked to Brian @ iWire and paid off the invoice, my harness should be shipping out today or tomorrow. I'm going to have to actually get my ass in gear and get to work on this thing soon!
Any pics of what you did? I'm not sure I understand how you made them thinner.
Old 04-30-2018, 05:49 PM   #3449
RedMonkey999
Member#: 191476
2005 2.5RS
Congrats, I'll be watching intently. Remind me what EM you're running, V88? G4? I'm also curious about how much it cost, we can talk via PM if you don't want to share with the group.
RedMonkey999 is offline   Reply With Quote
Old 05-01-2018, 09:56 PM   #3450
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
Vi-pec V88. I'll shoot you a PM.
Vag-Com cable resource thread cooleys04 Open Source Reflashes 283 04-03-2018 02:04 PM
The Impreza @$$ Thread - The Beautiful Impreza Backside! PICS! Upscale_Automotive Member's Car Gallery 8 10-03-2007 05:56 AM
The 2008 Impreza Photoshop thread...post them here adizon Member's Car Gallery 307 09-20-2007 12:36 AM
The 2006 Impreza/Impreza WRX/Impreza WRX-STi thread (merged thread) wrxpeed News & Rumors 938 05-17-2005 12:11 AM
Photo - Anders "loving on" the H6 Impreza Fred South East Region Forum 8 02-23-2004 06:04 PM
