Welcome to the North American Subaru Impreza Owners Club Thursday August 13, 2020
Mid Atlantic Impreza Club
Old 02-17-2018, 12:22 AM   #4101
RavensFan7
Member#: 346388
2001 Ej205 Impreza L
SRP
Default What did you really do to your car today? V3.1
Worked on my tune a little bit earlier while it was still warm out. Made some small adjustments to WGDC and a few other tables. The constantly changing weather has me backtracking, but its back to hitting my 20 psi target and holding 20 steadily up top.
Also set things up to get some more progress on my spare engine build this weekend. Gonna finish disassembling a set of ej205 heads, and maybe slap a 2.5 pan and pick up on my spare shortblock.
Originally Posted by carnz-pj-410 View Post
EZ30 with 6MT in a 2nd gen LGT should be a hoot
Originally Posted by Patrick Olsen View Post
That's my hope. Maybe someday I'll actually finish the project and find out!
Harness and ECU are on the way to iWire.
I agree. Sounds fun!
RavensFan7 is offline   Reply With Quote
Old 02-20-2018, 11:57 AM   #4102
Mr. Projekt
Member#: 240189
2018 WRX Premium
CWP
does it count if I finally ordered my '18 WRX Limited today?
Mr. Projekt is offline   Reply With Quote
Old 02-22-2018, 05:43 PM   #4103
weenerdog3443
Member#: 395225
Oil change time
weenerdog3443 is offline   Reply With Quote
Old 02-22-2018, 06:56 PM   #4104
tramp
Member#: 459629
2017 WRX base
WR Blue
Fresh air filter.
tramp is offline   Reply With Quote
Old 02-22-2018, 11:41 PM   #4105
corona672
Member#: 262902
'04 WRX Hybrid
It's a wrap!
Sexy skid plate^^
Never heard of them - looks like a fairly niche company.
Decided I didn't need these window motor things anymore. Bolted the window holder to secure glass in up position - thinking about how to rivet down lexan and still be able to open the door without critical window flopping at speed.
https://i.imgur.com/F79EX2y.jpg
I have 52lbs more I can lose, not much cash left, and a new angle grinder..
corona672 is offline   Reply With Quote
Old 02-23-2018, 05:52 AM   #4106
weenerdog3443
Member#: 395225
Originally Posted by corona672 View Post
Sexy skid plate^^
Thanks. Tbw I believe, ordered off Amazon for like 150 or something silly cheap
Old 02-24-2018, 10:37 PM   #4107
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
- Picked up a used set of 328x28mm Stoptechs for the Legacy, reflecting my newfound optimism that it will someday live again.
- Heli-coil'd one of the mounting holes on one of the Stoptech brackets. Other than those buggered threads, everything appears to be in good shape.
- Did a quick test fit:
(Stoptech vs WRX rotor)
- Got the Impreza towed home after it died suddenly while out running errands. I'm thinking maybe fuel pump or fuel pump relay? I was doing ~60mph when it died. Coasted to a side road and onto the shoulder. Tried to re-start it as I was coasting, no joy. Once I was on the shoulder I tried again and it did run for a couple seconds, but as soon as I tried to get moving it died again. It would crank over just fine, but wouldn't fire. Of course this all transpired as it was getting dark, so I'll do more troubleshooting when I have some daylight to work with.
Old 02-26-2018, 06:23 PM   #4108
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
Went out to troubleshoot a short while ago. Car started up just fine, ran for 20 or 30 seconds, and moved under its own power. Needless to say, having a problem magically fix itself doesn't give me a warm fuzzy for driving the car anywhere.
Old 02-27-2018, 08:25 AM   #4109
Fishhunter911
Member#: 464074
2018 WRX
Traded it for a 2018 WRX
Fishhunter911 is offline   Reply With Quote
Old 02-27-2018, 09:17 PM   #4110
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
Congrats!
Old 02-27-2018, 09:47 PM   #4111
j4k3
Member#: 262126
2007 STI
Put 40 miles on it after it’s been sitting since November. Wanted to do a week of driving it to shake it down before I list it for sale. Not sure it’s getting listed now.
j4k3 is offline   Reply With Quote
Old 03-04-2018, 06:18 AM   #4112
weenerdog3443
Member#: 395225
What is going on here
Old 03-04-2018, 06:29 PM   #4113
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
- On the advice of a couple folks in the N/A Powertrain forum, I replaced the fuel filter today, and I think that should fix the problem. I drained the old filter out through the inlet and what came out was pretty dark (rust-colored). While the filter was removed, I put a bottle on the fuel supply line and cycled the ignition a couple times to get the fuel pump to kick on. That fuel was nice and clean, so I'm reasonably certain the problem was just a fuel filter in need of replacing.
Old 03-05-2018, 07:30 PM   #4114
DavC825
Member#: 201736
12 IS-F Sold!! :(
Slowest 07 STi
whos the tuner
DavC825 is offline   Reply With Quote
Old 03-07-2018, 12:36 PM   #4115
carnz-pj-410
Member#: 110994
1995 Turbo Impreza
701whp 05 2.5XS Forester
New 04 STi steering rack and jdm GC turbo crossmember for my swapped coupe
https://i.imgur.com/aOd8kuD.jpg
carnz-pj-410 is offline   Reply With Quote
Old 03-07-2018, 01:31 PM   #4116
RavensFan7
Member#: 346388
SRP
Very nice! I have the JDM GC crossmember on my coupe as well. Hope they're not getting too hard to find (or expensive) cause I need one for my other car soon
Old 03-07-2018, 01:33 PM   #4117
carnz-pj-410
Member#: 110994
1995 Turbo Impreza
You can still order them right from Subaru!
Old 03-07-2018, 02:05 PM   #4118
RavensFan7
Member#: 346388
SRP
Hmm good to know the dealer can still get the crossmember. The price isn't too bad for being new either....I think I got mine used for 200 shipped a few years back.
Did you catch how many were left over here? The GC parts are dwindling down lol. I bought one of the last JDM GC aluminum hoods last year.
Old 03-07-2018, 02:22 PM   #4119
carnz-pj-410
Member#: 110994
1995 Turbo Impreza
when I bought mine there were 5 remaining, I just logged on to check current stock status and there are 3 in the USA warehouses.
there are 53 Aluminum GC hoods in the USA warehouses right now, just got another resupply of them (35 more).
I plan to buy an Alum hood soon, I've been rebuilding my entire car from back to front. Getting close to being finished!
Old 03-07-2018, 03:44 PM   #4120
RavensFan7
Member#: 346388
SRP
Well that's good to know that they will still resupply some GC parts that are getting low. For some reason I was under the impression that once they're out of stock here, we'd have to individually order from Japan, or whatever country has them.
Now that I think about it, it was probably 2 years ago when I got my hood and they said there wasn't many left. It was shipped from an Oregon warehouse I think. I felt bad taking one from the west coast people....but now that you said there's 53 here, I don't feel bad at all.
Old 03-07-2018, 03:56 PM   #4121
carnz-pj-410
Member#: 110994
1995 Turbo Impreza
If you need to know availability of any usdm GC/GM parts shoot me a PM and i'll check it out. I have been buying parts for my car that I notice are low stock before they all run out and don't get resupplied.
I majorly regret not buying new Coupe rear quarter window mouldings when they were available. I have 3 sets of them but they are all messed up in some way and it drives me nuts
Old 03-07-2018, 06:14 PM   #4122
Tc51
Member#: 451515
2017 WRX & 2003 WRX
CWP
Where do you go to look at inventories on parts?
Tc51 is offline   Reply With Quote
Old 03-07-2018, 06:28 PM   #4123
RavensFan7
Member#: 346388
SRP
Cool I'll keep that in mind
And yea i feel you on the 1/4 window trim. My driver side got partially broken off during the winds last week. Gonna have to start searching through the pick n pulls I guess
Old 03-08-2018, 11:35 AM   #4124
Matt
Allergic to turbos
Member#: 181
What year is your Impreza? I'm posting from my telephone so it isn't the best.
I had an issue similar to this with my old 1.8L Impreza. Turned out to be the cam angle sensor. Infuriating, but less than $100 to fix.
Matt is offline   Reply With Quote
Old 03-08-2018, 06:01 PM   #4125
carnz-pj-410
Member#: 110994
1995 Turbo Impreza
Installed TEIN EDFC motors and started routing the harnesses today,
pulled old front crossmember and steering rack to prep for new crossmember and steering rack install
