03-21-2018, 01:21 PM | #1951 |
Member#: 453427
MWSOC
Vehicle:2017 WRX Crystal White Pearl |
The stock throttle is really bad, like almost unbearable, its the #1 reason for tuning.
03-21-2018, 01:29 PM | #1952 |
Member#: 453427
MWSOC
I asked Ian about the changes in the MAPerformance thread he monitors, lets see what we get as a response.
03-21-2018, 01:50 PM | #1953 |
Member#: 332408
03-21-2018, 01:56 PM | #1954 | |
Member#: 453427
MWSOC
COBB maps work for I'd say 80% of the cars, the V5 beta MAPerformance map has also given me no trouble, something changed in V7 though. |
03-21-2018, 02:01 PM | #1955 | |
Member#: 332408
For $300, you can get a healthy 15-20% bump from a good e-tuner on a completely stock car. I'd throw in EGR, TGV, and boost controller if you don't mind wrenching. |
03-21-2018, 02:25 PM | #1956 |
Member#: 483649
SCIC
Vehicle:2015 WRX CBS |
I bought the AP from MAP so the MAP OTS is essentially free. Def going to dynotune in the future. I gotta figure out the TGV and EGR codes b/c Ca smog is a PITA.
03-21-2018, 02:27 PM | #1957 |
Member#: 453427
MWSOC
I completely agree, turns out my MY2017+ has alot of 1 use clamps and diagnostic connections when compared to the MY2015-2016, right now I'm just spotting the differences and planning out engine mods.
I 100% agree that a custom map is the way to go, but the MAPerformance OTS was a great in between for most people. I was on the V5 beta, the V7 looks to have changed quite a bit. |
03-21-2018, 06:24 PM | #1958 | |
Member#: 419593
The target AFR on their 93 tunes was always on the lean side. 11.7 IIRC on the prior revisions. This one seems to be targeting 11.4. Here is another log if you would like to take a quick look: https://datazap.me/u/e90/map-v70?log...1-2-3-10-13-27 |
03-21-2018, 06:35 PM | #1959 |
Member#: 419593
It is hard to explain. It is these little things here and there that make this tune very enjoyable. It is certainly nowhere near as strong as my custom tune but it is smoother, the throttle input is perfect IMO, the way the revs climb and drop, specially in 2nd and 3rd gears (where I spend most of my time), is also perfect. It sounds different too in a better way, hard to explain really. The car just feels happy and not over stressed if that makes any sense. It does register knock a bit more, but that is to be expected for an OTS tune but on the other hand who knows how much the sensors are desensitized with etunes...So the actual difference may not be as big as the AP screen would make you believe. I also think that there is a little more room left on the table in terms of power, which maybe easier on the clutch in the long run.
03-21-2018, 10:46 PM | #1960 | |
Member#: 244192
NESIC
03-21-2018, 11:19 PM | #1961 |
Member#: 460907
RMIC
Vehicle:2020 Golf GTI |
FTCL makes sure you are always hitting target AFR at WOT (unless your O2 sensor is fouled) and it also allows for a little better gas mileage as well. Other benefits as well but those I am most familiar with.
It 100% is. Ask anyone tuned by JR, PhatBotti, Clark, Bren-the difference is night and day. If an OTS map is at any point better than your E tune than your E tuner sucks hardcore balls. |
03-22-2018, 12:36 AM | #1962 |
Member#: 483649
SCIC
Thanks guys, for taking the time to check my log from yesterday. I did another three pulls today with Cobb 91. Same tank of gas, same roads, pretty much identical conditions. I think it did a lot better. Almost no FKL except for one pull at -1.41 but it seemed to "unlearn" back to 0 itself during the pull. The other pulls had no knock whatsoever.
https://datazap.me/u/sjxie1990/cobb-...&zoom=577-1231 Although the Cobb OTS did show some FKL at -1.41 when just cruising but I dont think i should worry about that. Also, this isn't because Cobb desensitizes the Knock Sensors right? I there was such a huge difference in WOT knocking so I'm really hoping it's a legit reduction. Also just curious, the AF CORR 1 % flattens to 0 at about 3448rpm, is this the transition form Closed to Open loop? The COMM FUEL AFR also as a large deviation at the same spot. Cobb OTS def feels less powerful but ill stick with it until protune. Last edited by sweet101; 03-22-2018 at 12:49 AM. |
03-22-2018, 01:02 AM | #1963 | |
Member#: 483649
SCIC
03-22-2018, 11:05 AM | #1964 |
Member#: 244192
NESIC
There is no night and day difference between open loop and closed loop if it's tuned properly.... It's the same... Closed loop is adjusting the fuel injection all the time to keep it on target. The reason why it is removing 10% is because of the O2 scaling. It's off from the factory... Notice on the Cobb map that the AFR reading from the O2 sensor is richer than target... The car is actually running target, but since it's in OL on the Cobb map, it's not going to correct it when the O2 is reading different than target. You can verify this by an actual wideband, which is what I did. It's also needed to get the correct scaling for the O2 sensor. I simply scaled the O2 to what the dyno was reading and it works perfect
03-22-2018, 01:29 PM | #1965 | |
Member#: 391748
NESIC
Vehicle:2015 WRX CWP (sold) 2019 STi CWP |
03-22-2018, 02:04 PM | #1966 |
Member#: 393545
Vehicle:2015 WRX (6MT) DGM |
Guys, just to clarify you are saying that the O2 scaling is off, not the MAF scaling?
More and more I've been wishing I had a dyno in my garage to play around with all day... |
03-22-2018, 02:44 PM | #1967 |
Member#: 391748
NESIC
03-22-2018, 04:28 PM | #1968 | |
Member#: 419593
03-22-2018, 04:30 PM | #1969 |
Member#: 460907
RMIC
I would say reputable tuners understand the o2 scaling problems and adjust fueling and fueling targets to compensate.
03-22-2018, 04:42 PM | #1970 | |
Member#: 244192
NESIC
03-22-2018, 04:49 PM | #1971 | |
Member#: 391748
NESIC
My car targets mid 10 to 11, reads high 10 to low 11 on factory sensor, runs dead on the dyno sniffer. Lots of FTCL etunes probably running pretty rich. even my scaling when i was making maps was probably rich, this is why I left them on the leaner side of target if you look at my logs. not hurting anything, just leaving a little power on the table. |
03-22-2018, 05:16 PM | #1972 | |
Member#: 419593
03-23-2018, 09:06 AM | #1973 | |
Member#: 244192
NESIC
03-23-2018, 09:22 AM | #1974 | |
Member#: 391748
NESIC
That being said I still think looking at the dyno afr plot is the way to go as those are (hopefully) calibrated regularly |
03-23-2018, 09:42 AM | #1975 |
Member#: 327563
MWSOC
Vehicle:2018 Civic Type R 2008 N54 335i |
