Welcome to the North American Subaru Impreza Owners Club Wednesday January 23, 2019
Old 12-12-2017, 01:28 PM   #1
KNS Brakes
Member#: 125739
2007 1500HD
Need Brakes? 919.420.0021
Default 2018 STI Brembo Brakes
The pads and rotors used on the 2018 STI are confirmed now so we can prepare for next year. It will take a while to have reasonable parts for these brakes.
I am going to have GiroDisc make 2 piece front and rear rotors.
UPDATE - WE CAN ONLY MAKE FRONTS. REARS WOULD REQUIRE A SHORTER PAD OR GRINDING A LOT OF THE STOCK PAD. NO BUENO
I am going to have DBA make KNS rotors.
UPDATE - ALL SYSTEMS GO - CALL ME IN THE FALL!
Pad choices will be OK - fronts are already out but rears are going to take a bit.
UPDATE - REAR PADS ARE ALL NEW BUT WE SHOULD HAVE THEM IN FEBRUARY
I need to get a set of brake lines as well.
DAMMIT _ AM I GOING TO HAVE TO BUY THOSE TOO?
Rotors
Front - 340mmx30mm and drilled -24.5 pounds. Pad Annulus = 59mm.
The overall height is 54mm but my measurement of that was crude. Just a small change there.
Nice black finish though
Rotors
Rear - 326mmx20mm and drilled -17.5 pounds. Pad Annulus = 54mm.
The overall height is 63.5mm which appears to be unchanged.
Front Pads
Rear Pads
It's ALMOST but not quite this.
Old 12-12-2017, 01:36 PM   #2
rexworx
Member#: 103232
GTX 3071R'd 11WRX
PPG,4.44,LSD,E85,6spdx3
Very nice!
rexworx is offline   Reply With Quote
Old 12-13-2017, 01:18 PM   #3
KNS Brakes
Member#: 125739
2007 1500HD
I ordered rear brake pads from the dealer and they are backordered until January 22nd.
Old 12-13-2017, 01:51 PM   #4
Samurai Jack
Member#: 21145
2002 Enemy of Aku
So, why drilled and not slotted?
Many are aware of the problem with drilled rotors cracking at the drill points.
Old 12-21-2017, 07:06 PM   #5
KNS Brakes
Member#: 125739
2007 1500HD
I can only assume people still think that drilled = performance.
Old 12-21-2017, 07:12 PM   #6
KNS Brakes
Member#: 125739
2007 1500HD
The good news is Dan at Mach V verified what pads fit the 2018 STI.
The bad news is that Dan at Mach V Motorsports verified what pads (do) not fit the 2018 STI
I was correct that the D1365 shape fits the front of the 2018 STI and Hawk's version of it will fit. Depending on what you get there may be a wear sensor cutout but that does not matter.
The rear shape is ALMOST the D1366 shape but not so fast. They actually moved the pin holes for some unknown reason so the backing plate will have to be new.
Check it out.
2018 STI rear pad on the right. ISF pad (Hawk HPS) on the left.
And for comparison sake - here is how much bigger the new rear pad is.
Old 01-11-2018, 12:58 PM   #7
KNS Brakes
Member#: 125739
2007 1500HD
We got the pads in and they are off to GLoc to get this going.
2018 Subaru STI rear brake pads
Old 03-07-2018, 10:03 AM   #8
KNS Brakes
Member#: 125739
2007 1500HD
Track pads are now in stock in selected compounds
http://www.knsbrakes.com/c/car-items...ace+Brake+Pads
Old 04-30-2018, 10:40 AM   #9
Barge
Member#: 62941
2004 Forester XT
Do you have any measurements comparing dimensions if these to the older rotors?
Is the wheel clearance to the face the same?
Barge is offline   Reply With Quote
Old 04-30-2018, 11:05 AM   #10
KNS Brakes
Member#: 125739
2007 1500HD
I did not measure the offset so I am not sure if it is exactly the same.
Old 05-03-2018, 10:01 PM   #11
MrEngineerGuy
Member#: 470131
2018 STI
Any update on a Brake line Kit in the future? I have seen a lot of yes fit no fit on online retailers so far.
MrEngineerGuy is offline   Reply With Quote
Old 05-04-2018, 11:23 AM   #12
KNS Brakes
Member#: 125739
2007 1500HD
I thought it was confirmed that the '17 lines worked?
-Ken
Old 05-09-2018, 11:38 AM   #13
MrEngineerGuy
Member#: 470131
2018 STI
Thanks for the info!
Old 05-16-2018, 09:24 PM   #14
TopazM3
Member#: 483211
Are there any 2018 STI front rotor options that are not drilled? Mine got heat stress cracking in four track days. I haven’t found anything so far.
TopazM3 is offline   Reply With Quote
Old 05-16-2018, 10:29 PM   #15
ifearnoevo
Member#: 475635
2016 WRX STI
Wrb
Originally Posted by TopazM3 View Post
Are there any 2018 STI front rotor options that are not drilled? Mine got heat stress cracking in four track days. I havenít found anything so far.
http://www.subispeed.com/2015-subaru...i#.WvzazqUpA0M it says they will fit 18 sti
ifearnoevo is offline   Reply With Quote
Old 05-16-2018, 11:35 PM   #16
jamal
Member#: 71875
Originally Posted by ifearnoevo View Post
They definitely won't. That's the 326mm rotor for 4-pot brembos.
jamal is offline   Reply With Quote
Old 05-17-2018, 11:00 AM   #17
KNS Brakes
Member#: 125739
2007 1500HD
I have 2 piece Girodisc rotors in stock for these now.
http://www.knsbrakes.com/c/car-serie...+Rotors+-+PAIR
Old 05-19-2018, 12:37 PM   #18
TopazM3
Member#: 483211
What is the cost for the replacement rotors?
Old 05-21-2018, 11:02 AM   #19
KNS Brakes
Member#: 125739
2007 1500HD
I did not get that info yet - but I would guess around $600/pair like most of the others.
Less than OEM 1 piece drilled rotors .
Old 05-21-2018, 02:55 PM   #20
MORGSY
Member#: 408655
18 STI
CWP
Nice upgrade over OEM
MORGSY is offline   Reply With Quote
Old 05-23-2018, 10:48 AM   #21
TopazM3
Member#: 483211
Old 06-10-2018, 12:37 AM   #22
bloodyBug_
Member#: 389775
2017 WRX premium
Crystal white
Is the girodisc still the only other option for rotors so far? Rotors are he only thing keeping me doing the 2018 swap oh my 17 wrx
bloodyBug_ is offline   Reply With Quote
