Welcome to the North American Subaru Impreza Owners Club Saturday January 19, 2019
Old 06-07-2018, 11:17 AM   #876
JamesEub
Member#: 373837
Facility: Surgeline Tuning, Oregon
Type of Dyno: Mustang
Baseline # for a stocker at the dyno: ~220
Boost: 19.5psi peak
Fuel: 92 octane
Target AFR: 11.0
SAE Corrections: 1
Peak HP at RPM: 314 @ 6100
Peak Torque at RPM: 280 @ 5450
Mods:
Chassis: 98 SF Forester
EJ205 2.0L
Wiseco Pistons
Manley Rods
King bearings
Stock Heads - stock cams, stock valves, stock springs.
OEM header - ported out/gasket matched
Blouch 16G-XT turbo
1000cc ID injectors
Full TGV's intact
Walbro 255l
DC Sports Intake
SRS Type-RE full 3" exhaust
Catless 3" DP
all other supporting mods
Power: 314whp / 280 wtq - 75 degree day, damn near sea level.
JamesEub is offline   Reply With Quote
Old 06-07-2018, 01:12 PM   #877
maperformance
Member#: 141043
2011 STI
black af
My Wifes 2015 WRX
Facility: MAPerformance
Type of Dyno: Dynojet
Baseline # 222whp 265wtq
Boost: 22 psi
Fuel: 93 octane
Target AFR: 11:4's
SAE Corrections: 5
Peak HP at RPM: 350.61 5600 rpm
Peak Torque at RPM: 365.54 4400 rpm
Mods:
MAPerformance short block
Manley 10:1 pistons
Manley Turbo Tuff rods
King XP bearings
MAPerformance Stage 3 heads (slightly ported)
GSC valve springs/retainers
Steamspeed STX67 turbo
MAPerformance 3" intake
MAPerformance catless J-pipe
MAPerformance cat back
ETS FMIC
Aluminati TGV deletes
Aluminati EGR delete
Perrin BPV
ACT HDSS clutch/flywheel
Tuned by Ron Watson on 93 octane fuel, 72 degrees, 814ft elevation:
maperformance is offline   Reply With Quote
Old 06-23-2018, 04:59 PM   #878
dev6565
Member#: 424131
2006 WRX Limited
2006 WRX Limited w/ 04 STI 6-speed swap
150343 miles at beginning of tune, original stock EJ255
Facility: Topspeed Motorsports Alpharetta, GA
Tuner: Taylor Leier
Temp: 83 degrees F
Altitude: 1135 ft
Type of Dyno: Dynojet Research
Tuning Strategy: Full speed density and flex fuel
Baseline #: Car was at 310whp/321ft lbs @17 psi on 92
octane according to a dyno chart from before I bought it.
Boost: 21psi peak and tapering
Fuel: Shell 93/E77
Target AFR: 11.2
SAE Corrections: STD Smoothing-5
Peak HP at RPM: 93 = [email protected] / E77 = [email protected]
Peak Torque at RPM: 93 = [email protected] / E77 = [email protected]
Mods:
• Cobb AP V3
• VF39 turbo
• Tial F38mm external wastegate
• Tial Q Bov
• Grimmspeed 3-port EBCS
• Cobb FMIC
• Perrin short ram intake
• Walbro 255
• TiTek catless downpipe straight back to Blitz Nur Spec axleback
• KSTech secondary air pump delete plates
• Cobb Flex Fuel kit
• IAG v2 fuel rails w/dampers
• IAG braided fuel lines
• IAG tgv housings
• Aeromotive adjustable fuel pressure regulator at 43 psi
• Cobb/ID1300 topfeed injectors
• Grimmspeed pnp intake manifold
• Omni 4 bar map sensor
• Cobb MAF delete plate
• GM IAT sensor
Comments: Cylinder 4 coilpack was showing its age and intermittently misfiring. Didn't get in the way of tuning so we pressed on but it'll need to be replaced. Also broke the welds on the turbo internal wastegate midway through a pull but we were able to wedge a screwdriver in the actuator arm to keep it shut and after that we had no more problems finishing up. Will get a bracket on that actuator this coming weekend to hold it shut but until then the janky screwdriver fix is holding solid!
Overall I've very impressed with the car and the little VF39! E really woke this thing up!
Yes of course I can see that the turbo is too small for this motor and it can't hold power up top but for now this is more than enough for me and has really freshened the car up. It's a lot of fun on the street and in the curves. Should be an excellent setup for autox.
Built shortblock, heads, and a bigger turbo (thinking about a Blouch Dom 1.5 XTR right now) are in the future when finances allow.
dev6565 is offline   Reply With Quote
Old 06-26-2018, 02:42 PM   #879
VanWo
Member#: 447721
2017 WRX Limited
2017 WRX
Facility: Snail Performance AZ
Baseline # ~220whp from other 17' WRX on same dyno
Boost: 22 psi
Fuel: E65 (flex fuel with 91ACN)
Peak HP at RPM: 379 @ 6000 rpm
Peak Torque at RPM: 354 @ 4200 rpm (dialed back from 392 because rods)
Mods:
Cobb AP
Cobb Flexfuel
Invidia Catless J-pipe
Invidia R400 Catback
Grimmspeed Stealthbox Intake
Grimmspeed EBCS
Boomba BPV
PRL EGR/TGV Deletes
DW300C Fuel Pump
IAG AOS
Perrin Turbo Sump Restrictor
Tuned by Taylor Wilson on E65, 110 degrees ambient , 1,086ft elevation.
Charts are unfiltered.
Shows E65 and 91ACN numbers.
VanWo is offline   Reply With Quote
Old 06-27-2018, 06:40 PM   #880
Superorb
Member#: 135252
2002 WRX Wagon
^^ On the stock turbo?
Superorb is offline   Reply With Quote
Old 06-27-2018, 07:26 PM   #881
VanWo
Member#: 447721
2017 WRX Limited
Yes sir. Stock turbo, stock trans, stock clutch, stock headers and stock intercooler too.
Old 06-27-2018, 08:15 PM   #882
BlackSun
Member#: 93591
2007 WRX STi Limited
UGM
Originally Posted by VanWo View Post
2017 WRX
Boost: 22 psi
Mods:
Cobb AP
Cobb Flexfuel
Grimmspeed EBCS
Boomba BPV
PRL EGR/TGV Deletes
DW300C Fuel Pump
IAG AOS
BlackSun is offline   Reply With Quote
Old 06-28-2018, 12:32 AM   #883
Superorb
Member#: 135252
2002 WRX Wagon
Good numbers.
Originally Posted by BlackSun View Post
Same.
Old 06-28-2018, 02:01 PM   #884
1wrxtra
Member#: 316364
Originally Posted by Subi117 View Post
no other mods other than what you listed? those numbers are impressive for those mods.
He's basically stage 1... this dyno is insanely inflated unless he left out a bunch of mods. He also listed the wrong value for HP... he wrote in the second torque #. The dyno shows 312 hp 354 tq on his first run, 296/326 for his second run.
Old 06-28-2018, 06:18 PM   #885
VanWo
Member#: 447721
2017 WRX Limited
Good numbers.
Same.
Thanks...So why we having popcorn?
Old 06-28-2018, 07:01 PM   #886
GlarryHoodDIT
Member#: 460907
2016 WRX
Good numbers, that dyno reads a little high from what I remember- JeremyAZ I think it was making 440s with a so-cal ported wheel, so definitely not a heartbreaker by any means.
GlarryHoodDIT is offline   Reply With Quote
Old 06-28-2018, 07:23 PM   #887
VanWo
Member#: 447721
2017 WRX Limited
I didn't know any Mustang dynos read high lol atleast compared to a Dynojet.
Also, I thought Jeremy was tuned by Clark.
Either way all i know for sure is I picked up 160hp from stock, that will hold true on any dyno. Not too shabby for only about $4k for parts and tuning .
Old 07-22-2018, 01:43 AM   #888
tokensti
Member#: 132262
2017 WRX
RED
Default Post your Dyno Plot and Mods, see format inside.
2017 WRX
Manual transmission
Mods
Cobb AP
Cobb Flex Fuel kit
MAP Intake
MAP Charge pipe
MAP J-Pipe/Downpipe
ISR CATBACK
Boomba BVP/BOV
Perrin Oil Cap
Perrin EBCS
Perrin Shifter stop
Perrin solid shifter bushing
Perrin Pitch Stop Mount
OLM S-LINE DRY CARBON FIBER FUEL COVER
OLM S-LINE DRY CARBON FIBER FENDER INSERTS
OLM HID Headlight low beam Bulbs
OLM LED Highbeam/DRL
SuperStick dip stick
Process West Viticool Top Mount IC
IAG TGV deletes
Place-DBW Motorsports
Mustang Dyno
93 Octane 354HP/332TQ
E70 411HP/380TQ
tokensti is offline   Reply With Quote
Old 07-29-2018, 12:00 PM   #889
pelos125
Member#: 351203
2016 Impreza Wrx Sti
Red
2016 Sti
Cobb ap
Takeda Intake
Agency Power Downpipe
MAGNAFLOW Exhaust
Cobb 725cc fuel injectors
Aem 320lph fuel pump
DIY stumble fix
Hks ssqv3 BOV
Grimmspeed 3 port boost controller
4 bar omni map sensor/gm iat sensor, speed density conversion
93 octane 319 hp 337 tq on dyno jet
Tuned by CP Motorsports in Houston, TX
https://www.facebook.com/68201840851...5529525160606/
pelos125 is offline   Reply With Quote
Old 08-06-2018, 07:42 PM   #890
trevorgarr
Member#: 489775
hopefully mine will be posted in the forum soon!
trevorgarr is offline   Reply With Quote
Old 08-30-2018, 12:07 PM   #891
Nujabes
Member#: 478853
2014 WRX Hatch
Cobb AP
Cobb intake with airbox
Cobb catted dp with heatshield
Grimmspeed 3 Port boost controller
93 Octane / 286 hp 317 tq on Dyno jet
Tuned by Precision Tuning in Spotswood, NJ
Nujabes is offline   Reply With Quote
Old 09-04-2018, 01:02 PM   #892
slowstipj
Member#: 491026
2018 STi
Facility: Surgeline Tuning (Portland OR)
Baseline # for a stocker at the dyno: 268whp/270wtq
Boost: 18.1psi
Fuel: 92oct
Target AFR:
SAE Corrections: 1
Peak HP at RPM: 276 @ 5800
Peak Torque at RPM: 316 @ 3700
Mods:
AntSpec Catback
APv3
slowstipj is offline   Reply With Quote
Old 09-06-2018, 03:15 PM   #893
brian_14sti
Member#: 482036
2014 STi Hatch
Plasma Blue Pearl
2014 STi
Facility: IAG Performance
Type of Dyno: DynoJet
Boost: 19.87psi
Fuel: 93 octane
Peak HP at RPM: 321 @ 5250
Peak Torque at RPM: 346 @ 4500
Mods:
Cobb AP v3
Cobb SF intake with airbox
Nameless Performance Downpipe
Tomei Expreme Ti catback
Grimmspeed EBCS
Aeromotive FPR
Cobb Fuel Pressure Sensor
IAG Braided fuel lines
Tuned by JRTuned
brian_14sti is offline   Reply With Quote
Old 09-18-2018, 02:05 PM   #894
Euro vs Earth
Member#: 486082
2006 wrx
Blaaaak
06 WRX tr
80,000miles
Sept 2018
80 degrees F
Mods:
vf48
Cobb airbox, catted dp, up, cbe
GS tmic, ebcs
Some suspension bits that are irrelevant to power
mustang dyno
tuned by DBW motorsports
93octane - 316awhp / 346 lb-ft @19psi
91octane - 292awhp / 335 lb-f
[IMG][/IMG]
Euro vs Earth is offline   Reply With Quote
Old 10-10-2018, 03:37 AM   #895
Kostamojen
Member#: 2272
2018 Type-RA 196/500
1999 OBS Camo Wagon
2018 STI Type-RA
Stock vs. Tune on the graph
Accessport tuned by Snail Performance West Coast @ M45 Automotive
91 Octane
No other mods. Completely stock car...
Old 10-17-2018, 09:55 PM   #896
atbwrx
Member#: 447001
2014 WRX
Default 2014 WRX - 322whp/352tq
Mods on Prior Dyno Run:
Engine:
COBB A/P
COBB CAI
Process West Verticooler
COBB 3 port EBC
COBB 725cc injectors
Perrin Small Tube EL headers
Perrim Small Tube Up Pipe
Cobb Turbo Back
Stock Turbo and fuel pump
Drive Train:
Stock clutch
Mods since last dyno run:
Engine:
XSBoost Rebuilt V52 turbo w/Billet (light weight) compressor wheel
Cobb High Flow Fuel pump
Perrin Turbo Inlet
IAG AOS
COBB BOV
Drive train:
Stage 2 Competition Clutch and Lightweight Flywheel
Moore Performance Blast Plates
You can see the overlay of my prior run and the most recent one:
And here’s the video:
Tuner says I'm maxed out at 350 ft. lbs. with the stock 5 speed. Time for forged internals and 6 speed.
atbwrx is offline   Reply With Quote
Old 11-08-2018, 08:19 AM   #897
Turpid Porpoise
Member#: 476573
2008 Impreza WRX STi
Baseline # for a stocker at the dyno: Unknown
Boost: 22.87 psi
Fuel: 93 octane
Target AFR: 11.0
SAE Corrections: 1.02
Peak HP at RPM: 409 @ 6000
Peak Torque at RPM: 403 @ 4200
Mods:
Chassis: 2008 STI
EJ257 - IAG Stage 2
FP Blue
MAPerformance EL Header
GS Up-pipe
Cobb Catted DP
3" Exhaust
FIC1000
AEM320 Pump
IAG Fuel Rails
Parallel Fuel Lines
Radium Auto FPR
Torque Solution TGV Deletes
IAG 8mm Phenolic Spacers
ETS 3" FMIC
Silicone Inlet
3" Custom Intake
Speed Density Tuned
Turpid Porpoise is online now   Reply With Quote
Old 11-15-2018, 12:45 AM   #898
justacarguy2012
Member#: 424268
Do you have a dyno sheet? Im just curious to see
justacarguy2012 is offline   Reply With Quote
Old 11-15-2018, 10:53 AM   #899
Turpid Porpoise
Member#: 476573
Me? It's attached to my post.
Old 11-15-2018, 12:25 PM   #900
maperformance
Member#: 141043
2011 STI
black af
Nice curve for a street car. How do you like the header so far?
Boost: 22.87 psi
Fuel: 93 octane
Target AFR: 11.0
Mods:
Chassis: 2008 STI
EJ257 - IAG Stage 2
FP Blue
GS Up-pipe
Cobb Catted DP
3" Exhaust
FIC1000
AEM320 Pump
IAG Fuel Rails
Parallel Fuel Lines
Radium Auto FPR
ETS 3" FMIC
Silicone Inlet
3" Custom Intake
Speed Density Tuned
Post your OLD ride and your NEW ride. MF-DIF Member's Car Gallery 1291 03-03-2016 12:43 AM
Post your dyno results from today. (Mach V) banzai Mid Atlantic Impreza Club -- MAIC 70 03-28-2006 11:08 PM
hey baic folks, post your dyno results LEOSPEED Bay Area Impreza Club Forum -- BAIC 16 11-25-2003 03:22 AM
Utec dyno plots and target A/F ratios and some tuning advice. nmyeti Engine Management & Tuning 39 10-15-2002 03:29 AM
Post your dyno results here! Darryl Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-10-2001 06:40 PM
