Welcome to the North American Subaru Impreza Owners Club Saturday July 21, 2018
Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 09-29-2011, 12:31 PM   #1
alpom
Member#: 240141
Default baja tire size
I just bought a 2003 baja. I need to buy winter tires. What is the maximum size I can put with 16" wheels without having problem. I would like to get Lt tires or studed tires.
alpom is offline   Reply With Quote
Old 09-29-2011, 01:50 PM   #2
Buck Rogers
Member#: 139234
05NA Lifted Baja MT
Brilliant Silver
The narrow wheel well, and the way the arches close up at the bottom severely limits tire size. I have an 05 with a 2" body lift, and I run a 215/70 16 AT General, and these will slightly rub at full chalk when new.
Buck
Buck Rogers is offline   Reply With Quote
Old 09-29-2011, 04:57 PM   #3
Samirr76
Member#: 4835
2003 Baja 5MT
Yellow w/ 220,000 miles
LT tires are often worse in the snow compared to passenger snow tires.
Samirr76 is offline   Reply With Quote
Old 09-30-2011, 10:12 AM   #4
alpom
Member#: 240141
true but lt in quebec is perfect to start winter, in the law we must have snow tire or LT tires from december 15 to march 15. sometimes there is praticly no snow and I would like to put my snow rallye tires on it when there is a lot of snow only. yokohama A034.
Same for summer... A035 for gravel and mud... and LT for everything else.
what is the minimum size of LT? I think its with the general... grabber
Old 09-30-2011, 12:04 PM   #5
Buck Rogers
Member#: 139234
05NA Lifted Baja MT
Brilliant Silver
I know some folks have run 215/65 16s on stock Baja s, and that may be the smallest AT, but I'm not sure of that.
Buck
Old 09-30-2011, 04:05 PM   #6
Samirr76
Member#: 4835
2003 Baja 5MT
I beleive Buck is correct. 215/65 should also be similar in overall diameter to the stock 225/60, just a bit skinnier.
Old 09-30-2011, 04:50 PM   #7
lumpy
Member#: 28410
2012 Outback 3.6R
RRP
You've probably seen this already, but it is very handy.
TIRE SIZE CALCULATOR
I've probably used this thing 50 times or more over the years...
lumpy is offline   Reply With Quote
Old 10-02-2011, 10:17 PM   #8
alpom
Member#: 240141
thank you guys
need to lift a bit then. 2 or 3".
Old 08-26-2015, 03:11 PM   #9
industryrocker
Member#: 176937
Chapter/Region: PRSIC
2002 RS-T
white
235/60\16 on a 2003 w. Stock suspension.
industryrocker is offline   Reply With Quote
Old 08-26-2015, 11:03 PM   #10
Buck Rogers
Member#: 139234
05NA Lifted Baja MT
Brilliant Silver
I'd like to see a picture of that
Old 07-12-2018, 04:47 AM   #11
GatorIsaac
Member#: 306142
2003 Baja
Silverstone
Default New Tires
I recently installed Cooper Discoverer AT3 tires in 215/70-16 on my 2003 Baja. They look and handle great with no rubbing yet. Haven't carried any heavy loads though. I have nearly 400k miles on this vehicle and have found Firestone Winterforce tires to be the absolute best in snow, water, mud, and all around driving.
GatorIsaac is offline   Reply With Quote
Baja speaker sizes?? Slug71 Baja Forum 10 07-24-2009 01:05 PM
Baja Turbo size and psi INFO Please Kc2Buk Baja Forum 18 04-06-2005 09:10 AM
Racing Tire Size to Street Tire Size mav1c Brakes, Steering & Suspension 0 11-18-2002 03:16 PM
Interesting Tire Size/Contact Patch Size/Shape Info - aka why I don't have 18" wheels rao Brakes, Steering & Suspension 6 06-19-2001 04:08 PM
Here is tire sizes chart. No more tire size Qs? Yeah, right! 25psi Brakes, Steering & Suspension 18 04-18-2001 03:29 PM
