Welcome to the North American Subaru Impreza Owners Club Sunday September 23, 2018
Old 07-16-2018, 03:10 PM   #1
three60austin
Member#: 487595
Default What custom or specialty tool did you make today?
Completely random, while the company 23 is being used on the car right next to me, I just needed a wrench with a little more bend to it. And a ratchet, well, it ratchets.
An extra harbor freight 17mm will now be in the specialty tool drawer.
Last edited by three60austin; 07-16-2018 at 03:24 PM. Reason: html is coming back to me now
three60austin is offline   Reply With Quote
Old 07-16-2018, 03:34 PM   #2
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Looks like an older EJ engine based on the plunger type TB tensioner.
I usually just use a 1/2" ratchet or breaker bar with correct socket.
I also have an, "honest to God, pair of COBB cam wrenches", one has a big bevel ground into it to deal with DOHC cams on older EJ's.
Frikkin really?
These were sold when EJ's were common.
Whatever, if it works for you, great.
PS, is this for turning things or breaking the bolt free/torquing up?
I ONLY spin timing components using the crank bolt......
PPS, your DS intake cam may be a tooth off.......may just be the photo angle.
Charlie-III is online now   Reply With Quote
Old 07-16-2018, 04:44 PM   #3
three60austin
Member#: 487595
Frikkin really?
Yeah it looks like the only tools COBB has to offer anymore is EMS.
This wrench was just used to take the slack out of the belt. I just hate when the cams spring on you.
Its just the angle of the picture, and when the last belt was installed they put the yellow marks on there a little "off". The customer just headed out with this one.
I have a few screwdrivers in my specialty drawer bent around just enough for VW and other random Airbag removal as well. Quite a fun drawer to go through sometimes.
Old 07-16-2018, 05:49 PM   #4
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Well, when doing doing loaded cam when doing a timing belt.....use a breaker bar or combination wrench. Then you can control load REGARDLESS of valve springs wanting to twist a cam.
Sorta seems obvious to me.
I have dealt with COBB since about 2000, just saying.
Yes, I have some oddball tools (bought, made or repurposed) over the years.
An example, a Gearwrench axlenut kit can be used for press in bearings.
Yes, I have a pair of stamped steel pliers for a couple year Chevy rear drum adjusters.
Old 07-16-2018, 06:21 PM   #5
three60austin
Member#: 487595
Sort of like my ball joint press tool kit, contains many old separated ball joints of different sizes, to press others out. Looks like junk, but they are real treasures when you cant find the correct combination with just the regular kit.
Speaking of drum brakes, some people would look at something like this and not have a clue what it is anymore.
Old 07-17-2018, 09:02 AM   #6
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Ahhh.....spring pliers. My first car on the road was a 68 Plymouth Fury III with 4 wheel drum brakes. It teaches you to manage braking since they got hot fast.
