Welcome to the North American Subaru Impreza Owners Club Friday January 18, 2019
Old 09-13-2018, 01:18 PM   #1
WRXXXED
Member#: 432652
2010 Subaru WRX STI
61K (Gray)
Default Do i need a tune after aftermarket intake manifold?
Dont know if this thread is in the right discussion but i am running a built motor so i figured why not here...
Currently running a:
Speed density kit
Rotated 3582r
Stock intake manifold
My question is if i run an aftermarket intake manifold will i need a retune? I wouldnt think so because the manifold really just increases flow and the computer will just adjust for the increased flow of air. Just just asking for peoples opinions because im not expert.
Best reguards,
Aaron
WRXXXED is offline   Reply With Quote
Old 09-13-2018, 01:53 PM   #2
svynx
Member#: 210371
2002 hybrid 16gxt
'03 Lifted TS
IMO yes, you'll need a retune. Being that you are running a SD tune, anytime you change anything between the throttle body and the cylinders, you'd need a retune.
A good thread to read:
https://forums.nasioc.com/forums/sho....php?t=1906415
svynx is offline   Reply With Quote
Old 09-13-2018, 02:43 PM   #3
mrsaturn7085
Member#: 375462
2006 Impreza WRX STI
WR Blue
Yes, you need a re-tune. Period.
mrsaturn7085 is offline   Reply With Quote
Old 09-13-2018, 07:01 PM   #4
bp05obxt
Member#: 459799
Ditto
bp05obxt is offline   Reply With Quote
Old 09-13-2018, 11:57 PM   #5
mrbunz
Member#: 491437
2007 Subaru wrx sti
blue
Definitely need a re tune
mrbunz is offline   Reply With Quote
Old 09-14-2018, 12:32 AM   #6
WRXXXED
Member#: 432652
2010 Subaru WRX STI
61K (Gray)
Got it. Need a retune
Old 09-14-2018, 02:03 PM   #7
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4+ hybrid STi
Originally Posted by svynx View Post
IMO yes, you'll need a retune. Being that you are running a SD tune, anytime you change anything intake and the exhaust, you'd need a retune.
Fixed
Old 09-14-2018, 02:52 PM   #8
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
No you don't get it, YOU NEED A RE-TUNE
J/K but with our cars you almost need a retune when you change anything.
Old 09-14-2018, 04:32 PM   #9
subaru_gc8
Member#: 29292
2004 WRX wagon
Speed density kit
Rotated 3582r
Best reguards,
Aaron
so will you need one, sure its always good to have the tune match the upgrades. if you are using the stock ecu. it compensate for it some what. a bigger intake manifold will flow more air so im assuming that you will probably lean out more on the low side of the rev range. honestly you stock comp will compensate before the cel comes on. if you don't want to get a tune, just start out slow and build up to full throttle to see what your trims look like. that will tell you more than some guy on the internet thats never tuned a car before So basically datalog datalog datalog and check your trims
Old 09-14-2018, 05:01 PM   #10
bp05obxt
Member#: 459799
This is how forums cause issues. The basis of what is being said here is fundamentally flawed. Cars are tuned in order to adjust parameters for different parts. As it was mentioned the ecu can adjust/adapt in certain ways to allow the car to “run” but it doesn’t mean it is right. If the ecu truly relearned and set parameters there would be no need to “tune” the car in the first place.
I get what is being said here, but to play around with something like this and test or try it out to see what happens seems silly. Data logging to wait until something isn’t right is backwards.
Bottom line get a tune when you change things.
If you are close to where the car is getting tuned maybe you can drive it there gently. I hope at least you have an AFR gauge to make sure it is okay in light load. Stay out of boost or heavy load.....
Old 09-14-2018, 05:25 PM   #11
kellygnsd
Member#: 32669
LINK G4+ hybrid STi
A MAF based tune would compensate better to this change that a SD tune. On a SD tune you will be following more air into the engine at the same rpm and MAP level and the only way your SD tuned ECU will know this is with a re-tune.
Old 09-14-2018, 09:00 PM   #12
subaru_gc8
Member#: 29292
2004 WRX wagon
lol so my question is how much more air is it going to flow it you dont mess with the wastegate duty or just changing the intake manifold? I personally would never put my car on the edge of tuning so yeah. as far as needing a tune, you probably should but what I am saying is it will run. just watch your fuel trims and your afrs, if they start to get a little out of control, just let off the gas.
as for the datalonggin, how do you think tuners know when somethings not right? they dont guess they datalog.... im assuming you have never tuned a car and if that is the case how would you know?
as for Kelly I do have a question, do if your map sensor is running off the manifold pressure, how is the pressure going to change if there is not more air being forced into the manifold, the biggest problem would be more air getting into the heads at the begining of a run but afterwards I was told a bigger manifold doesnt really make that big of a difference.
Old 09-15-2018, 02:17 AM   #13
mrsaturn7085
Member#: 375462
WR Blue
Because speed density is an estimation based on a model you create and MAF-based fueling is a measurement using a sensor. Yes, in the end they are both an estimation of air mass... but MAF fueling is a more direct measurement. The downside of course is that MAF controlled fueling will flat-out stop working with an air leak large enough while a speed density setup will let you blow an intake hose and keep running. This is why SD is generally the choice for everything from tuned to full motorsport cars; it is just more reliable.
Kelly is correct in his logic - speed density will always require a tune. Period.
With MAF-based fueling in an ideal scenario, you could change every part of the motor and it would still run. There are, in fact, motor swaps that can be done safely without even retuning using a good MAF based system.
Old 09-15-2018, 02:21 AM   #14
kellygnsd
Member#: 32669
LINK G4+ hybrid STi
A good aftermarket intake manifold can gain you 30+ whp or more on the top end depending on the setup. That 30+whp is a result of the increased volumetric efficiency of the setup, or in simple terms, for the same boost level the engine is flowing more air, therefore making more power.
Most VE based speed density systems are tuned MAP vs RPM in a 3D table. Your old fuel table accounted for X amount of air at what ever arbitrary load point but now the engine is actually flowing 30+ more whp worth of air that could lead to problems. That is not a small % change in airflow a could lead to possibly dangerous lean conditions.
With a MAF based tune, since you are measuring airflow entering the engine directly, changing the manifold is not as big of an issue since the increased flow is accounted for as long as your MAF is not maxed out. You should still datalog though.
